Author Topic: I'm looking for a square button  (Read 3692 times)
Generic Eric
« on: January 23, 2015, 08:42:02 pm »
I'm looking for a square button that is easy to disassemble in the hopes of putting a transperacy label to illuminate it.  Is there such a beast?  Or do I have to use a sharpie and hope it doesn't wear off, or paint it or apply vinyl?
This is what I'm talking about here.
MonMotha
Re: I'm looking for a square button
« Reply #1 on: January 23, 2015, 09:32:18 pm »
Those are illuminated buttons.  They're available in a wide variety of sizes and colors, and you usually can pull the diffuser out from the main plunger/lens assembly and could put a graphic insert inside.
Happ sells a line of them, and the premium line is from Sanwa Denshi in Japan.  You can also buy them direct from China, of course.
  • Last login:Today at 04:23:32 am
« Reply #2 on: January 23, 2015, 09:34:46 pm »
Divemaster has the small regular-profile and small or large low-profile square Happ buttons.
Your pic looks like the large low-profile button here rather than the small low-profile button here.
Generic Eric
« Reply #3 on: January 23, 2015, 10:24:08 pm »
"1x Arcade Video Game 33mm White Square Push Button Switch Lamp LED Illuminated" is the item description $2.5 + 1.00 for s/h  combine for additional .5 for s/h
« Reply #4 on: January 23, 2015, 10:57:03 pm »
Sounds like you've found another manufacturer.
Link?   ;D
Generic Eric
« Reply #5 on: January 23, 2015, 11:01:29 pm »
Link?   ;D
shazzle
That's from ebay.
« Reply #6 on: January 23, 2015, 11:18:39 pm »
Did you buy? Please report back if you can do an insert on it.
Generic Eric
« Reply #7 on: January 23, 2015, 11:40:26 pm »
I went for one.  If it can do what I want, I'll get more.
I'll be sure to give an update when it arrives from the slow boat.
Estimated delivery: Thu. Feb. 12 - Fri. Mar. 20
« Last Edit: January 23, 2015, 11:42:33 pm by Generic Eric »
« Reply #8 on: January 24, 2015, 12:59:29 am »
Awesome, you are the man.  :cheers:
Some things are worth the wait.
keilmillerjr
  • Web Developer.
« Reply #9 on: January 24, 2015, 06:33:07 am »
I applied vinyl from slammedniss to the plunger of my Seimitsu ps14kn's. It was cheap, easy to apply, and they look great. I'd go with the vinyl route.
http://forum.arcadecontrols.com/index.php/topic,130477.0.html
« Reply #10 on: January 24, 2015, 11:07:06 am »
I used those square buttons for the view buttons on my first driving cab.  Also used the rectangular version for coin buttons.
The top part of the button is clear and snaps onto the base with a removable flat insert in between.
Easy peasy to stick a piece of paper in there or apply a decal to the insert.
The insert being removable also makes it easy to trim the label to size.
For the square exit button on my nephew's cab, I masked off an X then spray painted.
Knowing what I know today, I'd use Avery 18665 full sheet clear labels for everything.
Only thing of note that I can think of is that the colored rectangular ones I bought sometimes had white inserts and sometimes had color matched inserts.
EDIT: These were done using the avery labels.  Note the use of color on the xbox button.  The rest were left clear except for the letter.
« Last Edit: January 24, 2015, 11:15:48 am by BadMouth »
bchiarmonte
  • Last login:November 05, 2016, 03:51:33 pm
« Reply #11 on: January 24, 2015, 08:55:54 pm »
I have a couple of these around that have been sitting in my parts bin from a grab bag I bought off of Bob Roberts when I did my first cabinet almost 15 years ago.
I don't have a pic of the lamp holder that the switch attaches to but you get the idea. I bet many of them work like this. The little cap pops off of the plunger after you remove it from the housing.
Generic Eric
« Reply #12 on: January 24, 2015, 10:52:00 pm »
Man...the bezel looks huge on these.
Generic Eric
« Reply #13 on: January 25, 2015, 05:38:28 pm »
Thanks for the replies everyone.
If anyone is interested in my exploits, I also bought the following item from ebay "Arcade Game DJ Rectangle Rectangular Push Button LED Lighted Switch Lamp White"
« Reply #14 on: January 25, 2015, 09:15:03 pm »
The one in the original pic you posted has a removable collar that does make for a thick bezel.
You can mount the button without it, but the catch is that you have to cut out a square hole instead of your standard 1-1/8" round hole.
It has to be fairly precise, as there isn't much overhang IIRC.
Generic Eric
« Reply #15 on: February 01, 2015, 06:10:37 pm »
I got my buttons.  Its cold here, so I'm gonna let them acclimate before I start to pry them apart.  Anyway, I ordered a rectangle shortly after the square so they sent them together.
They will work for one of the projects I want to do, but probably not the other.
« Last Edit: February 06, 2015, 03:22:00 pm by Generic Eric »
Generic Eric
« Reply #16 on: February 06, 2015, 03:22:09 pm »
OMG these twist buttons are so sweet!
Which glue would a person use to attach something to the button?  Say I wanted smaller button?  Testor's?  Gorilla?  2 part epoxy?  Who made those buttons with the thin disc of plexi illuminated?  Anyone remember that thread?
« Reply #17 on: February 06, 2015, 04:02:11 pm »
You want a smaller button attached to the big button?  Or you want to convert the big button into a smaller button?
They make smaller buttons like that for video lottery terminals, but they're harder to find.
Generic Eric
« Reply #18 on: February 06, 2015, 04:21:24 pm »
Ya
I want a smaller square.  I'll watch for those lottery buttons.  I'm just trying to stay away from mouser without a part number.
« Reply #19 on: February 06, 2015, 04:32:03 pm »
Generic Eric
« Reply #20 on: February 06, 2015, 04:42:18 pm »
When you put it that way, you make it sound like a ridiculous idea.  I'm just gonna keep looking for a smaller button, thanks.
