Author Topic: Driver Bartop - Sega Outrun Style - DONE!  (Read 97113 times)
Superfrog
    • My YouTube Channel
Re: Driver Bartop - Sega Outrun Style
« Reply #80 on: July 24, 2014, 05:25:23 pm »
I would pick the first or last one  :angel:
Bud I found this version sexy.. http://forum.arcadecontrols.com/index.php/topic,111231.0.html The outrun / GTA look  :cheers:
Take your time for picking some artwork, it could be a fail if it's not right.
Your great project NEED the have a perfect artwork at the end, to make it even better  >:D
markc74
  • Last login:Yesterday at 11:25:45 am
  • Flipping out
« Reply #81 on: July 24, 2014, 06:08:38 pm »
First one. By a country mile. Looks fantastic.
Something not quite right with the  'outrun' text but can't out what it is...
yamatetsu
  • Last login:Today at 10:05:51 am
  • Just because.
« Reply #82 on: July 24, 2014, 10:59:48 pm »
"Something not quite right with the  'outrun' text but can't out what it is..."
Maybe it should be tilted like in the third pic ?
I also like the first one best, except for the inconsistencies. This obviously consists of three parts, the sky in the middle and the lower part
looks a little bit different, there's a cut-off cloud under the 'R' and the palm tree leaves on the left are chopped.
Also, if I'm not mistaken, the rightmost mountain has the top of a palm tree growing out of it.
You may not notice these things in a screen-size picture, but if you print it full size ...
TheDude
  • Bartops all the way !
    • BARTOPMANIA
« Reply #83 on: July 25, 2014, 02:25:18 am »
I prefer the last one, for all it's worth.
Impressive work on this bartop. Great quality build !  :applaud:
Superfrog
« Reply #84 on: July 25, 2014, 09:17:04 am »
I did see that also.
Specially the chopped pictures is a bummer if you don't redo that before printing.
Dud I can imagine that's just a quick  mock-up for testing what direction you will go  :cheers:
johnrt
« Reply #85 on: July 25, 2014, 09:27:03 am »
Yes, everything artwork-wise is just mock-ups for now. I need the artwork to say: "YES, THIS IS IT!" before sending it to printing.
« Reply #86 on: July 25, 2014, 10:15:02 am »
can you give me the dimensions of the side art (or an exact size template?)  same goes for the CP.
I'd be happy to try and whip something up for you
johnrt
« Reply #88 on: July 25, 2014, 10:21:21 am »
got em. was hoping you'd have the striped one to work off of for the CP.
Im going to try and keep it as outrun-ish as possible
Yvan256
    • Yvan256
« Reply #89 on: July 25, 2014, 10:23:48 am »
Two things:
I prefer this one by far.
What buttons are those, with the very-low-profile switches?
johnrt
« Reply #90 on: July 25, 2014, 10:25:05 am »
Yvan256: These are goldleaf buttons from Ultimarc:
http://www.ultimarc.com/goldleaf.html
Malenko: I din't make that striped CP. But it's just PP modified. The original is here: http://vectorlib.free.fr/PolePosition/
« Last Edit: July 25, 2014, 10:28:14 am by johnrt »
Yvan256
    • Yvan256
« Reply #91 on: July 25, 2014, 10:32:30 am »
Thank you. I should have recognized those.
johnrt
« Reply #92 on: July 25, 2014, 01:22:32 pm »
I would really appreciate if anyone of you could help me a little with the artwork. I'm not good at this. It's almost like this is my artisitic level:
« Last Edit: July 25, 2014, 01:25:44 pm by johnrt »
« Reply #93 on: July 25, 2014, 01:24:02 pm »
Im finishing up some commissioned work but I'll try to poke around with it
johnrt
« Reply #94 on: July 25, 2014, 01:40:50 pm »
« Reply #95 on: July 25, 2014, 01:43:43 pm »
do you have a name for the cab or is it going to just have an OutRun Skin ?
johnrt
« Reply #96 on: July 25, 2014, 01:49:34 pm »
No, I don't have a name for it. The OutRun theme/skin is enough for me. Allthough I'm wide open for suggestions.
johnrt
« Reply #97 on: July 25, 2014, 01:54:12 pm »
Ouch!
The marquee template size is wrong! Download it again to get the right size! It's width is 40cm NOT 50cm!
gbeef
    • arcadepix.com
« Reply #98 on: July 25, 2014, 05:46:37 pm »
+1 for outrun also..... lol. If i were to goto back daytona usa would be second choice.
great build so far. Art can make or brake the cabinet, you got some good side choices going on, i would revist the cp.
My cabs
4 Player Arcade
X-men Arcade Remixed
johnrt
« Reply #99 on: July 27, 2014, 11:02:11 am »
Today I've been working on the back and upper marquee area.
I have mounted the battens:
And fabricated some other wooden parts:
Tested with 4mm plywood:
This is how big the lid will be.
