Author Topic: Help with wiring power to CPU  (Read 1552 times)
Deteacher
  • Last login:August 31, 2014, 08:30:24 am
« on: July 04, 2014, 04:56:48 pm »
I just upgraded the computer in my MAME cab.  The old computer was the old AT style motherboard.  The new one is ATX.  On the old computer, the power switch (momentary switch) was patched in on the motherboard.  The new one (Dell Optiplex 740 Enhanced) does not have the old style power pins on the motherboard.
Can I just connect the wires from the power button directly into the 20-pin PS plug?  If so, what pins to I connect the power button to?  Or, is there another way to wire this up?  Sorry for being such a noob, but I hate having to reach around the back to turn the machine on...would much rather use the power button I have installed.  :)
Thanks in advance.
Pete.
Typefighter01
  • Last login:February 27, 2026, 07:24:12 pm
  • Back I guess...
Re: Help with wiring power to CPU
« Reply #1 on: July 04, 2014, 10:05:08 pm »
There is probably a few different ways to wire this up.
First, if your cabs power button is switched, not momentary, you could splice into the green wire that goes from the PSU to the motherboard as the green wire is usually PWR_ON. Be careful though as Dell is famous for having proprietary pin outs on their PSU's, so it could be grey or purple. Having said that, just connecting the wire with everything else turned on, might not force it to send power.
If that doesn't work, hop in the BIOS and look under the system or power options and look for a setting that says something like "Turn on when power is sensed or restored" or "Return to original state after power loss". This way, you could add a switch from your incoming power (from your house, before PSU) and just turn everything off and once you turn it back on, computer will turn it self on. Only problem with this is the OS is not following proper shutdown sequence and could cause damage.
If your cabs power switch is momentary (which from the description of your post, it probably is), pop the front off of your Dell and splice into the front mounted power button. From the pictures online, it looks like it has a front mounted power button, so there is no reason you can't splice into it. *Some google flu reveals that the power button might not have a wired connection to mobo at all, it is a plastic arm the presses a button on the board itself*. I think there is a daughter board hiding behind the front cover that houses power button/LEDs/USB/mic and earphones making it harder to pinpoint the correct wires to short out.
Just throwing out some ideas, let us know what you come up with...good luck.
Deteacher
« Reply #2 on: July 05, 2014, 08:21:58 am »
Thanks for the response.  I currently have the AC Recovery set to "on" so all I have to do is unplug the cab from the wall.  Plugging it back in brings it back to life.  It works, but I don't like the idea of not shutting down the normal way.
I'm going to try splicing into the 20-pin jack first.  Next (and hopefully last) question.  Do I twist both wires together and splice them into the green "POW-ON" line, or do I splice one into POW-ON and one into a GND line?
If this doesn't work, I'll try your third option.  I saw the daughter board for the power and USB, but it's a pain to work with.  So that will be my last resort.
Thanks much!
jaharr01
« Reply #3 on: July 05, 2014, 11:15:23 am »
Take a paper clip and short the green wire with one of the black wires ( as said above may be purple or grey but prob green) to test it. If that turns it on then solder a jumper to those two wires.
