Author Topic: VertiGO - Vertical Cocktail Cab  (Read 20017 times)
mgb
  • North East, US
« on: June 29, 2015, 12:05:15 am »
I'm doing a full re-design on this project.
I will be changing the name as well.
Here is the new design:
« Last Edit: November 28, 2015, 11:05:29 am by mgb »
mgb
  • North East, US
Re: VertiGO - Vertical Cocktail Cab
« Reply #1 on: June 29, 2015, 12:10:10 am »
Here are a few concept designs I did on sketchup.
I don't want a plug jack on the side but I want to be able to plug it in neatly whether its on it's pedestal or a table so this is my plan:
mgb
  • North East, US
« Reply #2 on: June 29, 2015, 12:21:15 am »
The monitor I'm using is an HP LP2065.
It's a 20" 4:3 IPS display.
I stripped it out of its casing to save as much room as I possibly can
For the brains I will be using a Dell Duo Core Laptop I had around.
I stripped the mobo out and will be adding a SSD with Windows 7.
My plans are to keep it as light as possible.
Games will be limited to 2 and 4 way verticals and possible a couple of horizontal games run in cocktail mode, like Neo Bomberman.
I'm also planning a couple of usb ports for some game pads to play classic consoles with it in horizontal mode.
beyond that I don't plan on really any admin buttons. probably no pause and I'm not planning on coin buttons as I will set games to free play and use player 1 & 2 together for exit.
I would like to make the front end fun and I'm thinking of using Hyperspin on this one
mgb
  • North East, US
« Reply #3 on: June 29, 2015, 12:22:22 am »
This space reserved for some progress.
I've gotta get cutting  :)
mgb
  • North East, US
« Reply #4 on: June 29, 2015, 12:25:14 am »
I'm open to any ideas for the artwork on this.
Not that there's a whole bunch of room but like I said, I want it to be a fun kid friendly type of vibe.
« Reply #5 on: June 29, 2015, 12:31:04 am »
I cannot help you on the artwork but I love the design.    :applaud:
Could you use the base from a barstool and make the height adjustable?
« Reply #6 on: June 29, 2015, 12:34:10 am »
I'd be concerned about it tipping. How high is it going to be?
  • Last login:Today at 07:04:36 pm
« Reply #7 on: June 29, 2015, 01:02:02 am »
I like the inset IEC power inlet.   ;D
Instead of a bump in the bottom t-molding for the power cord, have you considered adding rubber feet on the bottom that are tall enough to keep the sides from pinching the cord when VertiGO is on a tabletop.
Maybe add two or three cord retaining "fingers" like in the attached pic to make it harder to accidently pull out the power cord.
JDFan
« Reply #8 on: June 29, 2015, 01:09:49 am »
Like the concept - but does look like it might be a bit tipsy (esp. when moving the joysticks )  :dunno
« Last Edit: June 29, 2015, 01:22:19 am by JDFan »
dmckean
« Reply #9 on: June 29, 2015, 01:12:04 am »
If the base is a little oversized, tipping shouldn't be an issue.
two40
  • Last login:December 28, 2020, 01:33:38 am
  • What does this button do?
« Reply #10 on: June 29, 2015, 06:12:58 am »
I'm with yotsuya. This thing will tip the first time an overenthusiastic friend yanks on the controls. The base would have to be either bolted down, very heavy or wider than what you've drawn.
mgb
  • North East, US
« Reply #11 on: June 29, 2015, 09:45:12 am »
Yeah, I've thought about the whole tipping possibility.
The base shown in the sketchups is just for reference.
I've checked out a couple of bar type pedestal tables and the bases are pretty heavy.
I'm planning on it being at a height where you can use a regular chair.
I'm not completely married to the pedestal base so if it doesn't work out, I'll be fine.
I don't have friends that play arcade games, nor do I have parties at my house so I'm not worried about it getting knocked over by a drunk friend or anything.
Scott, good call on the cabinet feet. I am planning on putting feet on it but wasn't planning on them being high enough to sit over the cord. I will consider that though. You do have a point, it would cause a little aesthetics issue with the tmolding.
