Author Topic: .  (Read 87291 times)
Re: Simplistic Pac-Man Bartop (Project Code Name: Yellow Fever)
« Reply #40 on: February 26, 2014, 03:58:15 pm »
I took it as the asian girl thing, prolly because I have a hot asian fiancee and Im just an average white guy :)
mcseforsale
  • Creepy Mario Dude
« Reply #41 on: February 26, 2014, 06:30:36 pm »
Pics or it didn't happen.  >:D
AJ
« Reply #42 on: February 26, 2014, 06:33:28 pm »
AJ
she can be seen in many of my project and restoration threads.
« Reply #43 on: February 26, 2014, 06:48:32 pm »
I thought you two were married by now. How's Learning Mandarin going? That is a ---smurfette--- of a language. >:D
ChanceKJ
« Reply #44 on: February 26, 2014, 06:49:42 pm »
« Last Edit: March 18, 2021, 11:42:57 pm by ChanceKJ »
« Reply #45 on: February 26, 2014, 07:07:56 pm »
AJ
Im a lazy man, just give us the goods or we're gonna still call BS.
« Reply #46 on: February 26, 2014, 09:13:28 pm »
threadjack
No we get married Oct 26th of this year, unless she wises up or I kill her (or both?)  My mandarin has actually gotten worse, Ive been focusing on updating all my M$ certs to 2012.
/threadjack
mcseforsale
  • Creepy Mario Dude
« Reply #47 on: February 26, 2014, 09:25:29 pm »
Screw that.  Go for RedHat.  That stuff is killing here at least (metro Atlanta).
I taught MS for years and still have a valid MCSE, but I use it less and less.  Linux is perplexing and fun all at the same time.  It's a long way from when I was a sysadmin for HPUX on HP miniframes.
Plus, I have an entire CI environment built on freeware (Jenkins, GitLab, GitWeb, et. al) that REALLY pads the resume.
/threadjack
AJ
ChanceKJ
« Reply #48 on: February 27, 2014, 01:30:42 am »
« Last Edit: March 18, 2021, 11:43:04 pm by ChanceKJ »
« Reply #49 on: February 27, 2014, 01:45:09 am »
Isn't bosconian and xevious 8 way?
« Reply #50 on: February 27, 2014, 07:45:41 am »
My job uses nothing but M$, and I have a pretty cushy job. After the 2012 stuff I gonna nail down my Mandarin. I muck around with *nix but its just not useful in my day to day.
Well Galaga is a two way, not a 4 way, not that it matters.
I know Xevious is an 8 way (2 buttons)
and Im pretty sure Bosconian is an 8 way (1 button)
jdbailey1206
« Reply #51 on: February 27, 2014, 11:07:12 am »
Current Roadblocks: 2014.Jan.05
1. Time
2. The Plug & Play runs on 6 AA batteries. I need to figure out how to run it off the display's power, or integrate a small power supply, which i'll probably need anyways for the audio.
The following youtube video may help Chance.  The best I could find for an actual wired dummy battery that was manufactured was a single A battery to an outlet plug.  Also if you ever need to find out what games had what controls just go here and type in the name of the game and that in turn will lead you to a link that gives you the basic information of the game including release date, button number, what joystick, etc etc.
jdbailey1206
« Reply #52 on: February 27, 2014, 11:52:59 am »
Uh...I mean....
Well Fed Games
  • Delicious!
« Reply #53 on: February 27, 2014, 04:10:12 pm »
Yep. FWIW, I plan on using LS-56s with octagonal gates when i do more of these plug and play cabs (I am slowly accumulating the stuff to do a run of 4).
