Author Topic: Sega Monaco GP 1979/1980 - My Remake  (Read 397330 times)
geecab
  • Last login:January 21, 2026, 08:37:13 am
Re: Sega Monaco GP 1979/1980 - My Remake
« Reply #360 on: March 11, 2024, 06:51:56 am »
Hi Geecab!
I managed to add my arcade button to turn off the PC by following your method: I created a bath file and set shutdown.exe -s -t 0
 Then I was in joytokey.exe and I associated my button with the bath file and it works great!! :)
if it can help others
Sounds good to me GPForverer2024!
I've recently been adding a couple of new steering options for 270 degree wheels. I've got a configurable deadzone option working (0% to 100%. Default is 0%). I've added a steering range option (0% to 100%. Default is 100%, thus you'll use the full 270 degrees of your wheel) and a steering curve option ('linear', 'soft curve', 'medium curve' or 'hard curve'. Default is 'linear').
I might draw some diagrams to explain better what these options do.
I still need to add some sort option that will limit the player x axis movement on ice roads.
It'll probably be a week or so before I have a 64-bit version for you to try :)
GPForverer2024
  • Last login:August 24, 2025, 09:43:10 am
« Reply #361 on: March 12, 2024, 05:29:25 pm »
Hi Geecab!
I was wondering what you could add as an option for the steering wheel, can't wait to be able to test all this!!
 and 64-bit of course  !!
Thank you  :)
geecab
« Reply #362 on: March 17, 2024, 02:16:58 pm »
Hi GPForverer2024!
Version 1.5.0D3 is here! I've built a 32bit and a 64bit package (FYI. The 64bit version does not contain a gui_launcher at the moment).
****EDIT: This version is now obsolete, please see initial post (on page 1) for download links to latest and obsolete versions****
It would be good to know if you notice a difference in performance when running the 64bit version.
In this debug version:
 - Deadzone steering configuration option now works.
 - New steering options for wheels with limited rotation; steering_curve and steering_range. Hopefully, the picture attached gives you an idea what these do. For your g29 wheel you should no longer have to set the steering sensitivity sky high anymore. I recommend setting steering sensitivity to 100%, then tweaking the steering range and curve to get the ideal response.
 - Ice road response is now more like the arcade. After watching some youtube videos I noticed differences with MGPr and the actual arcade game. On the arcade version, the car does stop skidding after a short timeout if the wheel remains still (MGPr used to skid constantly when on ice). Also, as you noticed, MGPr's steering response was more sensitive when driving on ice than on normal roads, which was wrong. So I've fixed this and also added some new ice road gameplay options as I might choose to tweak these settings in future.
- Small change to the in-game editor, where if you are viewing an option with a long description, the description will scroll across the screen (rather than being cropped).
Enjoy :)
« Last Edit: August 08, 2024, 07:03:53 am by geecab »
GPForverer2024
« Reply #363 on: March 18, 2024, 04:17:41 am »
Hi GEECAB!
 I just tested the D3 version 32 Bits and 64 Bits for information as weird as it may seem impossible to launch the import instance for the 2 versions in fact it launches the game directly to me (playfield)
 so I took my D2 import.cfg file and put it in the cfg D3 folder and the no window opens.
if I run the export.cfg instance, yes it works for the D3 32 Bits and D3 64Bits for speed, it's like 1.5.0 so impeccable but hard to tell because I only have a window and no score display on the second screen so no slowdown..
For the steering wheel, what an extraordinary job!! :applaud:
 Yes you were right, the level of sensitivity is very high, I had to lower the values!!
 Here's my setup:
 Steering_sensivity: 100%
 Steering_Weight:     60%
 Steering_joy_Curve: Linear
 Steering_joy_Range: 60%
 For me the car responds very well with the 270° steering wheel
For the car driving on ice, not a good visual sensation because the car jerks!
The effect in the D2 was much nicer apart from the fact that you swipe for too long, maybe add a swipe option for the car to make sure that the car stops not too sharp, which creates the jerky effect I think?
 once again, what can I say other than BRAVO and THANK YOU for this remarkable work!!
geecab
« Reply #364 on: March 18, 2024, 05:53:23 am »
Hi  GPForverer2024!
