Author Topic: Patendo - upright arcade based on Project Arcade 2  (Read 6261 times)
patstg
  • Last login:September 18, 2016, 02:48:39 am
« on: August 21, 2013, 01:09:52 am »
Patendo (a portmanteau of Pat (that's me) and Nintendo -- plus it sounds like Pretendo which I also like).
As a kid, I loved my original NES console. The color scheme and graphics should be a tribute to that original machine.
This is my first cabinet. While I have a decent amount of wood working experience and am pretty handy in general, but this is the biggest project I've taken on in years. The goal is for basic MAME usage, including all the old NES games I love. Simple set of controls: joysticks, buttons, spinner, trackball.
I'm basing the cabinet off the Project Arcade 2 plans (only minor tweaks) with a completely custom control panel design.
I've spent a few afternoons on the build already and have the wood all cut up and laminated. You can see the colors here -- light gray on the top and dark gray on the bottom, just like the original NES
The control panel is a 4 player control panel with trackball and spinner. 2 Ultimarc Ultrastiks and 2 Ultimarc mag stick plus. Here's is the wood before laminate
The plan for the colors of the control panel is here
https://docs.google.com/file/d/0BxoVfJq3P2-bbXlVb0FHTURSWXc/edit?usp=sharing
I made full plans for the control panel, including a full page, poster style template
PNG: https://docs.google.com/file/d/0BxoVfJq3P2-bM0RUV2xobFcwSkU/edit?usp=sharing
SVG (for Inkscape): https://docs.google.com/file/d/0BxoVfJq3P2-bZUxEaDZ1YmRHTFE/edit?usp=sharing
Plans in SVG: https://docs.google.com/file/d/0BxoVfJq3P2-bc1Ayd1hUbGs3MHM/edit?usp=sharing
I've already had a few oops moments and a few good ideas, but I'll follow up here with some of those soon.
Wish me luck!
Seith
Re: Patendo - upright arcade based on Project Arcade 2
« Reply #1 on: August 23, 2013, 11:04:09 am »
Looks like a good start!
  • Last login:January 01, 2026, 05:29:50 am
« Reply #2 on: August 23, 2013, 11:34:12 am »
Don't angle the P3 & P4 joystick bases like Saint did in the book!!
 :soapbox:
patstg
« Reply #3 on: August 25, 2013, 06:10:40 pm »
Really? Why not angle them?
My plan is currently to have players 3 and 4 be at 45 degrees relative to the screen and exactly parallel to the line of the control panel.
Looking back at the 4 player gauntlet control panel, they did angle the players on the ends
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=AqHiyYGBJX5FlM&tbnid=l67vhRxUBuBjnM:&ved=0CAIQjBw&url=http%3A%2F%2Fwww.findarcademachines.com%2Fimages2%2FGauntlet-Control-Panel.jpg&ei=q4AaUtn9AeTg2gWt3YCwCQ&bvm=bv.51156542,d.b2I&psig=AFQjCNGm-3f5jy_9_9L9bZnihHuJyOBkwg&ust=1377554943493685
Is there some received wisdom on the boards about this?
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
« Reply #4 on: August 25, 2013, 06:39:45 pm »
I don't have a 4 player setup myself, but there is lots of advice on here that say its just a bad idea.
In summary, people tend to stand toward the screen, and the joysticks are just a nightmare to play with.
You wont get many guys on here with angled joystick setups on 4 player, and less who agree its a good idea.
Have a search around ...
sabreerbasAlpha
  • Remember those big 10ps?
« Reply #5 on: August 25, 2013, 07:53:24 pm »
+1
As its already been said. its not natural to stand side on or as mentioned 45 degrees rotated towards the screen. Its far more natural to stand straight on to an object in this case it will be the screen. Take a look at that 1st player button layout on the left. Now imagine standing straight onto the screen and the awkward angle the right arm is going to be at to play and rest your palm near the buttons.
Its your build so you do what ever makes you happy. But trust me non angled and straight on is better. Unless your going to be P1 every time In that case crack on. mate.
All that said good luck and don't forget to post your progress. The above is not a criticism just an observation from years of a completely misplaced youth.
  • Last login:Today at 04:51:24 am
« Reply #6 on: August 25, 2013, 08:25:18 pm »
The latest knock-down-drag-out discussion on the topic is here.
sabreerbasAlpha
« Reply #7 on: August 25, 2013, 09:45:36 pm »
PL1 Beat me to it. I voted a while back and it was a resounding lead for straight on. Take a look. But like I said. its your build mate just have fun with it. But do listen to the voices on these boards. There are some super talented and experienced people here my friend & The advice is usually bang on.
« Reply #8 on: August 25, 2013, 09:49:09 pm »
Although the players stood at an angle on Gauntlet and most 4 player games,
the joysticks were still oriented so UP was parallel with the screen.
Notice the joystick mounting bolts on the Gauntlet control panel you linked to.  The player is angled, but the joystick isn't.
This is how it was done on nearly all 4 player games.  There are a few that angled them, but not more than a few.
Note where UP is labeled on Gauntlet Dark Legends.
http://gamesdbase.com/Media/SYSTEM/Arcade/CP/big/Gauntlet_Dark_Legacy_-_1999_-_Midway_Games.jpg
Having them this way just works.  Give it a try both ways and see for yourself.
A few people have angled them and regret it.  A few people have said they were perfectly happy with them angled.
Most just do it right to begin with and don't angle them.  ;D
« Last Edit: August 25, 2013, 09:55:46 pm by BadMouth »
patstg
« Reply #9 on: August 26, 2013, 12:48:34 am »
Thanks for the tips on this! I didn't even think to search on this question before. It seems like forward towards the screen is the better default to start with and I can always rotate it back later if I want to try out that configuration.
I just played with my plans and it looks like I can rotate these 45 without moving anything else (which is good because I already have all the holes drilled and the CP laminated).
I actually had to add extra insert nuts once already (told you I made some mistakes).
Here are the insert nuts for one of the player 1/2 joysticks
But turns out I did it 90 degrees off (it's right in the plans, I just messed up with laying out the holes)
I was able to just add more insert nuts (I left the old ones in because I thought they were structurally better than a wood filler hole)
However, I now have the laminate on the top and I've really worried about accidentally drilling through it, which is what I did here (before the laminate was on):
Guess I'll be careful :-)
EMDB
  • Project RetroCade
« Reply #10 on: August 26, 2013, 05:41:21 am »
You could have just turned the PCB of the Ultrastick 90 degrees to compensate  ::)
