Author Topic: Generic cabaret-Arcade Classics finished-02.23.14 **4 button/PC update 5.25.14**  (Read 28970 times)
Mr_Numbers
  • Last login:December 01, 2017, 10:49:05 am
  • Long time lurker, first time builder
Re: Generic cabaret cab. Bezel is in. Marquee attempt #1.5
« Reply #80 on: February 07, 2014, 04:55:28 pm »
I tweaked the marquee a little. Changed the font and contrast.
Top image is the old one.
 :dunno  My wife said she likes the first one. Both are pretty equal to me, I don't effin know.  :lol
I like how clean looking these are, kudos
Louis Tully
Re: Generic cabaret cab. Bezel is in. Marquee attempt #1.75
« Reply #81 on: February 23, 2014, 06:27:48 pm »
« Last Edit: February 12, 2015, 04:14:43 pm by Louis Tully »
« Reply #82 on: February 23, 2014, 06:44:25 pm »
That really turned out great.   :applaud:
Louis Tully
Generic cabaret cab "Arcade Classics" is now finished - 02.23.14
« Reply #83 on: February 23, 2014, 06:45:48 pm »
« Last Edit: February 12, 2015, 04:15:09 pm by Louis Tully »
Superfrog
    • My YouTube Channel
Re: Generic cabaret cab "Arcade Classics" is now finished - 02.23.14
« Reply #84 on: February 23, 2014, 07:10:23 pm »
I dig it to  :cheers:
Great and very slick cabinet  :notworthy:
BAMBOO
« Reply #85 on: February 23, 2014, 10:46:18 pm »
By far my favorite machine on here I've ever seen.   :applaud: :notworthy:
talkgeek
« Reply #86 on: February 24, 2014, 12:56:36 am »
I really like this, quality and detail  :applaud: - this style has just gone on my want need list (along with Moon Patrol and Fit-It Felix)  :banghead:
Nimbus
  • Last login:December 21, 2019, 08:08:57 pm
« Reply #87 on: February 24, 2014, 03:07:47 pm »
What a great design. Fantastic job!  :applaud:
blashyrk
  • Last login:May 14, 2017, 02:56:16 am
« Reply #88 on: February 24, 2014, 06:11:21 pm »
Very nice indeed
Louis Tully
« Reply #89 on: February 24, 2014, 07:46:58 pm »
« Last Edit: February 12, 2015, 04:15:15 pm by Louis Tully »
Louis Tully
Generic cabaret cab "Arcade Classics" is finished - 02.23.14 Kiddo approved.
« Reply #90 on: February 24, 2014, 07:52:20 pm »
« Last Edit: February 12, 2015, 04:15:22 pm by Louis Tully »
Drnick
  • Plodding Through Life
I see bare wire on the back black cable, where is the heatshrink protection, I presume you used protection  >:D
Louis Tully
« Last Edit: February 12, 2015, 04:15:26 pm by Louis Tully »
  • Last login:Today at 06:48:03 pm
No need to fear A.C. wiring.  Respect, yes.  Fear, no.
That power inlet uses QDs, just like buttons do.   >:D
Heat shrink is a nice touch if you have a heat gun and don't mind the effort:
* Pull one QD at a time.
* Place heat shrink on the wire, but don't shrink it yet.
* Reattach the QD.
* If you're paranoid about whether you messed up the wiring, check the resistance on the hot, neutral, and ground wires from the plug that normally plugs into the wall outlet to a power strip outlet inside the cab.
* Once all the heat shrink pieces are in place,  fire up the heat gun and shrink 'em on down.   :cheers:
« Last Edit: February 25, 2014, 04:44:40 am by PL1 »
Louis Tully
« Last Edit: February 12, 2015, 04:15:35 pm by Louis Tully »
Drnick
If you're being serious, I'm terrible when it comes to reading tone on the interweb and your line was kind of funny so...  :dunno But, yeah, I'll pop this ---smurfette--- out and double bag 'em if I've got it wrong here. This stuff is outside my comfort zone. Wrap it before you tap it.
Mostly serious but the line was also meant to convey a bit of humour.
Electrical tape will do for me.  I only mentioned it as I managed to shock my socks off, literally not physically with one of those connections.  And that's why I now always advocate the use of Protection.
jdbailey1206
If you have them like you should, quick female disconnects work well for this application.  I ordered an abundance of them for my control panels and found they work nicely for my rocker switches.
Louis Tully
« Last Edit: February 12, 2015, 04:15:48 pm by Louis Tully »
Generic Eric
What is the angle of the cp/bezel?
What stain was that?  I couldn't make it out in the picture.  I used a pecan stain by the same company for mine.
Thanks.
Louis Tully
« Last Edit: February 12, 2015, 04:15:55 pm by Louis Tully »
