Author Topic: Driver Bartop - Sega Outrun Style - DONE!  (Read 97334 times)
Re: Driver Bartop - Sega Outrun Style
« Reply #160 on: August 13, 2014, 03:29:15 pm »
To address the concerns about the pedals not being analog, learn as much as you can about how to set these controls up in MAME.
You'll want to adjust the "digital" options under analog controls in MAME's in-game controls menu.
"digital speed" will change how fast the virtual pedal is depressed when you press the button.
Adjust it correctly and the car won't squeal the tires and lose time every time you take off.
"digital centering" will change how fast the virtual pedal returns to its resting state when you release the button.
It's not as optimal as an analog pedal, but when set properly it's better than instant on/off.
Like most things concerning analog controls in MAME, this will need to be done for each game separately if you want the best experience.
johnrt
« Reply #161 on: August 13, 2014, 03:34:25 pm »
Interesting! I'll sure look into that. I'll soon have the cab up'n running (without artwork though, but still), so I will experiment with that. Thanks for the tip!  :cheers:
johnrt
« Reply #162 on: August 14, 2014, 03:10:47 pm »
Back lid plywood applied and adapted.
And hinges mounted:
Glued, screwed and fillled. Next is sanding and perhaps more filling.
And tomorrow my HAPP marquee retainers arrive!
« Last Edit: August 14, 2014, 05:31:02 pm by johnrt »
johnrt
« Reply #163 on: August 15, 2014, 04:31:02 pm »
Back lid. Lock and fan grill mock-up. Still needs some sanding, filling and primer.
Marquee retainers testfit.
« Reply #164 on: August 15, 2014, 04:42:04 pm »
looking good!
johnrt
« Reply #165 on: August 23, 2014, 04:48:11 pm »
Today I started on the circuit for the ONE View-button I have on the CP. Instead of having up to 4 View-buttons, this circuit makes it possible to step through the different views. Circuit is made of CMOS circuits 4093 (NAND Schmitt-Trigger) and 4017 (Decade counter).
I need the outputs to be an impulse instead of always on. Suggestions?
« Last Edit: August 23, 2014, 04:57:30 pm by johnrt »
  • Last login:Yesterday at 06:48:03 pm
« Reply #166 on: August 24, 2014, 01:12:13 am »
Not sure about the schematic for your circuit, but you might be able to use the button press to also provide power to a 4 pole (4PST or 4PDT) solid state relay. (each LED represents one encoder input, right?)
Each press of the button should close the relay longer than it takes for the counter circuit to advance.
When the button is released, the relay opens.   :cheers:
If the relay and counter circuits interfere with each other, use the button to drive a 2 pole relay with the 4 pole relay power on one pole and the counter circuit on the other.
johnrt
« Reply #167 on: August 24, 2014, 07:25:27 pm »
PL1: I think I nailed it.
This is the circuit (a pencil drawing):
With this the output stays connected as long as the button is pressed, so the outputs is an exact copy of the keypress!
Here's a video: Note that the outputs is inverted in this video. The BC557 PNP transistors will invert the outputs back to normal again. The relays will be small reed relays:
Link to reed relays: https://www.elfaelektronikk.no/elfa3~no_no/elfa/init.do?item=37-462-04
« Last Edit: August 24, 2014, 07:42:19 pm by johnrt »
« Reply #168 on: August 25, 2014, 04:41:55 am »
As long as the circuit driving the LEDs can drive the relays, it should be fine.   :notworthy:
johnrt
« Reply #169 on: August 27, 2014, 03:42:35 pm »
I haven't forgot everything I've learned during my electronic education quite yet. This is the PCB for my 3/4-way sequential View-button:
« Last Edit: August 28, 2014, 06:39:14 am by johnrt »
Superfrog
    • My YouTube Channel
« Reply #170 on: August 27, 2014, 04:41:42 pm »
 :banghead: good god, I can read some things, bud I can never build something like this on my own  :dizzy:
Always nice to see that people who can do these things  :cheers:
BGoulette
    • lazerjoose.com
« Reply #171 on: August 28, 2014, 12:11:51 am »
I can't read any of the things :( I'd love to be able to throw together some of these electrical thingies...
TheDude
  • Bartops all the way !
    • BARTOPMANIA
« Reply #172 on: August 29, 2014, 03:43:01 am »
This bartop never fails to impress me so far ! Impressive skills and a very orginal execution !  :notworthy:
johnrt
« Reply #173 on: August 29, 2014, 04:06:56 pm »
A little update:
Marquee LED strip mounted:
And tested:
Modification rig for the lower marquee retainer:
The final result marquee-wise:
Another shot:
By using the shortest cables possible...
...we get a really tidy setup:
The back lid is also painted:
And here's the final schematic for the 3/4-way sequential View-button:
johnrt
« Reply #174 on: August 29, 2014, 04:38:44 pm »
Ï have also acquired an original Sega Outrun! Everything on it works, but it needs some tender care. Something to do when winter arrives:
And here's the original side by side with the little bartop. Is this cool or what?  :lol
BGoulette
    • lazerjoose.com
« Reply #175 on: August 29, 2014, 04:54:50 pm »
The way the curves match (at least in your photo!) is beyond awesome. Excellent job!
Superfrog
« Reply #176 on: August 29, 2014, 05:16:44 pm »
Awesome  :notworthy:
Bud you really have to hurry, because I can't stand any longer til I finally can see the outcome of this beauty  :censored: :censored: :cheers:
johnrt
« Reply #177 on: August 29, 2014, 05:24:46 pm »
There's actually not much work left on it. I will order the PCB for the view-button by tuesday, and then I only miss the artwork. This I will test during this weekend, and hopefully order it within next week. I already got the T-molding, buttons, PC, HDD, PSU and encoder (in fact everything). The T-molding will be applied AFTER the artwork. I also can't wait to finish this!