Some experimenting with ventilation holes (this one I did not like):
Soaking the plywood:
I'm using the house itself for bending it:  :lol
« Last Edit: July 27, 2014, 01:16:39 pm by johnrt »
johnrt
« Reply #100 on: July 28, 2014, 02:58:30 pm »
The bent plywood did fit like a glove. It''s now glued on. But I made a mistake: I forgot to make the ventilation holes! Well, I have to make them anyway, only now I have ONE try.  :banghead:
The back lid panel was bent too much, so I have to make a new one.
Inside the marquee area:
The fan I'm gonna use. Btw: I'm a big fan of this fan!  :lol
First coat of primer revealed some imperfections on the surface, as expected:
« Last Edit: July 28, 2014, 06:04:05 pm by johnrt »
johnrt
« Reply #101 on: July 29, 2014, 01:58:46 pm »
Today I started on the back lid. First I made a template for the ribs:
Using 18mm plywood I then cut the ribs a little to big. The rest was a job for the router.
I screwed the pieces together. And screwed the whole thing to a scrap piece of plywood prior to routing it.
The result: 4 exact copies.
And the structure for the back lid is almost ready:
« Last Edit: July 31, 2014, 11:03:23 am by johnrt »
johnrt
« Reply #102 on: July 30, 2014, 04:30:44 pm »
Today I only did some priming and sanding. The result so far:
And the curved back is getting smooth!
  • Last login:March 06, 2026, 05:17:37 pm
« Reply #103 on: July 30, 2014, 05:11:11 pm »
Looks amazing. :cheers:
Superfrog
« Reply #104 on: July 30, 2014, 05:13:24 pm »
Now the shape got even better  :applaud:
I like the curves on this one  >:D
yamatetsu
  • Just because.
« Reply #105 on: July 30, 2014, 05:38:47 pm »
Cool.
ant2
  • Last login:June 02, 2024, 07:05:47 am
« Reply #106 on: August 02, 2014, 10:26:20 am »
Looks like i'm a bit late to the party for suggestions but I think it would be good to build paddle shifters behind the wheel and then you can use one for accelerator, one for brake.
Then drill some small holes to make 2 small buttons on the wheel i.e the size of a small pad, use the logitech gt wheel for an example (one either side you can get your thumbs on) and perhaps put a button right in the center.
SpaceHedgehog
  • Almost done ...
« Reply #107 on: August 02, 2014, 10:40:58 am »
This is going to be a beauty. Very nice  :cheers:
Click a pic for a video tour
johnrt
« Reply #108 on: August 04, 2014, 02:00:36 pm »
About the ventilation holes in the back:
Today I found these on a local shop (I don't know what they are called in english):
I cut them in right sizes:
Next I drilled some holes in the back of the cab:
And the result did turn out quite nice. I want to keep these white allthough if the back is painted black. They will make a nice contrast back there.
johnrt
« Reply #109 on: August 06, 2014, 07:05:51 pm »
I'm just playing around a little with the original artwork. I have simplified it compared to the original one. But you guys think this is a way to go?
« Last Edit: August 06, 2014, 07:46:05 pm by johnrt »
« Reply #110 on: August 06, 2014, 07:52:35 pm »
other than the chick's eyes, I really like it
johnrt
« Reply #111 on: August 06, 2014, 08:34:28 pm »
Well. That's how her eyes looks like in the original artwork. I think they looks good!  :lol
johnrt
« Reply #112 on: August 07, 2014, 07:34:14 am »
Further work on artwork. Actually I'm quite happy with this one.
« Reply #113 on: August 07, 2014, 09:52:07 am »
Very sharp :applaud:
« Reply #114 on: August 07, 2014, 10:03:09 am »
Id lose the OutRun logo, and maybe adjust the pink on the hood to contrast a little less. I know its very close to the original, but I think it'd be better without it
johnrt
« Reply #115 on: August 07, 2014, 10:50:17 am »
Adjusted the hood color and moved the OutRun text and made it smaller.
Moved the clouds to avoid clipping them:
« Last Edit: August 07, 2014, 11:02:27 am by johnrt »
« Reply #116 on: August 07, 2014, 11:11:09 am »
thats a winner right there.
Superfrog
« Reply #117 on: August 07, 2014, 11:23:50 am »
The color correction is very nice now, bud I would go for a Bigger OUTRUN logo and a smaller SEGA logo.
It's a Outrun cabinet, so it has to be on top  :cheers:
« Reply #118 on: August 07, 2014, 11:43:56 am »
now that you mention it..... I'd move the sega logo to the top right corner. I still say lose the outrun logo, so you can name the cab something else. If youre going to make the marquee say OutRun, then keep it.
YMMV
johnrt
« Reply #119 on: August 07, 2014, 12:06:22 pm »
How about this? Now it's not that naked on the top right corner either.
