Author Topic: MRotate using USB port.  (Read 24483 times)
woody4325
  • Newbie
  • Last login:February 08, 2021, 02:44:17 pm
« on: June 30, 2015, 02:47:32 pm »
Anymore consideration given to creating a version of MRotate that supports a USB port rather than a printer port?
Thanks.
Re: MRotate using USB port.
« Reply #1 on: July 01, 2015, 02:29:09 am »
Thanks.
Hmmmm. It has been thought of.
What sort of device (drive) do you have that communicates through USB?
I played around with using a PIC chip, but never finished it:
http://forum.arcadecontrols.com/index.php/topic,110083.0.html
« Last Edit: July 01, 2015, 02:31:10 am by DaOld Man »
« Reply #2 on: July 01, 2015, 02:40:41 am »
Where have my manners gone?
Just noticed you are new here.
Welcome to the forum.
This is the most time consuming, head scratching, finger scraping, and wallet draining hobby you can ever get into, but it is more than worth it.
Please don't be afraid to ask for advice or help, thats why we all are here.
You may now bow to Saint, for starting this knowledge packed forum.  :notworthy: LOL
darthpaul
  • Last login:March 11, 2026, 02:46:45 pm
  • Join, It's your duty
« Reply #3 on: July 10, 2015, 09:47:13 pm »
Amen to that Ken
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
Samson
  • Last login:March 23, 2022, 04:18:46 pm
« Reply #4 on: July 17, 2015, 11:15:03 pm »
There are some USB to RS232 breakout boards that can also be used for general purpose IO.
https://learn.adafruit.com/adafruit-ft232h-breakout/overview
http://hackaday.com/2009/09/22/introduction-to-ftdi-bitbang-mode/
The 232h breakout seems to offer more IO pins than some of the others.
The FTDI drivers are free, and there are application notes on how to use the gpio functions.  Might not be too difficult to incorporate into mrotate.
Of course these just offer IO, you still need a motor driver circuit.
Koz
« Reply #5 on: July 18, 2015, 08:15:51 pm »
That looks interesting Samson. Do you have one? If anyone does Id be glad to work on a version of mrotate for that, but I will need someone to test it for me.
SojuMaster
  • Last login:April 07, 2016, 11:57:28 am
« Reply #6 on: October 05, 2015, 10:03:47 am »
I have an USB Pololu Simple Motor Controller 18v7 that I am willing to be your test monkey :)
« Reply #7 on: October 07, 2015, 09:46:40 am »
Thanks Soju!
Does that controller use line commands to run? (I havent researched it yet).
If it does, you probably wont need MRotate with it. You may be able to run it directly from startcom in mala.
Can you shoot me a link, just so I make sure Im researching the correct drive?
Edit: I see you have already posted a link to that drive in your other thread, let me study it a bit.
« Last Edit: October 07, 2015, 09:48:18 am by DaOld Man »
SojuMaster
« Reply #8 on: October 07, 2015, 06:38:30 pm »
The Simple Motor Controller polulmu 18v7 is at https://www.pololu.com/product/1372
I am able to control the motor via the command line.  The one thing that that threw me for a loop at first is that you have set everything up with the software then save the configuration file.  Then at the command prompt, you have to load that configuration file before sending commands.  I am not sure how long the configuration stays loaded after the power and USB connection is disconnected.
Edit: You have to send two commands to the command prompt: smccmd --resume  and smccmd --speed 3200 or -3200.  3200  = 100% Speed.
« Last Edit: October 08, 2015, 09:23:09 am by SojuMaster »
« Reply #9 on: October 09, 2015, 05:52:33 pm »
Havent forgotten about you. Ive been working a lot of hours this week, but have a few days off coming up, so hopefully I can explore this real soon.
SojuMaster
« Reply #10 on: October 10, 2015, 01:24:41 am »
Take your time.  I know how it goes.  I am hoping that this weekend that I can squeeze in a few hours and move forward with my project.
« Reply #11 on: October 10, 2015, 12:25:49 pm »
Im thinking you can build a bat file with those commands in it, then call the bat file from startcom.
SojuMaster
« Reply #12 on: October 11, 2015, 08:46:46 pm »
I tried the bat before and no success...
But after looking at the smccmd source code, I noticed that I could put multiple arguments on a single command line **DOH**  :banghead:
The problem I have been struggling now with, is that the startcom plugin is acting stupid .... I built one playlist with two games (pac-man (vertical) and pac-land (Horizontal)).
I start with Mala in the Horizontal position, play Pac-Land, exit game and MaLa stays Horizontal.
I switch to Pac-land, Monitor moves to the Vertical position then I exit the game and Mala stays Vertical.  I don't want that, I want Mala to go back to Horizontal BUT I could live with it and I would just have to build two different layouts.
Now here is where it gets stupid, while MaLa is in the Vertical position, I select Pac-Land, the Monitor moves back to Horizontal but the game is now oriented Counter-Clockwise 90 degrees, so now I am looking at Pac-Land sideways.
I am pretty sure it is a setting or two that I need to fix but there are SOOO many options in MaLa, that this is getting frustrating.
« Reply #13 on: October 12, 2015, 12:02:08 pm »
Yeah, there is a setting in mala that has to be unchecked, let me look into it, memory aint what it used to be.
Edit:
Check out this thread:
http://forum.arcadecontrols.com/index.php/topic,130682.msg1338095.html#msg1338095
Or better yet, this thread:
http://forum.arcadecontrols.com/index.php/topic,91842.0.html
« Last Edit: October 12, 2015, 12:08:26 pm by DaOld Man »
