Author Topic: .  (Read 87652 times)
ChanceKJ
« Reply #200 on: July 27, 2014, 11:52:57 am »
« Last Edit: March 18, 2021, 11:49:53 pm by ChanceKJ »
ChanceKJ
« Reply #201 on: January 27, 2015, 11:47:21 pm »
« Last Edit: March 18, 2021, 11:49:59 pm by ChanceKJ »
jdbailey1206
Re: Simplistic Pac-Man Bartop (Project Code Name: Yellow Fever)
« Reply #202 on: January 28, 2015, 06:21:30 am »
120 days and all I get is a monitor update?  Weak! :laugh:
Generic Eric
« Reply #203 on: January 28, 2015, 09:23:34 am »
What does the other side look like?  Can you debezel this?
« Reply #204 on: January 28, 2015, 09:25:40 am »
It's too bad you couldn't use those in portrait orientation, with the game taking up the whole screen.
« Reply #205 on: January 28, 2015, 09:49:58 am »
sell me the extra screen
« Reply #206 on: January 28, 2015, 09:51:42 am »
He'll need that for Project Code Name: Yellow Fever II: Fever Harder.  >:D
Generic Eric
« Reply #207 on: January 28, 2015, 09:51:47 am »
Why didn't I think of this?
@ChanceKJ  I'll give you even money.  $2.47.
ChanceKJ
« Reply #208 on: January 29, 2015, 09:17:03 pm »
« Last Edit: March 18, 2021, 11:50:06 pm by ChanceKJ »
jaharr01
« Reply #209 on: January 30, 2015, 08:36:22 pm »
I'm not sure that rotation thing is easily done chance. I did some research, I think it's a little tough
Jay
ChanceKJ
« Reply #210 on: January 30, 2015, 09:45:24 pm »
« Last Edit: March 18, 2021, 11:50:12 pm by ChanceKJ »
JDFan
« Reply #211 on: January 30, 2015, 10:17:51 pm »
Also keep an eye on EBAY under Slave screen or dual screen and you can find some for a decent price -- For Example this one for $22 shipped (not real bad but can usually find cheaper) -- ( http://www.ebay.com/itm/Philips-PD7012-7-LCD-SLAVE-Screen-MONITOR-ONLY-WORKS-GREAT-/271750168382?pt=LH_DefaultDomain_0&hash=item3f45927f3e )
or THIS ONE HAS 4 AVAILABLE FOR $20 - ( http://www.ebay.com/itm/PHILIPS-PD7012-37-Portable-DVD-Player-7-SLAVE-SCREEN-ONLY-4-AVAILABLE-/301507824331?pt=LH_DefaultDomain_0&hash=item4633444acb )
« Last Edit: January 30, 2015, 10:24:46 pm by JDFan »
« Reply #212 on: January 31, 2015, 09:30:18 am »
problem is, none of those ever come with power cords and the sellers never respond when I ask for specifics to find a replacement cord.
JDFan
« Reply #213 on: January 31, 2015, 09:41:43 am »
I usually do a google search on the model number of the screen\DVD player and\or look at the pic of the back of the monitor if given usually one or the other will give a look at the power specs ( FIgure most of them are pretty flexible since they are designed to work on 9V - 12V since they are designed to run on car voltages and only take a small amount of power.
For example the $20 ones I linked with a google search comes a link to the Manual  ( http://download.p4c.philips.com/files/p/pd7012_37/pd7012_37_dfu_eng.pdf ) and in it :
Input: 100-240V 50/60Hz 0.3A
Output: DC 9V 0.8A
SO you'd need an adapter that provides 9V and at least 0.8A which should be fairly easy to find at your local Goodwill ! OR a quick Google search for 9V DC power adapter comes up with this EBAY one for $1.95 shipped ( http://www.ebay.com/itm/AC-to-DC-9V-1A-Converter-charger-Adapter-Power-Supply-1000-mA-5-5X2-1-2-5X0-7-/171414833630?_trksid=p2141725.m3641.l6393 ) which is 9V 1.0A so would work fine !
« Last Edit: January 31, 2015, 09:48:39 am by JDFan »