I should have mentioned, configurations made with older versions won't be compatible with V1.5.0D3, sorry about that. The configurations in the D3 package should all work OK. If you run mgpr on command line with an older config, it should tell you why the configuration is incompatible (which configuration options it is missing), and then maye you can manually add those  an get it running.
Regarding the ice jerkyness, I'll look into into it. For the time being try increasing the ice_skid_time (I think that's what I called it...) to maximum.
Glad that the 64bit version ran OK 👍 🙂
suverman
« Reply #365 on: March 19, 2024, 01:41:31 am »
Enjoy :)
Amazing, thank you!!
geecab
« Reply #366 on: March 19, 2024, 02:29:59 am »
No worries suverman! 🙂
geecab
« Reply #367 on: March 19, 2024, 02:58:16 am »
Hi GPForverer2024 !
I've been giving some thought to this, I think perhaps the configuration you are specifying on the cmd line may have a typo in it. If mgpr.exe doesn't find the configuration you specified in its 'cfg' directory, it'll create a default configuration (that is just the playfield) for you with the name you specified. I'm guessing I know... perhaps try running mgpr.exe without any cmd line arguments, it should list all the configurations files it finds in 'cfg', allowing you to pick one by typing in its index. Try running the configuration that way.
Cool, good idea 👍I'll add an ice_skid_fade setting (or something like that) that is used too choose how fast the skid fades to a 'no skidding' state.
Hope this helps 🙂
GPForverer2024
« Reply #368 on: March 19, 2024, 03:07:48 am »
Hi Geecab!
 That's it, the 2 64-bit screens work!!!! whaooouu   :applaud: :applaud: :applaud: :applaud:
 I had to reverse the launch of the 2 command-line instances, namely: start Mgpr...... export.cfg and call Mgpr........ import.cfg
 And for the ice cream yes I found the ice option and I modified it it's much better!
 Small question for the playfield my screen is in a vertical position so elongation of the image but especially of the cars, do you think it will be possible to add an option to modify the W and H of the cars??
 otherwise once again BRAVO and BIG THANK YOU FOR THIS FABULOUS MGPR! ;)
GPForverer2024
« Reply #369 on: March 19, 2024, 03:18:14 am »
Thanks also for adding ice_skid_fade soon!
geecab
« Reply #370 on: March 19, 2024, 04:37:50 am »
This is excellent news GPForverer2024!
Glad you got those configs working. I could modify mgpr.exe when you try to load an old configuration to make things a little more user friendly. It could prompt you saying "You are trying to load an old config, should I update it with the latest settings? If you choose to do so, the config may not run on older versions of mgpr.exe. Continue? (Y/N)" sort of thing.
There is a 'zoom' option I added in somewhere (might be called playfield_zoom), in the system options. I think that might be what you are after? Let me know if not 🙂
« Last Edit: March 19, 2024, 04:46:17 am by geecab »
GPForverer2024
« Reply #371 on: March 20, 2024, 12:07:42 pm »
Hi GEECAB!
 the idea is not bad for compatible configs or maybe make a backup of the config in case of MGPR update?
Will this allow us to load our config faster?
 Otherwise for the zoom option that's exactly what I'm looking for!!
 I also think the Stunt circuit at the start there is the checkerboard on the ground (white and black square) is it possible to shorten it because for me it hurts the eyes with the scrolling, I think a length of about 25,4 inch would be enough, it would just be a starting line. What do you think?
Geecab really thank you! :)
geecab
« Reply #372 on: March 21, 2024, 04:05:22 am »
Hi GPForverer2024!
Glad the zoom option helped👍
Great to know you are playing the stunt track! 🙂 Regarding the checkered road section, I can understand how that could hurt your eyes. Rather than shorten the section, I'd prefer to add  a new config option that let's you dull it's brightness. Lets try that first and see.
Now you have been playing about with the 64bit package for a while, how do you think it compares  (with regards to cpu performance) to the v1.5.0 package? Any better do you think?
GPForverer2024
« Reply #373 on: March 21, 2024, 11:18:42 am »
Hi GEECAB!
Since the steering wheel update, I've been having a lot of fun on it!
 For the checkerboard good idea to add an option on brightness!!
Otherwise regarding the difference of v1.5.0 and the 64 bits,
v1.5.0 I have a slowdown as soon as I start the car with 2 screens!! because if only 1 screen there is no slowing down!!