ChanceKJ
« Reply #54 on: February 28, 2014, 02:09:11 am »
« Last Edit: March 18, 2021, 11:43:10 pm by ChanceKJ »
ChanceKJ
« Reply #55 on: February 28, 2014, 02:44:00 am »
« Last Edit: March 18, 2021, 11:43:16 pm by ChanceKJ »
Louis Tully
« Reply #56 on: February 28, 2014, 05:22:43 am »
« Last Edit: February 12, 2015, 04:23:31 pm by Louis Tully »
ChanceKJ
« Reply #57 on: February 28, 2014, 05:37:39 am »
« Last Edit: March 18, 2021, 11:43:20 pm by ChanceKJ »
  • Last login:Today at 03:29:09 am
« Reply #58 on: February 28, 2014, 05:16:57 pm »
Correct me if i'm wrong (Scott, i'm looking your way here), but i could just take this 6VDC, 1.2A adaptor, chop the end off, and wire it right to the leads that connect to the plug-n-play's battery compartment?
4 AA batteries @ 1.5v each, (6v) and the amps don't matter as long as the adaptor exceeds the draw of the device? correct?
That should work just fine, but why spend that much?.
i found some  5-ish volt ones laying around tonight. Cell chargers, etc. most were low mA tho.
If you want to try those 5v chargers, hook up your multimeter in series with the power supply to verify how much current the plug-and-play draws -- it should be fine.
Cylon-Scott
:P
I ran that thing for 9+ hours off of a 5v phone charger and it never seemed to act strange. Batteries aren't 100% accurate and they drop a little when they start to die.
Over most of the discharge curve, batteries have a 1.4-1.2 volt charge so engineers will usually design the circuit to work with 5v or less.
« Last Edit: February 28, 2014, 05:20:18 pm by PL1 »
jdbailey1206
« Reply #60 on: March 01, 2014, 12:24:55 pm »
Picard haz a smartfone.   :laugh2:
ChanceKJ
« Reply #61 on: March 15, 2014, 11:07:09 pm »
« Last Edit: March 18, 2021, 11:43:34 pm by ChanceKJ »
404
« Reply #62 on: March 15, 2014, 11:17:46 pm »
i have one of the first models of these little pac man units and i must say, they really stepped up the looks of the menu system on these bandai units.  :applaud:
ChanceKJ
« Reply #63 on: March 22, 2014, 06:39:59 pm »
« Last Edit: March 18, 2021, 11:43:39 pm by ChanceKJ »
ChanceKJ
« Reply #64 on: March 23, 2014, 03:13:28 am »
« Last Edit: March 18, 2021, 11:43:43 pm by ChanceKJ »
ChanceKJ
« Reply #65 on: March 23, 2014, 04:22:59 am »
« Last Edit: March 18, 2021, 11:43:47 pm by ChanceKJ »
JDFan
« Reply #66 on: March 23, 2014, 09:48:37 am »
Hmm may have to track one of these down -- Would be interesting to see if you could combine this with one of the 7 or 9 inch portable DVD players that also runs on rechargeable batteries and hook it up so all the batteries charge when plugged in -- figure that way the entire unit could be portable and just plugged it in to recharge. Figure the DVD player can run 5 hours or so on a charge so should last longer if just using the monitor and would have a completely portable unit that could be played for several hours without a cord.
I already have a couple of the DVD players so may just have to give this a try.
ChanceKJ
« Reply #67 on: March 23, 2014, 12:14:30 pm »
« Last Edit: March 18, 2021, 11:43:51 pm by ChanceKJ »
Well Fed Games
  • Delicious!
« Reply #68 on: March 23, 2014, 03:01:04 pm »
Very cool, and thanks for all the pics. Nice to have a reference for whenever i start hacking these things up.
ChanceKJ
« Reply #69 on: March 24, 2014, 10:36:55 pm »
« Last Edit: March 18, 2021, 11:43:55 pm by ChanceKJ »
« Reply #70 on: March 25, 2014, 03:08:38 am »
I am loving the progress in here!  And that TV looks great!  I might have to swing down to my local CanTire and see if I can get my hands on one.  The image on that thing looks great for composite.
