Author Topic: Just a quick THANK YOU to DaOld Man!  (Read 11428 times)
BorgDog
« on: January 20, 2015, 09:53:08 pm »
Thanks!   :notworthy:  I've been reading through a lot of threads on setting up some automated workings, in specific a servo run monitor rotation.  Following your advice and using your wonderful startcom MaLa plugin I have my micro Maestro controller telling my Hitec servo to rotate to the correct orientation at the start of each game.  I believe I now have the hard part working, I just need to build the rest, only have it sitting on the table at the moment  but was so tickled that I got it to work I had to post something!  Thanks also to everyone else who posted their servo projects without those threads I wouldn't even have known to try this and be having this much fun  :applaud:  I've attached my little batch file (name changed to .txt so could upload) just in case anybody cares.
Already started the build thread   http://forum.arcadecontrols.com/index.php/topic,143354.0.html
Edit:  I've updated the servo.txt file so it now has the correct parameters (at least for my setup) and has an acceleration parameter to slow the servo down a bit.
« Last Edit: January 25, 2015, 11:15:25 pm by BorgDog »
My Projects:
  • Last login:Yesterday at 06:56:46 pm
Re: Just a quick THANK YOU to DaOld Man!
« Reply #1 on: January 20, 2015, 10:11:11 pm »
You are welcome, my friend.
Im glad you found startcom useful, and Im looking forward to seeing your project complete!
  • Last login:January 01, 2026, 05:29:50 am
« Reply #2 on: January 21, 2015, 12:26:28 pm »
 :notworthy:  :notworthy:  :notworthy:
I would not have bothered with automation if it weren't for DaOld Man's Mala plugins.
TopJimmyCooks
« Reply #3 on: January 21, 2015, 07:03:04 pm »
Hear hear.  My rotator setup is still going strong and I literally haven't opened the hood in years.
Old Man(s) rule.
darthpaul
  • Last login:December 20, 2025, 07:32:11 pm
  • Join, It's your duty
« Reply #4 on: February 15, 2015, 11:50:52 am »
If it weren't for DaOld Man,I would have had a nice simple working arcade cabinet but what fun is that  ;D
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