 For the 64 bits we see a clear improvement in the starting of the car, maybe not as good as the v1.5.0 but not negligible, for proof I can't stop playing on it lol with 2 screens!! because the same if 1 screens no slowdown
conclusion: yes it's much better  :)
geecab
« Reply #374 on: March 23, 2024, 11:40:09 am »
Hi GPForverer2024!
I've made another debug version for you to try. This is v1.5.0D4 64bit:
I've made the following changes:
 - New refresh_rate option added (Only supported when running MGPr in import mode). By default, it is set to 50 (because the game runs at 50 frames per second). If you run your import instance with refresh_rate set to say, 10, it should really free up CPU usage and allow your export instance to run at full speed. 10 frames per second might sound low but you really don't notice it when just viewing the scoreboard LEDs :)
 - Renamed the ice skid options slightly, and added a new skid decay time option (The options are: ice_skid_trigger_speed, ice_skid_trigger_steer, ice_skid_intensity, ice_skid_time_active, ice_skid_time_decay). The skid decay option does seem to work well when using mouse or keys to steer. For limited rotation wheels and joysticks, it still feels a little off to me. See what you think anyway...
 - New chequered_road_brightness option added. I agree with you, chequered was always a bit too bright. I've tweaked the default brightness so its less dazzling than it has been. This option allows you to darken it more if you wish.
Unfortunately, I haven't written the "update old configuration to the latest version" code yet. So you'll have to do some manual tweaking again to get your old configs working on 1.5.0D4. Sorry about that (Just turned out a bit trickier than I had first thought).
Hope this helps :)
« Last Edit: August 08, 2024, 07:04:26 am by geecab »
GPForverer2024
« Reply #375 on: March 24, 2024, 06:09:44 am »
Hi GEECAB!
 Thanks for this new debug version D4_64Bits
Frankly, you're a genius to have thought about the frame rate for import instances!
 Actually I lowered it to 10 and yes no more slowdown on the other hand only (note) the revcounter jerks a lot so I raised the frame rate to 20 and the perfect one!!
 By the way, I've noticed that when the car has an accident and it goes down to the bottom right of the Playfield, the needle of the Revcounter and too long to go down, maybe speed it up to go down faster?
otherwise the game runs like version 1.5.0 with 2 screens!!
 -for skidding options ice_skid_trigger_speed, ice_skid_trigger_steer, ice_skid_intensity, ice_skid_time_active, ice_skid_time_decay I tested them all one by one with the steering wheel and unfortunately no feeling of slipping, on the other hand I tested with the keyboard yes it works (weird)
Regarding the option checkered_road_brightness :
it hurts the eyes less, I also think, instead of touching the white tiles for brightness, can we not do the opposite rather the black tiles and leave the white? What do you think? I hope I was able to answer your questions correctly
And don't be sorry for the configuration that has to be put back in hand! Already what you're doing is huge!!!
 THANK YOU :)
geecab
« Reply #376 on: March 24, 2024, 01:00:02 pm »
Thanks so much for your kind words, honestly its a pleasure! I'm actually really enjoying investigating this steering/screen stuff. Its something I've wanted to get right for while, but just don't have the equipment, so I really appreciate you trying out all these debug builds and all your feedback :)
Just so glad you've got the export instance running at full speed. I think that 1920x480 screen you have is quite attractive for anyone building an arcade cab, so its nice to find a way to comfortably run a scoreboard instance on it. Might even get one for myself now lol!
I know exactly what you mean and I've just fixed that. I've also made it possible to change the refresh_rate for the game instance too (Not that you want to do that, but I figured in future somebody might want to in future). The game actually plays pretty well at 25FPS, but less than that gets a bit 'interesting' (Actually feels like an Atari ST port of the game somehow!).
Regarding the ice skidding issue. I've fixed quite a bit of stuff in that area now. I've also backtracked on the whole skid timeout thing I added. I was looking at more youtube videos and I've now seen several monaco gp arcade machines that don't show the ice skid ever timing out... So its possible the arcade machine captured in the video I originally watched (That did show the skid timing out) may have had a board fault or something. I've left the options in the configuration anyway (so people can enable a skid timeout if you really want to).
