Author Topic: Help with Mame "ok" screens  (Read 2942 times)
USA007
  • Last login:January 05, 2014, 09:07:19 pm
« on: September 18, 2013, 09:29:56 pm »
Hi all,
Lately I have been making an arcade cabinet out of an old computer, and have run into a problem with mame when it asks me to type "ok" before a few games start.
My end goal is to not have a keyboard present, so I can't simply type it out. My joystick is the X-Arcade Dual Stick, which has a non-changeable key layout. I originally tried remapping two of my buttons with Autohotkey, only to discover Mame ignores anything but raw input.
Is there any way to be able to type "ok" for mame or get rid of those screens? I heard compiling gets rid of them, but also heard the screens that don't go away after one play will always be there no matter what.
Any help would be appreciated!
TopJimmyCooks
Re: Help with Mame "ok" screens
« Reply #1 on: September 18, 2013, 09:31:47 pm »
search for mkchamp hiscore nonag.
Thenasty
  • Last login:Yesterday at 11:35:24 am
« Reply #2 on: September 18, 2013, 10:30:16 pm »
wiggling the Joystick should also work (left/right,right/left etc...)
Free VGA Breakout Cable
USA007
« Reply #3 on: September 18, 2013, 11:26:18 pm »
My joystick's outputs are keys (in this case the num pad) so it doesn't work.
I'll look up mkchamp
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #4 on: September 18, 2013, 11:28:48 pm »
He's referring to this post:
http://forum.arcadecontrols.com/index.php/topic,64298.0.html
It's pretty easy to compile your own mame without those screens. It also adds high score support, which is fun.
USA007
« Reply #5 on: September 19, 2013, 01:46:47 am »
Yes, I found that post, for some reason my old computer could not open the command prompts to apply the patch/compile mame. I'll see if one of my newer computers can do it
TopJimmyCooks
« Reply #6 on: September 19, 2013, 08:40:02 am »
use either the directions from MrDo's arcade or the compiler program from headsoft.
USA007
« Reply #7 on: September 19, 2013, 07:02:21 pm »
Yeah, for some reason my old pc didn't want to work through the command prompt. (I need 32-bit, and the compiler program only creates 64) I have my other comp compiling it right now, so thanks for all the help!
