Author Topic: Mario Pedestal. Finished. Better video added showing turning accuracy with PiP.  (Read 129149 times)
Louis Tully
« Last Edit: February 12, 2015, 04:52:10 pm by Louis Tully »
Generic Eric
That is cool.  I think you should pursue it.  Also, I had no idea you could flick the controller like that.
Would you make it look like the arcade release of Mario Kart Arcade GP?
kixfan
  • Last login:May 22, 2018, 06:59:26 pm
Me neither!
Louis Tully
« Last Edit: February 12, 2015, 04:52:16 pm by Louis Tully »
Louis Tully
« Last Edit: February 12, 2015, 04:52:34 pm by Louis Tully »
jmike
 :applaud: :applaud:
    Loving this project so far.
That's some sweet drifting action you got going on there LT.
Can you post some more pics on the bracket you used to attach the wheel?
« Last Edit: March 14, 2014, 06:55:45 am by jmike »
Try out Crusin`   I never could steer well in that game holding the wii mote sideways, I ended up driving with the Dpad.
Louis Tully
« Last Edit: February 12, 2015, 04:52:50 pm by Louis Tully »
Louis Tully
« Last Edit: February 12, 2015, 04:53:07 pm by Louis Tully »
Louis Tully
« Last Edit: February 12, 2015, 04:53:18 pm by Louis Tully »
driving games seem better when siting, so why not little things that sit on your lap? Like the padded things for laptops, only this time wii-eel (wheel /pun) mounts. You could then still drive sitting in front of a bigger TV
just spit ballin ideas.
Generic Eric
Maybe one of those kids color tables.  Seems like a difficult task with the flip action.
I love your creativity in general, Louis, but I don't think anyone could make this work and not look like an afterthought bolted onto a file cabinet. Sorry.  :cheers:
Genius!!
The older I get, the more I want to get rid of clutter and simplify things.
Yeah... let me know how that works out for ya  ;D
mattgold
  • Tinker 'till it's right...
Just my .02... but it looks like a filing cabinet.  With a monitor on top of it.
  • Last login:Today at 03:27:55 pm
Sorry, LT.
While you may think you have vision on this filing cabinet thing, I suspect that Le Chuck's Mom would disagree.
« Last Edit: April 05, 2014, 01:06:58 am by PL1 »
DGP
  • Gamer4Life
    • My Toys...
Sonic Racing Transformed is much better than the first Sonic racing game. ;)
Jason
Louis Tully
« Last Edit: February 12, 2015, 04:53:41 pm by Louis Tully »
Louis Tully
« Last Edit: February 12, 2015, 04:53:47 pm by Louis Tully »
Louis Tully
Wii Mario Kart..project. Appreciate the input fellas. Opinions again?
« Reply #20 on: April 05, 2014, 11:10:48 am »
« Last Edit: February 12, 2015, 04:54:06 pm by Louis Tully »
jdbailey1206
Re: Wii Mario Kart..project. Appreciate the input fellas. Opinions again?
« Reply #21 on: April 05, 2014, 12:35:51 pm »
LT - Going through your builds in my head one word comes to mind.  Simplicity.  This one just seems forced.  Its a great idea but I think you are just trying to make it work.  I think you should keep at it but let it create itself like your other builds have.
Louis Tully
« Reply #22 on: April 05, 2014, 01:22:21 pm »
« Last Edit: February 12, 2015, 04:54:12 pm by Louis Tully »
« Reply #23 on: April 05, 2014, 04:28:07 pm »
How about a tilt-out wheel design?
CP (green) is hinged at the back so you can lift it and tilt the wheel forward.
« Reply #24 on: April 05, 2014, 05:19:39 pm »
if we're just thinking of ways to mount them seamlessly, why not just giant magnets under the CP. Make the Wii wheel rig, put a magnet on the bottom of that. unless you drive angry, it should suffice.
DGP
  • Gamer4Life
    • My Toys...
« Reply #25 on: April 06, 2014, 05:21:40 am »
"I'll have to take your word on that. I don't have a Wii U."
Neither do I, we play it on the pc.
I was not aware this project was wii only, sorry. ;)
Jason
Louis Tully
Pedestal. Formerly the Wii Mario Kart..project. Keep it simple.
« Reply #26 on: April 06, 2014, 06:43:05 am »
« Last Edit: February 12, 2015, 04:54:26 pm by Louis Tully »
Re: Pedestal. Formerly the Wii Mario Kart..project. Keep it simple.