And now I'm thinking of selling my Fix it Felix cab. I would give it away to the childrens hospital if it weren't for the legal issues (ROM-wise). :-P
johnrt
« Reply #178 on: September 02, 2014, 06:10:31 pm »
Today I've done some wiring. I think this will be the tidiest cab I've ever done wirng-wise. Here's shot from the front:
Prepared power for marquee, audio amplifier and my view-button circuit. The power is 12V from the PC PSU.
Loudspeaker cables:
Audio amplifier:
Even the power for the monitor is from the PC PSU (And yes, it works):
johnrt
« Reply #179 on: September 04, 2014, 01:01:35 pm »
Video coming later this evening!
Testing of artwork:
From the front:
From behind:
From behind with back lid opened:
How do you guys like my bottom base?  :lol
Superfrog
« Reply #180 on: September 04, 2014, 01:56:54 pm »
 :applaud: Very nice.
Only two things my eyes can't stand  :angel: the Sega logo in the marquee.. if you make it a little bit smaller, it won't hit the marquee holder.
And the graphics of the cp is not fitting the nice side and marquee artwork  :dizzy:
Maybe you can skip it and try something new  :cheers:
Back and inside ware very slick and clean  :cheers:
johnrt
« Reply #181 on: September 04, 2014, 03:09:54 pm »
About the Sega logo, yes I see it also. That's why I try this with plain paper first to check how things turn out. And I agree: the Sega logo has to shrink or at least being moved.
The CP graphics: This is based on the map from the original cabinet. But since I suck that much on the artistic level I don't have anything else to show. I DO welcome any artwork suggestions!  :lol Nothing is 100% decided yet artwork-wise.
johnrt
« Reply #182 on: September 04, 2014, 03:40:20 pm »
And here's another video of the project. It's slowly getting there.
  • Last login:March 10, 2026, 12:46:21 pm
« Reply #183 on: September 04, 2014, 03:51:49 pm »
Excellent. :cheers:
markc74
  • Last login:March 08, 2026, 11:25:45 am
  • Flipping out
« Reply #184 on: September 04, 2014, 05:05:01 pm »
VERY nice. Loves that profile and the artwork.
johnrt
« Reply #185 on: September 08, 2014, 11:26:09 am »
Yesterday I went by a flee market and found this. A fully working Microsoft Sidewinder USB racing wheel and pedals. For this I paid 20NOK, that is 2.50 Euro or 3 USD. Maybe I'll use the pedals on my bartop.
Superfrog
« Reply #186 on: September 08, 2014, 12:02:45 pm »
Why not the whole wheel  >:D
05SRT4
  • Check out my Pow Pow
« Reply #187 on: September 08, 2014, 08:39:21 pm »
Do you get any noise feedback from having the PSU hooked up to everything?
johnrt
« Reply #188 on: September 09, 2014, 03:13:35 am »
No, I'm using a ground loop isolator:
http://www.ebay.com/itm/260741338139
05SRT4
« Reply #189 on: September 09, 2014, 05:16:47 am »
Awesome, thanks for the info and link!!
Superfrog
« Reply #190 on: September 11, 2014, 05:18:12 pm »
John,
How long do you have to Soaking the plywood in the water and let it dry in the shape you want?
I'm thinking of using that Technic for my next project.
Will it stay in the position when it's dry, or did it want to go back a little in the original form ?
Thanks :cheers:
« Reply #191 on: September 11, 2014, 11:56:28 pm »
Looking good johnrt  :cheers:
I like the SEGA logo up top.   >:D
If anything, I'd make the Outrun Logo bigger, but it doesn't look bad as it is now.
That thing is from before the time dinput force feedback was standardized.
The force feedback won't work on anything but some very old games that were designed specifically for it.
The original Logitech Formula Force is the same way.
johnrt
« Reply #192 on: September 13, 2014, 04:35:56 pm »
John,
Sorry for the late reply. I'm currently in a hotel room in San Francisco.
I soaked the plywood for about half an hour. And it will stay in that position. It didn't go back at all in my case.
Generic Eric
« Reply #193 on: September 13, 2014, 11:26:07 pm »
I promise I tried to find the answer:  Who think is that plywood?  Only half an hour?  :shazzle:
« Reply #194 on: September 14, 2014, 10:31:56 am »
This totally needs a mini base with wee pedals at the bottom, built so you play it sitting.  Looking awesome!
johnrt
« Reply #195 on: September 16, 2014, 12:31:06 pm »
So while I was away in SF the PCB for my Sequential View-button circuit arrived. It look very professional!
And the finished result just missing the screw terminal (which I don't have yet):
And I also received some more short cables, this time for the audio amplifier:
« Last Edit: September 16, 2014, 01:49:47 pm by johnrt »
« Reply #196 on: September 16, 2014, 04:57:04 pm »
There is just too much awesomeness going on in this thread.  :cheers:
« Reply #197 on: September 16, 2014, 06:18:44 pm »
Maybe I missed it, but where did you order your PCB from? I think this is all sorts of awesome.
johnrt
« Reply #198 on: September 17, 2014, 04:19:42 am »
The PCB is made with software from http://fritzing.org/home/
Here you'll find the necessary software and services to create your very own PCB. :-)
« Reply #199 on: September 17, 2014, 06:02:24 am »
Sweet! Thanks man!
