Author Topic: Problem with new 60-in-1 PCB  (Read 1476 times)
medtech1
  • Last login:July 10, 2015, 04:27:30 pm
« on: April 25, 2015, 02:04:40 pm »
I'm having an issue with a new 60-in-1 PCB board..
I’m testing the board and all the control leads using “I/O test”
All the wire pinouts appear ok, except Player 1:
1)   Red wire #18 (Part side) triggers both “P1-UP” and “P1-Left”,
                  and
2)   Yellow wire #20 (Part side) triggers both “P1-Left” and “P1-UP”.
This isn’t  a harness issue, as I removed the harness from the board, and  tested these two wires with an ohm meter, and they are not shorted.
Unless it’s a programming issue, I wonder if the board is shorting the two some where?
Any ideas?
Thank you!
RetroGreg
Re: Problem with new 60-in-1 PCB
« Reply #1 on: April 25, 2015, 02:35:41 pm »
Well the first thing I would check is if the voltage from the power supply is ok and then make sure you wired the ground up correctly.
medtech1
« Reply #2 on: April 25, 2015, 02:40:25 pm »
I found this on the board... which is a short between two pins soldered on PR4 (resistor pack?).
I sort of doubt this would be intentional unless someone screwed up on the board design and this was a quick fix..
medtech1
« Reply #3 on: April 25, 2015, 02:42:00 pm »
Thanks for the reply. Power supply voltages are ok...  Everything else appears to work so far. I get video/sound.. all other I/O tests work. Just this one issue.
medtech1
« Reply #4 on: April 25, 2015, 03:06:20 pm »
I was lucky.... I found that short on the resistor pack... remove it... everything works now for player 1-UP and player 1-Left
Picture after I removed the short.
It is obvious this board was not tested.. this could never have worked correctly.... anyways.. glad it works now.
RetroGreg
« Reply #5 on: April 25, 2015, 03:07:37 pm »
Maybe someone who has a board available can look at theirs and see if the soldering is the same in that spot you noticed.
Edit: nice work! Glad you were able to get it working.
medtech1
« Reply #6 on: April 25, 2015, 03:09:38 pm »
Thanks RetroGreg.. I had more boards coming.. but I took a chance (despite it being micro-work), removed the short, and it works correctly now.
I have to say I never thought I'd use my PC microscope before to repair PCB's... but it sure came in handy for this.
Also I didn't want to have to return the board..
Wyo
« Reply #7 on: April 25, 2015, 05:24:49 pm »
Nice job!!! A lot of people, such as myself, would have never figured that out.  :applaud:
I guess we need to be careful when using these boards.  I bought a 19n1 two months ago that I have yet to test....I need to get on that.
paigeoliver
  • Awesome face!
« Reply #8 on: April 25, 2015, 10:54:04 pm »
They don't even test the whole cabinets that they put together with those boards in it. I have done service calls to two Chinese built 60 in 1 cocktails and neither one of them had the player 2 side even wired up.
