Author Topic: Sega Monaco GP 1979/1980 - My Remake  (Read 385913 times)
GPForverer2024
  • Last login:August 24, 2025, 09:43:10 am
Re: Sega Monaco GP 1979/1980 - My Remake
« Reply #600 on: July 26, 2025, 03:28:33 am »
Hi Geecab!
 I changed the damping to 75 and the rpm_stall to 0 in the Arduino_rev.sim.ino file.
And strangely, the needle goes all a over the place.
What if there were throttle inputs from 1 to 6 very quickly?
 Nothing's consistent anymore.
 Then I modified the file by changing oar tone(OUTPUT _Pin,1); And the needle doesn't go to zero; it increases and then drops to 2 rpm.
Nothing's consistent either. So I tried changing the damping to 75 and rpm_stall to 500 in the file, leaving the tone(OUTPUT _Pin,1);
The rev counter responds better, but doesn't go down to 0 rpm at all; it only goes down and freezes at 500 rpm.
Finally, I went back to the file as I did yesterday with the damping at 95, the rpm_stall at 500, and the noTone(OUTPUT _Pin); This is the best result I have, except that the needle doesn't go directly to 0; it stops at 500 rpm for 1 second, then goes down to 0 rpm. I noticed that as soon as I go below 500 with the rpm_stall, the needle goes crazy.
 I hope this helps, thanks.
GPForverer2024
« Reply #601 on: July 26, 2025, 08:52:28 am »
Hi Geecab!
This morning it was impossible to post on the site, I don't know why.
I changed the damping to 75 and the rpm_stall to 0 in the Arduino_rev.sim.ino file. And strangely, the needle goes all over the place.
Then I modified the file by changing oar tone(OUTPUT _Pin,1); And the needle doesn't go to zero; it increases and then drops to 2 rpm. Nothing's consistent either.
geecab
  • Last login:Today at 08:37:13 am
« Reply #602 on: July 26, 2025, 10:04:55 am »
Hi GPForverer2024!
>>I'm writing you a private message because I can't post anymore, I don't know why.
This forum is a bit strange sometimes. I'll post this response on the main thread too in case you don't receive it.
Thanks for running those tests. The point of them was to see what your revcounter did when you try to display low RPMs (lower than 500RPM). My revcounter's needle also goes crazy when I send it low RPMs. I was hoping your revcounter might be able to handle low RPMs better than mine (and your needle would drop to zero better, avoiding that 1 second freeze thing you are seeing), but clearly this is not the case. Anyways, good to know.
OK, so with this configuration when the game's RPM is 500 or lower, the Arduino will completely stop sending pulses to the revcounter. The Arduino will only send pulses to the revcounter when the game's RPM is greater than 500RPM. That's what the RPM_STALL thing does.
Regarding the "It stops at 500 rpm for 1 second, then goes down to 0 rpm", I can't say for sure, but I suspect this is just the way your particular revcounter was designed (So might be something we just have to live with). The occasions when the Arduino completely stops sending pulses, its like your revcounter freezes for 1 second at the last 'good' RPM its needle pointed at. Then if its still receiving no pulses after 1 second,  it decides the engine really has been switched off and its needle drops to zero. Does that make sense?
I have another arduino_rev_sim.ino that I'd like you to try please. I've improved the damping code (You shouldn't need to set it so high, and you shouldn't need to increase the rpm_range to 8300 anymore). I've also renamed the "RPM_STALL" option to "LOWEST_RPM", and added a "LOWEST_RPM_NEEDLE_ACTION" option which can be set to "DROP_TO_ZERO_RPM" or "POINT_TO_LOWEST_RPM". Hopefully this will make more sense when you read the descriptions of these options in the file.
The new version of arduino_rev_sim.ino can be downloaded HERE.
Hope this helps :)
go2ldook
  • Last login:December 25, 2025, 04:11:52 pm
« Reply #603 on: November 27, 2025, 10:39:39 pm »
Installed on Windows 11 and will not run from cmd line or using the application. Even tried running as admin. When I click START I get a brief screen pop-up then nothing. Would love to get it going. Was looking for this game and learned MAME could not emulate, then found your post. Was my fav racing game back in the day!
neilsnonsense
  • Last login:January 13, 2026, 05:57:42 am
« Reply #604 on: December 01, 2025, 05:16:00 am »
Runs fine on Win11 24H2 for me. A couple of things to be aware of:
  • You have to fully extract the archive. Don't try to run the exe from the Windows explorer view of the archive folder without extracting
  • When launching from command line the terminal has to have the current working dir as the dir with the mgpr.exe in. i.e. cd to this dir first and run only with command mgpr.exe - do not provide a path to the exe from another dir
geecab
« Reply #605 on: December 01, 2025, 07:32:48 am »
Hi go2ldook!
Some good advice from Neil in the last post. Just thought I'd add:
Unfortunately, WIndows 11 is very strict on what executables it allows you to run these days. When you click the GUI Launcher's START button, the GUI Launcher will attempt to run mgpr.exe with various command line arguments. Even though you may have run gui_launcher.exe as admin, those privileges don't automatically get assumed by mgpr.exe.
Thus, can you make sure you have given administrator privileges to both gui_launcher.exe and mgpr.exe. I.e. For both files, right-click and select 'Properties', go to the 'Compatibility' tab, check the box for 'Run this program as an administrator', click Apply, and then OK.
Hope this helps :)
geecab
« Reply #606 on: December 06, 2025, 01:01:20 pm »
Hi All!
I thought I'd put together a full release containing the new utilities I had been working on (Allowing the game to control a physical revcounter and 'CH340' USB Relay boards) and that has a few minor bug fixes. I have added new sections to the release note that explain how the new utilities work. I've also updated the first post on this thread to include the links to the new version that you see here.
enjoy! :)
Monaco GP Remake (v1.5.2) is ready download from my google drive.
For Windows:
  This release supports WindowsXP/Vista/Windows7/Windows10/Windows11:
    Monaco GP Remake v1.5.2 for Windows (Download from my Google Drive)
    Please read the release notes HERE.
  For Linux and Raspberry Pi:
    The release supports x86 Linux PCs Ubuntu 24.04 based distros (e.g. Linux Mint 22) and ARM Linux Debian 12 ('Bookworm') based distros (e.g. latest Raspberry Pi OS) 32-bit & 64-bit:
    Monaco GP Remake v1.5.2 for Linux & Raspberry Pi (Download from my Google Drive)
Extract from the release notes version history:
v1.5.2 (6-12-2025)
 - Added new Scoreboard To Relays utility. See Section 13 of the release notes for details.
 - Added new Scoreboard To Revcounter utility, Arduino sketch file ('arduino_rev_sim.ino') and circuit diagram ('arduino_to_revcounter_circuit.jpg'). See Section 14 of the release notes for details.
 - OPTO2_DEVICE configuration option added. See Section 9 'Accelerator Pedal' of the release notes for details.
 - Bug fixed on the 'Enter Your Name' screen. Ensure the player is off the gas before detecting the first pedal press.
 - Bug fixed in the arcade game track file that was causing 'Number of Opponents' errors in the console window.
« Last Edit: December 06, 2025, 01:02:52 pm by geecab »
