Author Topic: Mini Wreck it Ralph Pi Cabinet  (Read 7608 times)
stallion85
  • Last login:January 26, 2016, 11:32:08 pm
  • I dabble in the arcade building.
« on: April 30, 2015, 05:19:57 pm »
Finished up school last fall  :applaud: and decided to build a mini cabinet with a raspberry pi at the core. Turned out pretty good I think, even though it is a little bit messy inside.
I didn't take a lot of build pictures, sorry about that.
SPECS:
1/8 MDF Laser Cut to a donkey kong type cabinet
Raspberry PI B+
Mini Joystick (http://www.digikey.com/product-detail/en/04A-B01/GH7455-ND/2138044)
Mini Arcade Buttons (http://www.digikey.com/product-detail/en/0/EG1938-ND)
Speakers I had laying around, which smaller ones would have been much easier to fit
4.3 in LCD (http://goo.gl/oWfO3A)
Voltage Converter (http://goo.gl/4LMNkE)
Raspberry Pi Shutdown Switch (http://goo.gl/aMSV2x)
I used retroPi for the front end and have MAME, Atari, NES, Sega Master System and Sega Genisis on there. (Good emulators to use 3 buttons with)
Might have missed something, but that is most of it.
Now for the pics! (I'll try to get a video of it in action soon)
Video of it in action. Not a great video, but a video non the less.  ;)
« Last Edit: May 01, 2015, 10:14:35 am by stallion85 »
Slippyblade
Re: Mini Wreck it Ralph Pi Cabinet
« Reply #1 on: April 30, 2015, 05:44:05 pm »
Not too shabby.  I'd like to know about the art though.  Did you paint the MDF and then laser etch the art?  I'm curious due to the monochrome nature.
I assume you are using the GPIO for controls?
What are the buttons on the top for, I assume power?
Is it just Wreck it Ralph or do you have other games?
ChanceKJ
« Reply #2 on: April 30, 2015, 06:00:24 pm »
 :applaud: Thats pretty clever. good job.  :D
stallion85
« Reply #3 on: May 01, 2015, 09:24:58 am »
I'm a little new at using a laser. I did paint the MDF first then vector cut the shape and etched the images. It looks good, but if I did it again I would paint the mdf, cover it with tape, etch it and then paint the etches with black and then remove the tape to give a better contrast and nice two color look.
I did use the GPIO for the buttons. Worked great.
Buttons on top are power and exit to exit back to the game menu.
It actually doesn't play Fix it Felix at all.... :embarassed:  I don't think there is a good linux version of it, but I could be wrong.
I edited my first post to show what emulators are on it.
stallion85
« Reply #4 on: May 01, 2015, 10:15:05 am »
Added a video in the original post of it actually working.
Slippyblade
« Reply #5 on: May 01, 2015, 03:05:42 pm »
I've had a question about those Grayhill mini-joysticks for a long time.  The Digi-Key page lists it as 4 way.  Is there a restrictor or something in there or is it actually an 8-way?
  • Last login:Today at 05:10:51 am
« Reply #6 on: May 02, 2015, 02:33:15 am »
It is an 8-way stick.
There's no way to add a restrictor plate on the bottom.   ;D
Related thread here on the mounting method pictured above.
Aceisback
  • Last login:February 04, 2021, 07:45:41 pm
« Reply #7 on: May 02, 2015, 03:09:16 am »
Nice setup. I am in the process of building a mini also using a Pi. Waiting on parts to arrive so I can really get going with it.
05SRT4
  • Check out my Pow Pow
« Reply #8 on: August 23, 2015, 08:32:12 pm »
Great job on this!
Ive been wanting to build another Micro Arcade. Thanks for sparking the fire.
This should be added to the Micro Arcade projects on the wiki.
« Reply #9 on: August 23, 2015, 08:46:01 pm »
Sounds like a plan if Stallion85 grants permission to upload one of the pics to the wiki.   ;D
If it is OK, which pic would you like to use for the wiki, Stallion85?
stallion85
« Reply #10 on: August 24, 2015, 02:56:33 pm »
Definitely. That would be awesome.
Probably this one I guess (Maybe I will get a better picture with something to reference the size later)-
« Last Edit: August 24, 2015, 02:58:33 pm by stallion85 »
« Reply #11 on: August 24, 2015, 05:01:55 pm »
Here's a first draft http://newwiki.arcadecontrols.com/index.php?title=Wreck_It_Ralph_Micro.
Let me know if there's anything else you want to add to the writeup.
Added it to the micro builds and builds by year lists.   ;D
When you post the better picture I'll upload that one, unless it will take you a long time to do it.  :cheers:
« Last Edit: August 24, 2015, 05:04:32 pm by PL1 »