JDFan
« Reply #12 on: June 29, 2015, 11:00:16 am »
Hmmm - Just remembered I have an old metal bar table that would be perfect for this type of setup -- It's actually pretty stable as is so this might not be too unstable  :dunno
The one I have is height adjustable from what would be sitting height like a normal cocktail cab to bar stool or stand up height so would be a pretty good base for you if you can find something similar (and has nice metal brackets that could make a square base for the unit with a bit of adapting !)
mgb
  • North East, US
« Reply #13 on: June 29, 2015, 11:08:45 am »
Yeah that's right where I'm thinking.
I'm waiting to hear back from a guy on Craigslist for one that looks good
I'm not worried about modifying it to my needs either.
I have access to people who weld so it should all work out.
But even if the pedestal base proves too tipsy, what the hey, I'll still have a nice tabletop machine
JDFan
« Reply #14 on: June 29, 2015, 11:14:02 am »
Perhaps make a table top for the pedestal base designed to mount the machine but also be easily removed so then the pedestal could be used as a small table top when not using the machine or when using the machine elsewhere.
« Reply #15 on: June 29, 2015, 11:24:12 am »
Well, to play devil's advocate, why not just put the tabletop machine on top of the small table and not worry about switching parts out?
« Reply #16 on: June 29, 2015, 11:32:19 am »
Here's a slightly better example of the "cord retaining fingers" mentioned above.   ;D
JDFan
« Reply #17 on: June 29, 2015, 11:33:19 am »
Not a bad idea either - figure that would also give you plenty of room for the cupholders  :laugh2: :cheers:
mgb
  • North East, US
« Reply #18 on: June 29, 2015, 12:36:25 pm »
No cup holders!!!
I realize I can just sit it on a small table but that's just not the exact setup I'm looking for.
I would like a particular look to it that having it on the pedestal would give.
I am thinking of different ways to mount it on the pedestal though.
I know it'd be easier to just sit it on a table but then again it's easier to just play the games on my regular home computer with a game pad but where's the fun in that.  :)
Scott,
  I'm familiar with the cord retaining fingers.
Good idea, I may go that route but with having them a little looser than some I have seen
Locke141
  • Never grow up.
« Reply #19 on: June 29, 2015, 04:54:10 pm »
Are you sure that's an IPS? That model had two different screens.
From a review:
Check the revision number on your box or on the back of your monitor. If it starts with "GSM" followed by 3 numbers then you have an S-IPS panel and won the "HP Lottery". Otherwise, you got the MVA panel which, while good, is not as color accurate as the IPS.
8BitMonk
« Reply #20 on: June 29, 2015, 05:20:09 pm »
Neat idea for a build, looking forward to seeing it progress. I'd say avoid the notch for the electric plug if you can, think it'd look better without.
mgb
  • North East, US
« Reply #21 on: June 29, 2015, 05:41:05 pm »
From a review:
Thanks for that because I had read that there were two different displays so I wasn't positive but I checked and sure enough it has the Gsm followed by 000 (I'm not sure why just zeros.)
Only kinda crumby thing is it has 2 dvi inputs and no vga input.
I will be using a vga to dvi plug will the mini slg still work as long as its before the adaptor
mgb
  • North East, US
« Reply #22 on: June 29, 2015, 08:35:07 pm »
I was really wanting a round base but I found these on Craigslist and at $15 each, I'll probably pick one up.
Locke141
  • Never grow up.
« Reply #23 on: June 30, 2015, 11:15:53 am »
I almost jumped on a good deal on the a while back but I have 3 20inch or larger 3:4 monitors waiting for me back in the U.S. If you don't mind me asking how much did you pay for it?
« Last Edit: July 11, 2015, 02:54:59 am by Locke141 »
mgb
  • North East, US
« Reply #24 on: June 30, 2015, 11:30:55 am »
$38 including shipping
« Reply #25 on: June 30, 2015, 12:19:14 pm »
A few things here:
First off, I wouldn't really "secure the plug" like people suggested.  If anything you WANT it to unplug if someone were to trip on the power cord accidentally.  Better to have it power off then to have it sideways on the ground with the cord still attached.  Most consoles today are designed this way (controllers) for that very reason.
The SLG works fine with DVI/VGA adapters on a monitor.  So no worries there.  I've tested them on my Samsung IPS monitor.  Also, you can put the SLG on either end of the VGA cord and it will still work.  So you could have the DVI/VGA adapter, the SLG, the VGA cord and the computer.  Or, the DVI/VGA adapter, the VGA cord, the SLG and the computer.
