Author Topic: Mala Error: when setting "snap" directory  (Read 3242 times)
jlfreund
  • Last login:June 12, 2025, 02:25:33 pm
    • My project's blog
« on: June 20, 2015, 06:48:27 pm »
Hi,
I have Mala 1.7.4.0 for Windows running on a Win7 64bit computer.  I just downloaded all the "snaps' (ie screenshots) and set the directory under: "MAME Config -> Pictures and Videos -> Snap / Title"
When I click OK, I get:  "Unexpected error.  Mala will terminate"
In the mala.exe.log, it says:
15:40:31.75   Info: Options: OK Clicked. Collecting data
2015/06/20  15:40:31.75   Error: Exception Message: Cannot create file "C:\MAME\Mala\MaLa174\mame.mli". Access is denied, Object Function: SaveInfoPages, Exception Class: EFCreateError, Object Class: TPopupList
2015/06/20  15:40:35.26   Info: Showing taskbar
2015/06/20  15:40:35.27   Error: AppException: Terminating MaLa
Any help would be appreciated.
jlfreund
    • My project's blog
Re: Mala Error: when setting "snap" directory
« Reply #1 on: June 20, 2015, 08:25:11 pm »
Note, falling back to MaLa 1.0.5 (loading all the same data files) fixes the problem, so for now, I  will stick with that one.
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
« Reply #2 on: June 22, 2015, 10:14:56 am »
You might check using the last beta of MALA 1.820.
Have you defined a snaps object in your layout?
Greetings.
