Author Topic: joystick issue.  (Read 2465 times)
dcninja
  • Last login:March 01, 2025, 09:59:52 am
joystick issue.
« on: March 01, 2014, 04:43:34 pm »
I have a metal control panel.
it's a dynamo cut corner panel.
i have zippy joysticks.
mounting plate won't match up to the holes on the control panel, it's too narrow of a mounting plate.
I'm frustrated as I thought I was going to be able to hook these up today.
anyone else have this issue with joy stick mounting? how do I fix it?
The control panel is metal. I do not have a drill, not do I want to drill the panel. I'd like to just modify the sticks.
http://www.paradisearcadeshop.com/4-8-way-joysticks/45-classic-arcade-stick-zippy-long.html
any help would be greatly appreciated!
  • Last login:October 28, 2025, 11:06:27 am
Re: joystick issue.
« Reply #1 on: March 02, 2014, 01:21:08 am »
Something like this would probably be what you're looking for.  However they are out of stock.   :-\
http://www.paradisearcadeshop.com/home/1175-universal-joystick-mounting-plate.html
dcninja
Re: joystick issue.
« Reply #2 on: March 02, 2014, 01:37:34 am »
thanks I saw the kickstarter. It does say in stock though. Did they just update that or something?
Re: joystick issue.
« Reply #3 on: March 02, 2014, 02:15:47 am »
The same guy (owner) of paradise arcades is the guy that started the kick starter project. :-)
Louis Tully
Re: joystick issue.
« Reply #4 on: March 02, 2014, 05:39:47 am »
« Last Edit: February 12, 2015, 04:23:40 pm by Louis Tully »
  • Last login:Today at 02:09:30 am
Re: joystick issue.
« Reply #5 on: March 02, 2014, 06:11:45 am »
If you don't mind losing a little joystick height, you could just mount the stick to a piece of say... 1/2" plywood/mdf/material of your choice, then mount that to the control panel. Kind of like what I did here.
Two things to piggyback on this idea:
1. If the mount holes are too close to each other, turn the joystick 90 degrees.
2. For a shallower mount, you can use this method (pictured below) minus the white hardboard cover/Bondo/spackle and add 4 holes for the carriage bolts to make an adapter board or you might be able to use a 1/8" hardboard or 1/4" MDF adapter board if you use countersunk screws/nuts to attach the stick to the underside of the adapter board and carriage bolts/nuts to attach the adapter board to the CP .
dcninja
Re: joystick issue.
« Reply #6 on: March 02, 2014, 11:39:07 am »
I thought about making a 2 or 3 layer cardboard adapter since i don't have metal or woodworking tools. I went ahead and ordered some happ competitions because they looked like they'd probably fit and it's a dynamo (american cab) and the holes look like they'll fit. So close yet so far from getting the cab at least playable. :(
Re: joystick issue.
« Reply #7 on: March 02, 2014, 12:34:20 pm »
Hopefully those Comps will work out for you.
A cardboard adapter isn't going to work for long if it works at all.
You can do 90% of the adapter plate with a drill and the rest with a utility knife if you really have to.
If the Comps don't work and you can't make an adapter plate, the alternative is to wait for Paradise to restock on the universal plates.   :dunno
P.S. Be careful about those "no woodworking tools" comments, you might get your Man Card pulled for that kind of talk.   :laugh2:
EDIT: Thought they were out of stock.   :dunno
« Last Edit: March 02, 2014, 01:14:53 pm by PL1 »
dcninja
Re: joystick issue.
« Reply #8 on: March 02, 2014, 12:49:11 pm »
the paradise stock says it has adapter plates tho. everyone keeps saying out of stock but the site says otherwise.
also I'm not worried about my man card. lol
mgb
  • North East, US
Re: joystick issue.
« Reply #9 on: March 02, 2014, 01:06:09 pm »
I've made some adapters in the past for mounting zippyys in where happs once were. They were pretty ugly underneath but did the trick.
You can use a 4" electrical box cover like this http://www.globalindustrial.com/p/electrical/boxes/covers-accessories/4-square-box-cover-flat-1-2-knockout-center
and a drill and make an adapter.
just keep in mind for the future that all joystick mounting patterns are not the same.
Happs, Il, Crowns and Sanwa JLWs have the same basic mounting
seimitsus, zippyys and Sanwa JLFs have the same basic mounting pattern
eds1275
  • Last login:October 06, 2025, 04:35:27 pm
  • Rock and Roll!
Re: joystick issue.
« Reply #10 on: March 02, 2014, 01:18:57 pm »
If there's clearance, could you not just drill more holes in the joystick's mounting plate?
dcninja
Re: joystick issue.
« Reply #11 on: March 02, 2014, 08:01:46 pm »
the mounting plate is too narrow. it's not a square like the happs are i guess, it's a rectangle like the sanwas, i guess?
