Author Topic: .  (Read 15615 times)
Re: Arcade Road Trip: I'm not stupid, just Crazy. (RedTent #2)
« Reply #40 on: September 14, 2015, 02:47:55 pm »
I just want to say that I partially agree with the title of this thread.  :cheers:
ChanceKJ
« Reply #41 on: September 14, 2015, 06:45:23 pm »
« Last Edit: March 19, 2021, 12:03:15 am by ChanceKJ »
ChanceKJ
« Reply #42 on: September 17, 2015, 12:57:44 am »
« Last Edit: March 19, 2021, 12:03:20 am by ChanceKJ »
« Reply #43 on: September 17, 2015, 01:12:16 am »
Under the yoke? Hmmmm.. sparks usually equals flyback, but under the yoke is odd. Is it loose?
« Reply #44 on: September 17, 2015, 01:12:58 am »
Wait, what did you plug the monitor into? You used an iso, right?
ChanceKJ
« Reply #45 on: September 17, 2015, 01:45:19 am »
« Last Edit: March 19, 2021, 12:03:24 am by ChanceKJ »
ChanceKJ
« Reply #46 on: September 17, 2015, 01:49:25 am »
« Last Edit: March 19, 2021, 12:03:28 am by ChanceKJ »
« Reply #47 on: September 17, 2015, 01:52:11 am »
how much you wanna bet if i pull that yoke off i'll find charred corrosion under that coil?
Hopefully that's ALL you find...  :cheers:
« Reply #48 on: September 17, 2015, 01:53:48 am »
Oh, and I've gotten to the point where I just cap the monitor first before I fire it up. Saves time.
johnrt
« Reply #49 on: September 17, 2015, 03:56:34 am »
^THIS
Cap the monitors BEFORE firing it up. When caps are at wrong values due to age and leakage it affects the electronic properties. This can for example increase a frequency somewhere in the circuit causing higher voltages to be generated and thereby blow the damn thing to kingdom come.
« Last Edit: September 17, 2015, 06:25:39 am by johnrt »
SlammedNiss
  • Last login:Yesterday at 01:46:31 am
  • Mine Drags the Ground!
« Reply #50 on: September 17, 2015, 05:41:57 am »
Lol! And you thought it was a long drive for you!
EDIT: You ARE crazy, its only two hours further from where I live in Oklahoma to get to Regina SK.
Great thread, but yea, I agree. I could never drive that far for a cab. Btw, about what parts of OK you live in?
« Reply #51 on: September 17, 2015, 09:04:54 am »
Tulsa area,  Claremore.