As for the pedestal, the ones for $15 look like the ones used on those wobbly tables you see everywhere.  Are you sure you want them?
Del
« Reply #26 on: June 30, 2015, 06:44:27 pm »
I would personally have a permanent extension cord that goes down the interior of the stand pole and out the bottom. Then have it plug into a coiled up cable hidden in an inside compartment, like the old boom boxes used to have because the 8 D batteries lasted only 2 hours. If you want to play free from the stand, unplug the extension cord, lift out the machine and uncoil the internal power cable.
mgb
  • North East, US
« Reply #27 on: June 30, 2015, 07:55:25 pm »
I have thought of something kinda along those lines. Bassically having a cord inside the pedestal shaft.
I'll really work out the odds and ends on that once I have a pedestal.
Delusional,
   I hear you on the wobbly table thing. There are a few reasons for that though. Many times it's also do to uneven restaurant floors and missing feet on the table stand. Also sometimes just a loose table top.
There's still the possibility of this whole thing being wobbly but that's sometging I still have to work on.
Worst case, I can build the pedestal my self or if I really can get a stable stand I will just put it on a table.
« Reply #28 on: June 30, 2015, 10:12:49 pm »
I think it's a great aesthetic you're going for and any wobble issues you'll be able to work through fairly easily with a bit of trial and error.  Looks like a fun project and a great take on the cocktail.
JDFan
« Reply #29 on: June 30, 2015, 10:40:59 pm »
Where is the stand going to be placed -- If you plan to have it always setup could always stabilize by adding some anchors into the floor so that it doesn't move.  :dunno
mgb
  • North East, US
« Reply #30 on: June 30, 2015, 11:13:40 pm »
Man, I just noticed that in my sketchups I have the buttons for player 2 on the wrong side.
JDfan, bolting it down won't really be an option. Though that would be a great way of doing it in a dedicated game room.
I did find a couple of cabinets that use this pedestal idea but I wouldn't be surprised if they get bolted down.
mgb
  • North East, US
« Reply #31 on: June 30, 2015, 11:16:34 pm »
I'm hoping to cut the sides soon.
I'm hoping to get them cnc'd for a nice clean finish.
8BitMonk
« Reply #32 on: July 01, 2015, 01:04:50 am »
Not sure if they'd be heavy enough but how about 1 or 2 of those weighted bottoms for patio umbrellas? You could remove the poles when not in use and store the stands.
« Last Edit: August 07, 2017, 08:06:30 pm by 8BitMonk »
mgb
  • North East, US
« Reply #33 on: July 08, 2015, 12:54:09 pm »
So last night I was at the arcade in the Indian Casino and they had some tables in there's with the perfect base for I'm looking to do.
These bases are very much stable.
Of course a base this tall would need to be cut down a bit for the height I want but that's not a big deal.
dmckean
« Reply #34 on: July 08, 2015, 01:15:56 pm »
I think what you want to search for is a 17" cast iron round table base with footring.
« Reply #35 on: July 08, 2015, 01:30:19 pm »
Looks like about $100.
mgb
  • North East, US
« Reply #36 on: July 08, 2015, 03:16:53 pm »
You guys are awesome.
Thanks for the leads on where to look.
mgb
  • North East, US
« Reply #37 on: July 08, 2015, 05:52:07 pm »
I'm actually looking to stick with a 22".
The one I saw last night was definitely 22"
The foot ring would be nice but not needed, especially because I plan to have it shorter.
dmckean
« Reply #38 on: July 08, 2015, 06:29:44 pm »
Looks like you can save quite a bit of money if you don't need  the footring.
http://www.bizchair.com/ji3-22rdtp12bhfr-jib.html
http://www.bizchair.com/ji3-22rdtp12-jib.html
mgb
  • North East, US
« Reply #39 on: July 08, 2015, 09:44:17 pm »
Yeah, it appears that the ones with the foot rings are 41" bar height units but I'm looking for the 28" dining height type which is like the 2nd one you posted.
I found a nice one for $50 plus $24 shipping.
I'm also searching local places to see if I can save the shipping.
