Author Topic: Mario Pedestal. Finished. Better video added showing turning accuracy with PiP.  (Read 127368 times)
Re: Mario Pedestal. Pretty much all built. Now I've got to fancy it up.
« Reply #160 on: May 25, 2014, 09:23:47 am »
I didn't like anything about this idea until now.  Looking good.
It's the kid in the box that does it amiright? Be honest.  >:D
ChanceKJ
« Reply #161 on: May 27, 2014, 08:18:26 pm »
I feel like I need to mail pbj a fire extinguisher. ;D
Love it LT,  screw using "crunchy" sounding Velcro when it gets a little weight on it. Use inset rare earth magnets like the ones I was gonna use for my marquee on Flynn's.
Slippyblade
« Reply #162 on: May 27, 2014, 08:41:15 pm »
Schrodinger's Child?
Louis Tully
« Reply #163 on: May 28, 2014, 05:12:42 am »
« Last Edit: February 12, 2015, 04:41:49 pm by Louis Tully »
« Reply #164 on: May 28, 2014, 05:53:54 am »
Wanted dead and alive!
ChanceKJ
« Reply #165 on: May 28, 2014, 11:57:16 am »
Boooo! Get the hook!
Louis Tully
Mario Pedestal. The fake brickwork just got a lot easier.
« Reply #166 on: May 28, 2014, 05:57:08 pm »
« Last Edit: February 12, 2015, 04:42:04 pm by Louis Tully »
ChanceKJ
Re: Mario Pedestal. The fake brickwork just got a lot easier.
« Reply #167 on: May 28, 2014, 07:23:18 pm »
Now all you need to do is paint it black and get a stamp to replicate the brick look :)
  • Last login:Yesterday at 10:37:15 am
« Reply #168 on: May 29, 2014, 04:48:12 am »
Very cool. :cheers:
Louis Tully
« Reply #169 on: May 30, 2014, 04:38:31 am »
« Last Edit: February 12, 2015, 04:42:09 pm by Louis Tully »
Louis Tully
Mario Pedestal. So many base blocks. I need some bigger clamps.
« Reply #170 on: May 30, 2014, 04:52:31 am »
« Last Edit: February 12, 2015, 04:42:16 pm by Louis Tully »
ChanceKJ
Re: Mario Pedestal. So many base blocks. I need some bigger clamps.
« Reply #171 on: May 30, 2014, 09:06:22 am »
I'd seriously consider painting.  Have a "stamp" made on a 3D printer and go from there. That or just use vinyl.
« Reply #172 on: May 30, 2014, 09:17:03 am »
make a template , just cut the black area out of a square. Paint the base blue, then use the template to paint the black area
  • Last login:Yesterday at 07:33:48 am
« Reply #173 on: May 30, 2014, 09:47:35 am »
Stencil and a spray bomb would probably give a decent brick effect.
Louis Tully
Mario Pedestal. So many base blocks. I got some bigger clamps.
« Reply #174 on: May 30, 2014, 08:34:28 pm »
« Last Edit: February 12, 2015, 04:42:31 pm by Louis Tully »
  • Last login:Today at 04:28:07 am
Re: Mario Pedestal. So many base blocks. I got some bigger clamps.
« Reply #175 on: May 30, 2014, 11:40:36 pm »
Have you looked at making a guide template with built-in stops?
Chain-drill and smooth a slot (red) the width of a Dremel bit shaft through some MDF and attach stops. (gray)
Use a #194 bit along with the attachment you showed above.
Set the Y-axis of the guide (blue) by putting the bit into position 2 of the template (Dremel switched off) and dropping it into the existing groove -- ensure that position 2 of the template matches the existing groove across the length of the guide.  (Use position 3 if you need the guide on the other side)
Set the X-axis of the template by putting the bit into position 1 of the template (Dremel switched off), dropping it into the existing groove, and clamping the template in place.
Trace through the template in numerical order.
If the template pattern is the right size, the bit will be in the existing slots at each numbered position, allowing you to switch the Dremel off when raising/lowering the cutting part of the bit through the template slot at the start and end of each stone block.   ;D
EDIT: Change to the template shown below -- extended the top and bottom gray pieces so you can clamp them to the blue piece as shown.
« Last Edit: May 31, 2014, 01:24:45 am by PL1 »
ChanceKJ
« Reply #176 on: May 31, 2014, 12:12:11 am »
That, could, work!!
I was about the say: "Yeah, just paint it. When do you ever see those blocks in 3D?", but who gives a crap if you can pull off that jig!!
« Reply #177 on: May 31, 2014, 01:42:43 am »
I've got to wait on cutting the brick pattern until I get those square LED buttons. I guess I'm going to order from Suzo
http://na.suzohapp.com/gaming_products/pushbuttons/D54-0004-31  or   http://na.suzohapp.com/gaming_products/pushbuttons/57-0004-31
Kinda leaning toward the low profile
Any reason you're not ordering them from Divemaster here?
$4.94 ea (DM) vs. $8.50 ea. (Happ) for the large square low-profile buttons.   ;D
Louis Tully
« Reply #178 on: May 31, 2014, 04:17:00 am »
« Last Edit: February 12, 2015, 04:42:43 pm by Louis Tully »
JDFan
« Reply #179 on: May 31, 2014, 07:56:54 am »
If you just need a couple buttons Le Chuck had a few for sale at $2@ in the BST thread !
Louis Tully
« Reply #180 on: May 31, 2014, 08:35:45 am »
« Last Edit: February 12, 2015, 04:42:47 pm by Louis Tully »
Louis Tully
Mario Pedestal. Base block pattern.