Anyways, I've done another build, v1.5.0D5:-
I wrote this about it in the release notes:
 - Fix a few bugs with the ice skid state machine.
 - Modify operation of the ice_skid_time_active option, it can now be
   configured to never expire when set to its maximum value (5000).
 - Change ice skid default settings.
   By default, skidding will only start when the steer threshold is reached.
   Once started, the car will skid indefinitely (Until the car slows right
   down, or crashes, or drives onto a normal road). I decided not to set a
   finite skid time as default because, since I working on this, I have seen
   youtube videos of arcade machines where the skid never times out. I suspect
   the arcade machine I watched originally (that did have a finite skid time)
   may have had a board fault. The default ice skid settings are now:-
       ice_skid_trigger_speed     30
       ice_skid_trigger_steer     20
       ice_skid_intensity         50
       ice_skid_time_active       5000
       ice_skid_time_decay        0
 - refresh_rate option now supports all modes.
 - Fix revcounter bug when running import mode at a low refresh rate.
« Last Edit: August 08, 2024, 07:07:13 am by geecab »
GPForverer2024
« Reply #377 on: March 26, 2024, 10:39:13 am »
Hi Geecab!
 I thought I'd answer yesterday but too much work sorry
I tested the D5 version and amazing the car for me reacts very well on the ice I just increase the ice_skid_intensity to 100 and the perfect one!!
 For the rev counter it works very well now  :applaud:
 Now I'm looking for the option to display the green and red dash to display in the score window with the pursuit mode
 nice job Geecab!!
THANK YOU :)
geecab
« Reply #378 on: March 27, 2024, 06:35:52 am »
That's great news about the ice and rev counter GPForverer2024!
Ah, unfortunately I don't currently export the overtake LED state. Pretty sure that will be an easy thing to do so I'll add that.
Also, I'm not sure if you played any of the '3cabs' configurations, but when running the pursuit/stunt track, there are flashing artwork lights when you are being chased that I don't get exported either, but I should probably export that too. I also thought it would be cool to have something that lights up when you car is damaged (and you need a spanner), like an orange "check engine" warning light.
Something I thought of that I thought we be cool would be to have the big "Monaco GP" sign illuminate when you've entered a coin (and playing the game), but then goes dim after you've finished playing. Not sure the best way of doing this though...
« Last Edit: March 27, 2024, 06:37:57 am by geecab »
geecab
« Reply #379 on: March 27, 2024, 01:15:34 pm »
Actually, I've just checked and the import/export of those overtake LEDs should work in the release you have (Although its not very obvious how to enable them). On your import instance, in GAMEPLAY OPTIONS, enable PRO_MONACO_GP_MODE and then those overtake LEDs should appear.
You'll also notice when you do this, the 'Score' LEDs strip will extend from 4 to 5 digits, and you'll get an additional 'Super Racer' 5 digit LEDs strip (Because that's what the Pro Monaco GP bezel had).
Hope this helps :)
GPForverer2024
« Reply #380 on: March 29, 2024, 03:39:29 am »
Hi GEECAB!
That's it, I found to add the green dashes, thanks for the info!!
 Regarding the Monaco GP which lights up by adding a coin to play frankly great idea I already image it with a neon effect style it flashes 2 or 3 times before lighting up !!
For the logo excellent engine problem! And I also thought for the logo of the headlights that lights up when you switch to night mode would be great!!
I was also thinking for the starting checkerboard if it would be too complicated to add an option to shorten it?
For example, the timer starts once the line has been crossed?
(it's just an idea)
THANK YOU GEECAB
geecab
« Reply #381 on: April 03, 2024, 08:59:59 am »
Good stuff GPForverer2024, glad the overtake LEDs are working!
>>Regarding the Monaco GP which lights up by adding a coin to play frankly great idea I already image it with a neon effect style it flashes 2 or 3 times before lighting up !! For the logo excellent engine problem! And I also thought for the logo of the headlights that lights up when you switch to night mode would be great!!
Ok, I'll add these things. Its taking a bit of time getting the Monaco GP lettering to look like it's backlit, but I have managed to make something that looks realistic now :)
>>I was also thinking for the starting checkerboard if it would be too complicated to add an option to shorten it? For example, the timer starts once the line has been crossed? (it's just an idea)
I do understand what you are saying and I like the idea. It might be a bit tricky to implement though and I'll try to explain why...
