Author Topic: Terminator 2 guns convert to mame  (Read 5363 times)
Sgc
  • Last login:January 20, 2018, 04:25:36 am
« on: February 08, 2015, 06:33:19 pm »
Hi has any one managed to convert these guns to mame,and whats the best way to go about it.
Re: Terminator 2 guns convert to mame
« Reply #1 on: February 08, 2015, 06:38:28 pm »
Any encoder that accepts analog inputs will work fine.  Uhid or Kade+ .  Getting the force feedback to work is trickier but getting the guns to be recognized by windows is a cinch.
Sgc
« Reply #2 on: February 08, 2015, 06:42:18 pm »
Thanks, is the wiring straight forward and the force feed back? never tried anything like this are there any wiring diagrams of this.
« Reply #3 on: February 08, 2015, 06:48:54 pm »
If you've never done much of this stuff it will be a bit confusing at first but it really is pretty straight forward.  Just hook the potentiometers up to the encoder and you'll be good.  The force feedback requires relays, and encoders capable of output so it gets trickier.
Sgc
« Reply #4 on: February 09, 2015, 03:06:44 pm »
What kind of relays and encoders would work with this setup.
« Reply #5 on: February 09, 2015, 03:26:46 pm »
Wiring diagrams for the pots:
http://forum.arcadecontrols.com/index.php/topic,109833.msg1163276.html#msg1163276
I believe charlieram got MAMEhooker working properly for the recoil output, but you'd have to get solid state solenoids or build a circuit to step up the juice.
I'd assume the solenoids in the T2 guns will pull more current, so you'd need beefier parts than charlieram used.
http://forum.arcadecontrols.com/index.php/topic,132537.0.html
Sgc
« Reply #6 on: February 13, 2015, 06:29:34 pm »
Hi have e-mailed Andy at Ultimarc he says the guns will work with the A-pac his concerns was setting the aim of the guns., i am just waiting of a delivery of a A-pac. So i can make a start. Has any one actually got these type of guns working in Mame.
« Last Edit: February 14, 2015, 09:40:04 pm by Sgc »
« Reply #7 on: February 14, 2015, 09:13:11 am »
Hi have e-maild Andy at Ultimarc he says the guns will work with the A-pac his concerns was setting the aim of the guns., i am just waiting of a delivery of a A-pac. So i can make a start. Has any one actually got these type of guns working in Mame.
Not T2 guns, but similar ones.
They're basically just joysticks with an X and Y axis same as any other joystick.
There's nothing mysterious to getting them working if you have a good understanding of how analog input works in MAME.
Whatever you do, don't map anything to Analog INC or Analog DEC in MAME.  Those aren't for analog inputs.
They are for when you are using pushbuttons in place of real analog controls.
Only map the axis.
Here are some calibration pointers I posted elsewhere:
1.  Calibrate the positional gun in windows by pointing it along the edges of the screen.
2.  In mame.ini set the dead zone to zero.
3.  In mame.ini set the saturation to 1 (100%)
4.  Calibrate the gun in the game's service menu
5.  Adjust the sensetivity under analogue controls in MAME's in-game menu until the crosshairs don't lag behind the gun movement.
    (there is only ONE sensetivity setting, ignore all settings that include the word DIGITAL)
If you are using a widescreen, when you calibrate it in-game, only move the gun to the edges of the 4:3 image.
I don't recall if I did the same while calibrating it in windows, but it may be necessary.
Model 2 emulator only accepts mouse movement, but I believe you can get it working with the APAC using Howard Casto's Troubleshooter2 program.
Look for it in the software subforum.
EDIT: Ha! found some old video of my first gameplay after tinkering with a positional gun.  No FFB, I have it wired to a leftover racing pedal interface, & I'm actually firing with a keyboard.....but it was a start.  ;D
http://www.flickr.com/photos/25643351@N07/4886932428/#secret2e9a647964
« Last Edit: February 14, 2015, 09:22:53 am by BadMouth »
Sgc
« Reply #8 on: February 15, 2015, 12:02:49 pm »
Thanks for all the pointers iwill let you know how i get on once i get my A-pac.
Sgc
« Reply #9 on: February 28, 2015, 05:06:51 am »
Have just got my A-pac  nearly ready to make a start,cleaning up the guns at the moment, willupdate once ive conected up.