Nice work getting the proper controls hooked up to that board too.   :applaud:
ChanceKJ
« Reply #71 on: March 25, 2014, 03:12:35 am »
« Last Edit: March 18, 2021, 11:44:00 pm by ChanceKJ »
ChanceKJ
« Reply #72 on: March 25, 2014, 03:26:31 am »
...looks like you can buy the main board separately too. I should have nabbed the serial number for that AUO panel.
http://www.tvpartsguy.com/servlet/the-13947/PROSCAN-PLED2435A-dsh-C-MAIN-BOARD/Detail
« Reply #73 on: March 25, 2014, 06:00:35 am »
Quote from: ChanceKJ
Do you think it's possible I could rig it up so that my little PacMan plug n play gets it's power from the 15"RCA LCD I bought for it?
I double checked your photos of the TV and noticed this one.
That looks like a USB port on the upper right.   ;D
You should be able to hack a USB cable or buy this USB cable from GGG.
Ok, i think i just answered a few of my questions with my multimeter. (I'm new at this, its a learning experience).
I tested the voltage from the USB on the TV and it outputs 5V  (well, 5.13V to be exact).  I tested the PnP at the batteries and it reads 6.18 directly from them. I have a feeling there are a couple resistors (?) in some heat shrink just past where the leads come from the batteries on the PnP. because after the switch at the board there is 5.98V.
Taking a hint on that USB idea i scrapped an old iPod cable and attached a Molex connector to the Grd and 5V leads of the USB.
Two questions:
1. Do you feel that i'm on the right track here and I'll be able to snip the PnP wires at the batteries and run them into this USB tap cable i made?
Assuming the plug-and-play doesn't draw too much current, it should work.
2. I'm worried about plugging it in backwards and frying the PnP with the USB. Based off the readings on my meter can i just plug the red wire on the USB tap to the red wire on the battery housing of the PnP (including what looks to be the resistor under the shrink)?
USB tap I made.
Power from the USB port on the TV.
Power from the batteries.
the reading on the left of 6.18 is misleading, i took the reading from right at the base of the wires where they connect to the yellow box holding the batteries, as shown in the image above.
Power tap cable looks good.   ;D
Based on your pictures, red to red and black to black should work fine.
ChanceKJ
« Reply #74 on: March 25, 2014, 11:58:18 am »
« Last Edit: March 18, 2021, 11:44:09 pm by ChanceKJ »
JDFan
« Reply #75 on: March 25, 2014, 09:35:04 pm »
FOr anyone looking for one of these it seems Kmart got a new supply of inventory of these and the Space invaders units -- $24.99 for the Pacman 12 game unit and $21.99 for the 10 game Space Invaders unit !
Made a trip to the local Kmart and they had about 10 of the pacman and 12 space invaders in the store so will probably be picking one up this week. Since I found an old AC plug that is 6V 200ma output that should work fine to replace the batteries and have an old 13" TV sitting in the closet that has the proper inputs so looks like a good start for building something (perhaps a Dig Dug based bartop)  :applaud:
ChanceKJ
« Reply #76 on: March 25, 2014, 10:14:08 pm »
« Last Edit: March 18, 2021, 11:44:14 pm by ChanceKJ »
JDFan
mcseforsale
  • Creepy Mario Dude
« Reply #78 on: March 25, 2014, 11:18:48 pm »
Not a sketchup, but a printable PDF.  Or, I'll just sell you one of the ones I built and don't want to finish. :D  PM me your email and I'll get that PDF and the photoshop side panel (for drawing sideart) out to you.
AJ
AJ
Sweet deal.  I've had my eye on that Space Invaders one. Just for the Bubble Bobble and Invaders.
I think i've figured out a design/theme/look etc.
Maybe an Ash grey hardwood Weecade clone cab. A couple of pieces of tinted black glass for the display and marquee. then behind the tinted marquee glass a "Namco" logo in red neon? couple red leaf switch pushbuttons and a red leaf switch ball top. a black metal back plate and black metal CP.
Anyone have a weecade sketch up model on hand?
ChanceKJ
« Reply #79 on: March 25, 2014, 11:59:23 pm »
« Last Edit: March 18, 2021, 11:44:19 pm by ChanceKJ »