Currently, the chequered road length is the height of 3 screens. The 'checkpoint' is triggered the first time the chequered road touches the bottom of the screen. The player car can be anywhere on the screen at that point, it doesn't need to 'cross a line', its all about how much road has passed.
To have a short strip of chequered road that, when your car's front tyres touch it, triggers a 'checkpoint' would require me to add some new collision code. it is all possible
but I'm in two minds whether its worth the effort. I do kind of like the long chequered road personally, but I might be a minority :p
Ideally, how long would you like the chequered road to be (In relation to the height of the car)?
GPForverer2024
« Reply #382 on: April 04, 2024, 09:37:29 am »
Hi GEECAB!
Thanks for the feedback, I've put a picture for you so you can see a little bit of the result of the second screen
 For the checkerboard, ideally for the length, it would be just the same height of the car, if too complicated I totally understand and thank you for the explanation already like that it's really very good so don't worry! you can leave it like this!!
 but I repeat bravo for this beautiful work and I am FAN lol!  ;)
See you soon
geecab
« Reply #383 on: April 04, 2024, 10:57:25 am »
That looks so cool GPForverer2024! I like how you've modified the bezel to accommodate the 'pro' elements, thanks for the pic!
That looks like a different screen to your previous (1920x480) one? I'm interested to know what the dimensions are of this new screen are?
Ok, I shall put the chequered board road thing aside for now. I'm thinking that once these new artwork changes I'm working on are finished (and you are happy with them), its probably a good time to release a v1.5.1 version :)
GPForverer2024
« Reply #384 on: April 05, 2024, 02:59:54 am »
Hi Geecab!
 I see you have an eye!! :)
 yes I just changed this screen for better visibility and to put all the widgets on it The screen reference: VSDISPLAY brand 1920x720 FHD 600 nit IPS HDMI Size 12.59 in x 5.21 in this screen I found on Amazon
 As for the display of scores, I'm really glad you like it
 I also thought for the insertion of the coins maybe add credits 1.....2....ect.. Then the Start button to play?
just an idea
Have a great weekend Geecab
geecab
« Reply #385 on: April 14, 2024, 12:31:56 pm »
Hi GPForverer2024!
Just a quick update, I've done quite a few code changes:
    Added dashboard indicator artworks for when driving on night roads, driving on ice roads, and when the car is damaged.
    Added a speedo gauge artwork.
    Added InsertCoin artwork (That flashes when you see 'Deposit Coin' displayed on the playfield).
    Ability to set 2 bezels artworks: A Primary Bezel (Showing, say, shows the bezel fully backlit), and a secondary bezel (Showing, say, the bezel with its backlight off).
    A new 'bezel mode' option that configures how the game should switch between bezels (Either, Fixed on Primary bezel (default), Switch to Primary bezel when inplay, Switch to Primary bezel when inplay with initial flicker etc...).
    All of the above is fully importable/exportable.
    I've fixed the police chase artwork lights so they work on import mode.
    I've fixed a bug with the Pro score LEDs not working when running the Stunt and Pursuit Modes.
    I've fixed the revcounter so that you don't have to have it enabled on the export mode to be able to see it on the import mode (Just a minor thing).
As you are aware, at the moment there is just a very simple scoreboard import configuration with the package.
I'm hoping that soon (Say in about a week), I will have finished some new scoreboard higher-res artworks that demonstrate this stuff working and add those as part of the package too :)
GPForverer2024
« Reply #386 on: April 15, 2024, 09:53:51 am »
Hi GEECAB!
 Thank you for the debrief which looks so good!!
Of course really looking forward to testing this update
Congratulations and thank you  :)
xfassa
  • Last login:September 16, 2024, 09:53:01 am
« Reply #387 on: May 31, 2024, 08:55:45 pm »
After being away from this project for several years, I was thrilled to see it is still being developed.  Amazing stuff Geecab!  Nice to see others sharing their projects too.  I did a complete overhaul on my mini (new artwork, deep cleaning of cabinet/hardware, and updated computer).  I hope share some pics soon.