« Reply #181 on: May 31, 2014, 08:59:33 am »
« Last Edit: February 12, 2015, 04:42:56 pm by Louis Tully »
ChanceKJ
Re: Mario Pedestal. Base block pattern.
« Reply #182 on: May 31, 2014, 11:00:09 am »
This is so awesome!
« Reply #183 on: May 31, 2014, 03:45:39 pm »
I'm still on the fence. The low profile one looks pretty sweet and I like it but the regular large square button has more height on the lens and that could make the ? block look a little better, pop out a little more. I'm just nitpicking over items I've never seen in person. Honestly, I kind of need 1 of each so I can put them in place and see which fits best.  :-\   I probably have to order a set of each and use the remaining buttons for a future project or something. Pictures online only help so much.
PM Gary the part number/description for the regulars and ask him if he has any in stock -- if not, he can probably get them fairly quickly from his distributor.
+1 on ordering a set of each from him and saving on shipping.
I almost gave up on this idea because ever bit I tried to use was cutting into the template. So I thought about it and since MDF is easy to scrape, why not flip the bit around and just let the friction wear it down? It keeps the bit from eating away at the metal and it actually worked.  :lol
The idea is to keep the cutting surface below the metal template so the smooth shaft of the bit traces the outline.  ;D
Add some 1/4" plywood under the metal template and you'll have a little more wiggle room for the cutting surface of the bit between the MDF and the template.
  Template                Bit
metal template |  smooth shaft
1/4 plywood    |   wiggle room for smooth shaft and a bit of cutting surface
MDF                 |   cutting surface
Thank you PL1.  :cheers:
Always glad to assist.    :cheers:
Keep up the outstanding work.
« Last Edit: May 31, 2014, 03:53:59 pm by PL1 »
AlienInferno
« Reply #184 on: May 31, 2014, 11:46:38 pm »
Dude that looks great!  Gonna be awesome once it's painted.
« Reply #185 on: June 01, 2014, 12:21:03 am »
That brick is brilliant just brilliant.  :applaud:
thatpurplestuff
« Reply #186 on: June 01, 2014, 12:56:39 am »
That is going to look amazing painted!  Great stuff!
« Reply #187 on: June 02, 2014, 08:55:37 am »
I'm loving this!  Also, I heard you need buttons...
CoryBee
  • Bopity Boopy
Re: Mario Pedestal. Pipes are cut and in place for a test fit.
« Reply #188 on: June 08, 2014, 11:32:07 pm »
Louis, my man, I'm nominating you for the 2014 CoryBee Memorial BYOAC Award For Innovation and Thrift. Great job!
 :afro:
What happened to the Bee anyhow, he leave with old Maximus?
Sweet build Louis!!!!
He's still gallivanting across the European countryside as far as I know. We spoke through PM back in the beginning of March. I asked him if he could work his flash game magic on Kaboom for me, the way he did with the Helicopter game. He said he'd be happy to take a look at it once he's back in the US. Said it'd be a few months.
:dunno  He should be popping back up sooner or later. I bet he's dying to build something. He'll have something cool in the works, no doubt. He's an addicted builder like the rest of us.
Bugggutty Booo!
I'm back in California, 8 months or something like that abroad. Had a lot of fun. Been here 4 days now.
Glad to be missed  :laugh:
I hope to build something, rented a place up in North Lake Tahoe for the next couple of months but will be up and down from Sacramento to there so maybe I can squeeze in a build. I fixed up and beffed up the battery on a power wheels for my nephew so there's something!
I will be going back to Europe in a few months as well, started an eBay business and it has been working out for me so no need to have roots anywhere.
On the subject of this man's build;
FUDKIN BADARSSE. Love the details with the bricks! Thinking out side the box.
Bookmarked.
« Reply #189 on: June 09, 2014, 03:50:46 am »
Welcome back, bro.   :cheers:
Louis Tully
« Reply #190 on: June 09, 2014, 04:14:07 am »
« Last Edit: February 12, 2015, 04:43:13 pm by Louis Tully »
ChanceKJ
« Reply #191 on: June 09, 2014, 05:11:50 am »
...so much for calling dibs on his stereo.
 :dunno
CoryBee
  • Bopity Boopy
« Reply #192 on: June 09, 2014, 11:53:05 pm »
 :dunno
HEYYYYYOOO
Sold that to Maximus a while back
Tully, this is some really good work brother.
Also, is awesome
Did I miss any really cool builds on here? (besides this one of course)
« Reply #193 on: June 09, 2014, 11:55:13 pm »
Forget that - tells us your ribald tales of laying your way across Europe in a puffy shirt!
CoryBee
  • Bopity Boopy
« Reply #194 on: June 10, 2014, 12:00:21 am »
You know how it is, ladies can't keep their hands of me;
ChanceKJ
« Reply #195 on: June 10, 2014, 12:11:52 am »
Found a few of these did ya?
Louis Tully
« Reply #196 on: June 10, 2014, 05:39:25 am »
« Last Edit: February 12, 2015, 04:43:32 pm by Louis Tully »
Louis Tully
« Last Edit: February 12, 2015, 04:43:40 pm by Louis Tully »
jdbailey1206
« Reply #198 on: June 10, 2014, 06:39:02 am »
"I don't wanna be a pirate!"
Good to see you back CoryBee.
LT - Those brick patterns look really slick and clean.  Keep at it.  It will be worth it in the end.
ChanceKJ
That looks legit! Carving these was definitely the right way to go.
