Author Topic: So it turns out that I have a Joust cabinet.  (Read 3665 times)
Cobolisdead
« on: July 22, 2015, 02:30:46 pm »
So, I have this WWF Wrestlefest arcade machine. I haven't done anything to it yet, as I originally got it in a lot deal and I didn't especially want it. However, the machine was the only one of the lot that was actually working, but needing some monitor adjustments, and it has been sitting while I work on other projects. I start to think about putting it on Craigslist to let someone else restore or convert it to another JAMMA game, but then I get curious about the bezel art that doesn't match the rest.
So now I am wondering what to do with this game? Is it worth it to convert it back to Joust? Or should I just kick it down the line to the next guy that might want it more?
Re: So it turns out that I have a Joust cabinet.
« Reply #1 on: July 22, 2015, 02:47:58 pm »
I want the boards!
« Reply #2 on: July 22, 2015, 03:22:34 pm »
I'd get a Jrok board and make it a Multi-Williams.
« Reply #3 on: July 22, 2015, 04:08:28 pm »
You took the words right out of my mouth.  I'd convert it to a Multi-Williams and THEN sell it.
D
« Reply #4 on: July 22, 2015, 04:13:19 pm »
Harrrummmph!
« Reply #5 on: July 22, 2015, 04:21:26 pm »
Harrrummmph!
Way better than throwing a 60 in 1 in it, or a computer so he can play all the latest NES SNES and Genesis games on it. It's not like it's actually a working Joust, after all.
« Reply #6 on: July 22, 2015, 04:21:47 pm »
D
Sell it? What kind of infidel are you?
Cobolisdead
« Reply #7 on: July 22, 2015, 04:48:50 pm »
I want the boards!
You want the WWF WrestleFest Boards?
Not a bad idea. Any idea on where to get one?
« Reply #8 on: July 22, 2015, 04:49:37 pm »
Www.arcadeshop.com
Even if you wanted to go straight Joust, this is probably the most reliable way to do it.
« Reply #9 on: July 22, 2015, 04:53:35 pm »
Harrrummmph!
Precisely,  I was agreeing with you.  I thought you spoke Blazing Saddles.
« Reply #10 on: July 22, 2015, 05:02:58 pm »
Harrrummmph!
I do, I do! I can't believe I missed that!!! Yotsuya just pawn in game of life.
« Reply #11 on: July 22, 2015, 05:16:44 pm »
yes, fuggin LOVE that game
« Reply #12 on: July 22, 2015, 06:54:05 pm »
Dr. Samuel Johnson's right about Olson Johnson being right
ark_ader
  • I glow in the dark.
« Reply #13 on: July 23, 2015, 05:23:31 am »
Put CoinOpS in there and call it a day.
Cobolisdead
« Reply #14 on: July 23, 2015, 08:47:29 am »
I guess that I need to drill the back lock and see what remains in the back of the original system. Then I can make a more informed decision on where to go with it.
All right, if I sell the boards, I will let you have first dibs. Oddly enough, some folks on KLOV want the boards as well. I had no idea that the game was that popular.
I never heard of that before, what is it?
« Reply #15 on: July 23, 2015, 09:26:36 am »
kids born in the late 70s and early 80s grew up on the wrestlers in the game. I don't have as deep of pockets as the guys on KLOV so if you end up selling it to one of them I'll totally understand.  :cheers:
Cobolisdead
« Reply #16 on: July 23, 2015, 02:02:06 pm »
I will try to get it open tonight then and see what the situation looks like. Like I said though, I will give you first dibs on it over some random KLOVers. It's the least that I can do for all the help that you have given me over the past year.
ChanceKJ
« Reply #17 on: July 23, 2015, 02:56:36 pm »
+1 on the Multi-Williams. That's definitely a setup on my own list.  What all did you get in this deal anyways?  The Nintendo, a Pac, and then just this?
Cobolisdead
« Reply #18 on: July 23, 2015, 03:26:34 pm »
DK JR
2 Ms Pacman
and this WrestleFest in a Joust Cabinet.
It wasn't a bad lot, but other than the WrestleFest, I had no idea of the condition of the games before I bought them.
ChanceKJ
« Reply #19 on: July 23, 2015, 04:05:15 pm »
Still, as long as you got it for a decent price, that's a nice haul.
Cobolisdead
« Reply #20 on: July 24, 2015, 09:32:35 am »
Sadly, nothing got done last night as we had a big thunderstorm come through the area.
Anyone know what bit I should use to drill through the lock?
  • Last login:January 25, 2026, 02:48:44 pm
« Reply #21 on: July 24, 2015, 09:55:12 am »
I know it's tempting to think, 'the tumblers are brass, any old drill bit I can fit into the hole ought to do it,' but the truth of the matter is you will need to special order a lock bit.  Unfortunately, they're quite expensive and generally require you to be a licensed and bonded tradesman before the shops will sell them to you.  Maybe you can get lucky on a Friday afternoon in a small town if you are willing to pay cash and dress the part.
« Reply #22 on: July 24, 2015, 11:41:43 am »
Ive drilled through many a door lock with these: http://www.homedepot.com/p/DEWALT-Titanium-Pilot-Point-Drill-Bit-Set-14-Piece-DW1354/202019930
alternatively, you can reach through the back (assuming its held on with 2 drywall screws like every cab Ive ever bought) and just take the back off the cam lock
Cobolisdead
« Reply #23 on: July 24, 2015, 01:58:57 pm »
Unfortunately, this is the only cabinet that I have ever bought where the back panel is actually being held in place by the lock. Although there is a hinge that I might be able to remove, so I need to take a closer look at that.
« Reply #24 on: July 24, 2015, 02:26:32 pm »
Never heard of that and never used one.  Have drilled plenty of locks.  Start at 1/8" bit, use a bit of oil, and work your way up till it pops.  Usually takes me less than 2 min to bore out a lock and the bits don't even get hot or damaged.  Dunno.
ChanceKJ
« Reply #25 on: July 24, 2015, 03:17:56 pm »
ChanceKJ
« Reply #26 on: July 24, 2015, 03:19:05 pm »
a good high speed steel (HSS) bit will make short work of the lock.
Cobolisdead
« Reply #27 on: August 18, 2015, 11:31:59 am »
So I opened up this cabinet last night and got to look around. It turns out that this was done with a legit kit. They removed all the wiring, replaced it with a new harness, and left some NOS stickers and manual in the bottom of the cab.
« Reply #28 on: August 18, 2015, 12:43:18 pm »
Pretty cool that you found NOS stuff.  Any pics?
D
Cobolisdead
« Reply #29 on: August 18, 2015, 02:10:35 pm »
Unfortunately not for this. I didn't have my ipad on me and if I used my camera phone it would have looked like Bigfoot was holding them.  ;D
I will try to to take some tonight. I have a semi-local guy that wants just the cab to convert it to Joust, so I will take some pics of it then after I remove the PCB.
« Last Edit: August 18, 2015, 02:12:18 pm by Cobolisdead »
