Author Topic: Kbranden's Viewlix Clone  (Read 1943 times)
kbranden
  • Last login:November 03, 2014, 04:53:39 pm
« on: June 24, 2014, 09:38:10 am »
Hey all,
I have a couple questions for you guru's out there. For starters, I have absolutely no woodworking experience but trying to build a viewlix Clone anyways.  Here is the pic of where I am at right now.
BTW - I do have the side/front beveled additions done for the control panel box, just not put on yet. So it won't look boxy like in the pic. :)
Anyways, questions.
1). What would you suggest using to fasten the marquee arc to the frame? I'm having a bit of trouble because for one I opted not to have the side opening (on the side panels) to move the TV in and out. I actually have to lose'n one of the side panels from the base to get it in from the back. So, I can't really glue it on. A straight bracket inside won't work because the curve of the arc starts too soon for it to work. I thought about either drilling holes and using dowels or finding a bracket that would go from the top to the side at a 45 degree angle (But can't really find anything out there). What would you suggest?
2) Any suggestions on who can build a good marquee. I'm not sure if I can take plexi and cut the rounded shape as well as paint it evenly enough to look good.
Thanks,
kbranden
Typefighter01
  • Last login:Today at 10:40:37 am
  • Back I guess...
Re: Kbranden's Viewlix Clone
« Reply #1 on: June 24, 2014, 07:17:23 pm »
Not sure who could build you one, but, I have had good luck cutting plexi right on my table saw. I just make sure to lower my blade down so it just barely cuts though it and then I round my corners with a belt sander.
If you want to be sure to get nice exact corners on both sides, cut a curved template and clamp it to each corner and sand up to it, or, if you have a router and no sander, cut your template and route plexi with a flush trim bit.
As for painting it, if you are only doing one colour, it is impossible to screw up. Just remove protective film from the back, spray a few light coats until fully covered, wait till dry, install and remove front film.
Good luck  :cheers:
