Author Topic: e clip removal  (Read 7964 times)
Fonkybeachbum
  • Last login:September 27, 2023, 12:10:14 pm
e clip removal
« on: April 12, 2014, 01:04:11 pm »
hello,
I'm wondering if there's an easy method for getting the e clip off the bottom of my happ joystick.  i don't want to force it with pliers and mess something up, but i also don't feel like dropping $$$$ on an e clip removal tool either.  Any advice would be much appreciated.
« Last Edit: April 12, 2014, 01:25:49 pm by Fonkybeachbum »
Louis Tully
Re: e clip removal
« Reply #1 on: April 12, 2014, 01:14:31 pm »
« Last Edit: February 12, 2015, 05:03:31 pm by Louis Tully »
Generic Eric
Re: e clip removal
« Reply #2 on: April 12, 2014, 02:01:10 pm »
I posted a similar question.  PL is on point.  I was concerned I would bend the clip. I didn't.  I even managed to find a replacement in my sleepy town hardware store.
ed12
Re: e clip removal
« Reply #3 on: April 12, 2014, 03:19:23 pm »
the exact way i have done it for well over 30 year's
>You're close on the img embedding, it's [] [/] not ()(/)
As for the e clip, I've always had good results from a flat screwdriver and/or pliers. Grab the end opposite the opening and pull away from the stick, not up or down. If you accidentally bend it, you can bend it back. They're pretty tough.<
ed
Re: e clip removal
« Reply #4 on: April 12, 2014, 04:11:46 pm »
I always use a flat head to get it away from the stick enough to use pliers. Even if you bend it a little, when you put it back, it'll get straightened out.
matt4949
Re: e clip removal
« Reply #5 on: April 12, 2014, 09:28:47 pm »
That's exactly how I do it. I use a tiny eyeglass screwdriver. Don't do it in a dirty garage full of sawdust and wood scraps because you'll drop it for sure.
  • Last login:Today at 02:35:06 am
Re: e clip removal
« Reply #6 on: April 12, 2014, 10:10:03 pm »
Another trick is to turn an open box on it's side and drape a cloth loosely over the opening so if/when the clip shoots off, the cloth absorbs the impact of the flying clip instead of letting it ricochet off to places unknown.
Ken Layton
  • Guru
  • Technician
Re: e clip removal
« Reply #7 on: April 12, 2014, 10:25:37 pm »
Re: e clip removal
« Reply #8 on: April 13, 2014, 01:20:56 am »
The proper tool is like $2 at Harbor Freight.  Seriously.
SusanInParadise
  • Last login:August 01, 2017, 03:16:34 pm
    • Paradise Arcade Shop
Re: e clip removal
« Reply #9 on: April 13, 2014, 07:33:52 am »
I always use a small flat swcrewdriver....works like a charm.
Thenasty
  • Last login:Today at 02:42:00 pm
Re: e clip removal
« Reply #10 on: April 14, 2014, 01:02:37 pm »
No one ever tried to use Teeth ?
I think I used my teeth once (I was drunk)  :banghead:
Now  I use tiny flathead screwdriver.
Free VGA Breakout Cable
Fonkybeachbum
Re: e clip removal
« Reply #11 on: April 14, 2014, 03:06:54 pm »
I finally got that sucker off.  Even my smallest flat head couldn't get into the recessed area.  Might pick up a cheapo tool or a tiny flat head for the next time, but once I got a piece of metal into it, it came off relatively easy.
Re: e clip removal
« Reply #12 on: April 14, 2014, 03:37:19 pm »
 :stupid Cheap and makes E-clips ridiculously easy.
