Author Topic: trackball doesn't work in mame??  (Read 2745 times)
angryadmin
  • Last login:October 31, 2013, 12:14:53 am
« on: December 27, 2003, 01:09:10 am »
My Trackball works fine (wired through opti-pac),  it works fine as a mouse but in games it won't work, only the joystick will, what am I doing wrong?
NH
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
Re:trackball doesn't work in mame??
« Reply #1 on: December 27, 2003, 01:10:18 am »
You need to enable it in the config file.  To create the config file, run mame -cc.  Then set mouse from 0 to 1.
angryadmin
« Reply #2 on: December 27, 2003, 01:30:59 am »
Thanks so much!!
BTW, I am also having problems with the forth player, on 4 player enabled games like gauntlet the forth player joystick and buttons don't work, but I tested them and they are sending the correct key strokes, (using I-Pac4). Am I missing another setting?
NH
Thenasty
  • Last login:March 19, 2026, 01:43:07 pm
« Reply #3 on: December 27, 2003, 10:12:25 am »
did you set it up in MAME for the forth player keys/buttons ?
Free VGA Breakout Cable
angryadmin
« Reply #4 on: December 27, 2003, 02:14:48 pm »
Ok, now I feel like an idiot, what do I have to do to enable the fourth player in mame?
NH
TalkingOctopus
    • My Arcade
« Reply #5 on: December 27, 2003, 07:37:45 pm »
Some games you have to go into the config menu to enable 4 players.  To go into that menu either press F2.  Another way to get there is press Tab then goto dip switches.