As I jump back into this project, I am revisiting an issue that I was never able to resolve.  Randomly, while steering left or right, the car will abruptly jump in the direction you turn.  Its almost like the wheel isn't registering and all of a sudden catches up and shoots the car off the road.  I will provide some video soon to better explain.  Just curious if anyone else has seen this problem.  I have attached my steering wheel to at least 5 different brands of spinner knobs, everyone does the same thing.   It's really odd....
I was going to test on my linux machine but I cant figure out how to get the dual displays (game and scoreboard).  I was hoping to see if it was a windows thing.  Looking forward to the the latest linux release.  :-)
All that said, this is just an amazing remake that lets me revisit one of my childhood favorites.  I can't thank you enough Geecab.
geecab
« Reply #388 on: June 03, 2024, 07:08:48 am »
Hi xfassa!
Great to here from you again!
That abrupt Jumping issue you describe sounds strange. I have fixed an issue recently where, if you hit a puddle whilst making a sudden turn, you would see the car 'teleport' from position to another. Although the teleport distance I was seeing was a couple of cars widths (Nothing drastic like shooting off the road). Could this be the same thing you are seeing??
The dual display situation has continued to be a headache. I added some new options in the past that should have made things easier (New full screen modes and a new video adaptor ID setting), but since added them, GPForverer2024 and myself have observed they just don't do the job. The graphics library I use to build MGPr with just doesn't allow me to display 2 instances of the game in true fullscreen mode, on 2 different monitors.
The only reliable way to get dual displays working, is to have both MGPr instances set to WINDOW mode, and have these windows sized and positioned in such a way that they appear as being in fullscreen on the desired monitor.
I remember in the past, for your setup, we worked around a couple of issues:
 1. It was not possible to set the MGPr scoreboard window dimensions to be the same size of the screen you wanted to display it on (MGPr only allowed you to choose resolutions offered by the OS, and for some reason your USB screen resolution did not show up).
 2. Running one big MGPr scoreboard instance impacted CPU usage badly, so you were forced to have 2 small MGPr scoreboard instances that we managed to join together.
Now, I've recently made some changes which should help you.
 1. When configured for WINDOW mode, you can now set MGPr's resolution setting to whatever dimensions you want and it will be honoured (You'll need to manually edit the config file though).
 2. I noticed that reducing the refresh rate (For which there is now a configuration option for) of the MGPr scoreboard instance drastically improves CPU. By default the refresh rate is 50FPS. MGPr scoreboard instances don't really need to be updated at 50FPS. Running the MGPr scoreboard instance at, say, 25FPS looks just at good and allows the MGPr game instance to run at 50FPS just fine.
I've been making some improvements to the scoreboard artworks recently. I wanted to create some for the Stunt Park and Pursuit modes, but I wasn't happy with my attempts (and took a time-out from working on them, waiting for some inspiration, which I'm still waiting for lol!). Anyways, I was looking at what I've done up to this point and actually, I think its pretty good. So, I think I might do a new release very soon :)
geecab
« Reply #389 on: June 04, 2024, 01:07:00 pm »
Thought I'd upload a quick demo of the new scoreboard artworks.
Demonstrates 2 instances of MGPr running simultaneously and sharing scoreboard information. The instance on the left is the Game instance (Writing scoreboard information), the instance on the right is the Scoreboard instance (Reading scoreboard information). The video captures the Classic 1979 Monaco GP game mode, the 1980 Pro Monaco GP game mode and finally the Stunt Park game mode being played. There are a few extras I've added to the scoreboard (It lights up when game is in play, rev & speedo counter, new dashboard indicator lights). All can be disabled if it's not to your taste. The idea is that if you have 2 monitors, you could display the game on one monitor and the scoreboard on the other.
Monaco GP Remake - v1.5.0 - Teaser Trailer 5 - Dual-Screen Scoreboard Artwork
GPForverer2024
« Reply #390 on: June 06, 2024, 02:23:55 am »
Hi GEECAB!
How nice it is to read you again!!
I'm starting to worry, I was going to send you a message otherwise
 I saw your video and whaoo it's exactly what I imagined and you did it!! How lucky you are to be able to do things like that! I really can't wait to test this FYI
 I saw at the level of the scoreboard (ranking) the left and right ends are not like the others, i.e. near the vertical blue lines It's a small detail but frankly it's so good even the neon effect
See you soon Geecab and thank you again! ;)
___________________________________________________
Hi xfassa
For your information,
following your steering problem, sometimes it happens to me and what I do is a recalibration of the steering wheel with the wheel_config0.4.exe software and after more problems!