« Reply #27 on: April 07, 2014, 01:18:04 am »
I was thinking about going with the no carriage bolt look for the joysticks and thought about those kit deals Randy sells. Then it clicked... What if I use a t-nut and a butterfly head bolt like all this drum stuff? Something like this has got to be the solution. I'll use a small block of wood with a through hole in the center for the bolt and have a small dowel on either side to keep it from shifting. 1 bolt for each, minimal materials, no moving parts, and I don't have to have the control panel box be 10" deep. 3 small holes on the underside of the control panel and it's in business.
Looks interesting.
What angle do you want to operate the wheel at normally?
Do you need to tilt the top towards you, away from you, or both?
(The video you posted only shows tilting the wheel away from you)   :dunno
The company name to know for the knob/threaded shaft is Dimco Gray.
Use the website to find the desired fastener then plug the P/N into Amazon FTW.
For tee nuts, I prefer to use the ones with the small nail holes instead of the prongs, especially in MDF.
« Last Edit: April 07, 2014, 01:27:03 am by PL1 »
Generic Eric
« Reply #28 on: April 07, 2014, 12:29:03 pm »
How do you put it back in?  It seems that *the force* would keep it in place once you took the wheel out.
Louis Tully
« Reply #29 on: April 07, 2014, 07:07:10 pm »
« Last Edit: February 12, 2015, 04:54:50 pm by Louis Tully »
« Reply #30 on: April 07, 2014, 08:02:49 pm »
Looks like you've got a good design there, LT.   ;D
Maybe add some furring strips on either side of the L-bracket to form a guide channel for easier alignment.
Add two thin nuts sandwiching a star-washer or a lock-nut to retain the knob on the L-bracket and you're golden.
Use a shelf-pin cover similar to this or the ones for bookcase shelf pins over the back screw to minimize scratches.
Same way you pulled it out -- lift the green and tilt it back.
Gravity does the work keeping the green (CP) down -- add some type of easy-release latch if your gameplay style is vigorous enough to tilt the CP while using the joystick.
« Last Edit: April 07, 2014, 08:27:56 pm by PL1 »
SavannahLion
Me neither!
WTH?!? How could I not realize that? Been playing this game since it came out and I've been getting hammered on the final races. I've seen the "stunts" during the time trials but could never figure it out.  :banghead:
I'm going to fire it up right now and try it.
jdbailey1206
« Reply #32 on: April 08, 2014, 10:32:22 am »
jdbailey1206: LT stop being a clown. Keep it simple.
Me: :banghead:
On a different note - I've recently started using Spotify and now know the greatest band in the world is called True Widow. That is all.
I would NEVER, EVER, call anyone a clown.  An ass clown maybe.... :lol  Great job pushing forward.  Edison said it took him 1,999 ways to figure out how not to invent the light bulb.  Keep at it.
keilmillerjr
  • Web Developer.
« Reply #33 on: April 08, 2014, 02:19:31 pm »
I'd go to a junkyard and pick out a set of nice car seats. Fix them to a 2x4 base, and make a pedestal with a mount on the other end for a tv. You can jailbreak the wii and probably have it boot directly to the game. I'd keep it simple and leave the controllers wireless as is. You could possibly have the seat and base section easily be removed, as well as the steering wheel assembly, making it easy to disassemble and those parts go into storage. Then you can just watch TV. Multipurpose.
Louis Tully
« Reply #34 on: April 09, 2014, 09:46:17 am »
« Last Edit: February 12, 2015, 04:54:58 pm by Louis Tully »
Louis Tully
Pedestal. Mario theme?
« Reply #35 on: April 09, 2014, 10:03:35 am »
« Last Edit: February 12, 2015, 04:55:07 pm by Louis Tully »
thomas_surles
Re: Pedestal. Mario theme?
« Reply #36 on: April 09, 2014, 10:33:47 am »
Get some led buttons with gold coin inserts or green 1up mushrooms for the coin buttons.
Generic Eric
« Reply #37 on: April 09, 2014, 11:06:38 am »
Could you hide the speakers in a cloud?
__________
Typing on a phone
« Reply #38 on: April 09, 2014, 11:33:41 am »
Sounds like you need a couple of these...
Generic Eric
« Reply #39 on: April 09, 2014, 12:11:11 pm »
You won't need a coin door, or coin buttons on your CP, just 2 of these.