You can find this description on page 9 if it can help you and for the display of the 2 screens for me everything works perfectly, playing with 2 screens is really great
Geecab has explained everything well above
 Have a nice day!
geecab
« Reply #391 on: June 06, 2024, 05:48:34 pm »
Hi GPForverer2024!
Really glad you like the youtube vid! Yes, sorry for being quiet, I'd been trying to design scoreboards specifically for the Pursuit and Stunt Park game modes but everything I made just looked silly. In the end, I just made the Pro Monaco GP, Pursuit and Stunt Park games modes all use the same scoreboard design (The 2nd design that you see in the youtube vid, which is pretty much a copy of what you did - a tweaked version of the original Monaco GP scoreboard).
I know what you mean regarding the ranking section alignment, and I think you might be as much a perfectionist as me lol! I did experiment with making that ranking section larger, but it looked too stretched somehow. I think I'm going leave the design 'as is' for now, I understand it is not going to be to everyone's taste, but the scoreboard images are just PNGs files so easy enough for users to change if they want something different.
I decided to make one last debug version (v1.5.0D7) as I've made quite a few changes recently. It would be be great if you can give it a quick try, see if you can find any bugs with it, if all good then in about a week I'll make it a full v1.5.1 release.
BTW. From now on if its ok with you, I plan to go back to just making a 32bit windows package. If I recall, there wasn't much of a CPU performance win when you tried the 64bit build, and it was in fact lowering the refresh_rate on the scoreboard instance was the thing that solved your performances issues. It's also easier for me just to build a single 32bit window package :)
[@xfassa - Hopefully, if you're reading this, you can give this debug version a try too, see if that steering issue you described still exists in this version.]
Extract from the release notes:
v1.5.0D7 (03-06-2024)
 - New scoreboard import/export configurations added.
 - Added dashboard indicator artworks for when driving on night, on ice, when
   the engine damaged and when out of gas (Note. the gas light flashes to
   indicate you need to insert a coin).
 - Added a speedo gauge artwork.
 - Ability to set 2 bezels artworks: A Primary Bezel (Showing, say, a bezel
   image with its backlight on), and a secondary bezel (Showing, say, a bezel
   image with its backlight off).
 - A new 'bezel mode' option that configures how the game should switch between
   bezels (Either, Switch from one to the other when in-play without flicker,
   or with one flicker, or with two flickers etc...).
 - Police chase artwork lights now work on import mode.
 - Fixed Pro score LEDs not working when running the Stunt and Pursuit Modes.
 - Fixed the revcounter so that you don't have to have it enabled on the
   export mode to be able to see it on the import mode.
« Last Edit: August 08, 2024, 07:08:57 am by geecab »
GPForverer2024
« Reply #392 on: June 09, 2024, 05:44:23 am »
HI GEECAB !
I just tested the D7 version
 So good news everything works smoothly,
 you just have to think about setting the refresh rate to 25 for my part
 I have a bit of trouble resizing the scoreboard because when I press TAB to be able to move the new widgets they are in black so you can't see much except the fuel one it remains to light small detail but hey it's okay
 then you have to think about restarting the game otherwise you see the superposition of the 2 logo images off
and on Then I found that the pink color around the letters of Monaco GP was not very pretty personally, I think we should leave the gray white color around the letters of Monaco GP of origin, so just turn on the yellow text of Monaco GP and not the rest because it makes a blur for example on the SEGA logo after the choices the taste the colors we are all different lol
I also noticed that the RevCounter, the needle goes up too fast compared to the sound of the motor and the needle far exceeds the number 320 of the meter On the other hand,
the speedo is impeccable
 otherwise what a fantastic job!
 Thank you for your trust for the different tests performed for you  :)
I hope I was precise in the details
 Looking forward to reading you
geecab
« Reply #393 on: June 10, 2024, 07:23:11 am »
Great stuff GPForverer2024!
I really appreciate you giving D7 a try and thanks so much for your feedback too! I'm a bit confused by a few things you mention so please can you help me clarify them:
When those dashboard indicator lights are off, you should see a very faint grey image of them. They are tricky to see, but if you lower the DISPLAY menu_contrast option that should help?
Do you mean when you exit the in-game config editor, sometimes the wrong bezel image (primary/secondary) is showing? If so I think I've seen this.
>>I also noticed that the RevCounter, the needle goes up too fast compared to the sound of the motor and the needle far exceeds the number 320 of the meter On the other hand, the speedo is impeccable.
I think you are your saying you are happy with the gauge on the left (which is the revcounter), but there are issues with the gauge on the right (which is the speedo) exceeding the 320km/h reading? If so, I totally agree with you.
I think I understand where you are coming from. I was going for a well used/burnt bezel look, giving the impression the back lamps had been running hot for ages. I also wanted there to be light bleed / glow. Without it, the 'light-up' effect didn't look real enough. I think I was going for something similar to what you see in this video:
The glow from the Monaco GP letters shouldn't reach the sega logo (I don't think, I'll check later to make sure). Is that what you mean?
GPForverer2024
« Reply #394 on: June 10, 2024, 01:31:46 pm »
Hi GEECAB!!
sorry I'm going to be a little more precise
 1) During the first configuration for the resizing of the score window by pressing Tab the new widgets you can hardly see them alone the fuel logo flashes so you have to rely on this one in value to be able to adjust the
 other widgets which are in black it is still feasible but you don't have to be in a hurry to adjust everything well, it would be necessary that when you press TAB all the widgets are on, I don't know if it's feasible?
2) Yes the primary and secondary bezel are displayed at the same time during the first configuration, it is imperative once you set up to restart the game so as not to have the 2 windows displayed at the same time
3) Yes the left rev counter works perfectly the one on the right the speedometer the needle goes up too fast and exceeds 320 km/h (FYI I switched the left and right of the speedometers because the rev counter in
 Europe is on the right lol)
4) you make me smile when you see I know where you're from lol Yes a burning effect would be great so I think the outline of Monaco GP should be less pink or more pale yellow right?
And yes the Sega logo is impacted by the glow of the letters of Monaco GP I hope
As soon as the new version is ready I'll make you a nice video of my MONACO GP REMAKE ARCADE
 I helped you See you soon ;)
geecab
« Reply #395 on: June 11, 2024, 03:09:14 pm »
Hi GPForverer2024!
1. Regarding the dashboard indicator lights - Have you tried going into the in-game config editor, and changing the DISPLAY OPTIONS -> MENU_CONTRAST option? If you lower its value to 0 that should help you see the dashboard indicator lights better.
2. I'm still a bit confused, but I think what you are noticing is that secondary bezel sometimes doesn't resize properly after exiting the in-game config editor. If so, I know why this is happening now, I will fix this.
3. Ah that make sense now you swapped the gauges over lol! I'll fix the speedometer exceeding 320km/h.
4. Regarding Monaco GP outline being less pink. I have to say, I quite like it 'as is' but I will have a tweak of a few things and see what I come up with. I think what might be a good I idea is if I just post my designs as images on here and you can pick the one you think looks best. Then we are both happy I'll put that design into v1.5.0D8.
Thanks again for all your help getting these bugs ironed out :)
geecab
« Reply #396 on: June 15, 2024, 05:52:40 am »
Hi GPForverer2024!
How about these? Monaco GP letters I've reduced glow and redness. The Sega logo I've removed glow.
GPForverer2024
« Reply #397 on: June 16, 2024, 07:37:50 am »
Hi Geecab!
 1.Yes indeed I have modified the value of the option-Menu_Contrast and we see much better the dashboard widgets
 2. yes for the first time you configure the resizing of the dashboard the secondary frame is displayed at the same time you have to reboot the game
and for the new photos of the Monaco GP which shines with these new colors for me I really like !!!! ;)  thank you
xfassa
« Reply #398 on: June 16, 2024, 05:03:15 pm »
Geecab,
Sorry for the delayed response.   I am just catching up on all the responses/posts from the last few weeks.   Looks like there may be some fixes for my issue.   I will give it a try tonight.   Before I read any of these posts,  I made/posted a few videos of my cabinet and teleport issue.   I will report back soon after trying done of the recommendations.   Thanks!!!
https://youtu.be/jrE81-RN8zo?si=v9JZ9Me2s6dEE2Iq
xfassa
