Author Topic: A Barrel of Kong (My version)  (Read 23107 times)
spaceclown
  • Last login:July 08, 2014, 07:57:23 am
  • It's not the Whistle that pulls the train.
« on: August 11, 2013, 02:57:21 pm »
Ok. So ive deceided to strat building my own. "A Barrel of Kong" Cocktail Cabinet. Here's my specs. Running Mame current version, Using Mala Frontend. Here's a current Pic. artwork is on its way.. Ill post more pics as i can. im real lazy.  :applaud: Thanks Maximus..
spaceclown
Re: A Barrel of Kong (My version)
« Reply #1 on: August 11, 2013, 03:14:37 pm »
Oh, i forgot. I have a lighted credit button under the Control Panel. Instead of paint I used vinyl Laminate only on the control panel box. I also added black t molding to the Control panel box sides and ill add it to the Control panel once i apply the overlay. I have one orange and one purple button. Im using black one player & two player start buttons. Thanks..
CoryBee
  • Bopity Boopy
« Reply #2 on: August 11, 2013, 03:17:17 pm »
Looks great so far!  :applaud:
Griff, you started a new trend.
spaceclown
« Reply #3 on: August 11, 2013, 03:53:23 pm »
It will fit in nicely with my other builds. Arcade Cabinet, Casino Cabinet & Touch Screen karaoke / Jukebox. Hey how did that Pic of my red foot tortoise's get in there? O well.  :o FYI. I used a Jack Daniel's Barrel. Cost $93 locale pick up in TN.
  • Last login:Yesterday at 10:36:29 am
« Reply #4 on: August 11, 2013, 04:32:22 pm »
Looks good!
Hey we are neighbors! I live in south central Kentucky.
TKW4rr10r
  • Trade Count: (+16)
« Reply #5 on: August 11, 2013, 04:42:26 pm »
Really? I'm only a couple hours from TN, whereabouts can one pick those up? Next time the family wants to go do Dollywood I'll have to make some space in the truck.
Edit: I need to grab me a bottle of that Jack Daniels Frank Sinatra select, too. Now I'm thirsty  :lol
« Last Edit: August 11, 2013, 04:54:19 pm by TKW4rr10r »
« Reply #6 on: August 11, 2013, 05:46:55 pm »
Hey how did that Pic of my Teenage Mutant Ninja Turtles get in there?
FTFY
:D
CoryBee
  • Bopity Boopy
« Reply #7 on: August 11, 2013, 06:04:44 pm »
I didn't even second guess why there was a turtle. I was just like, nice turtle and kept reading on......
« Reply #8 on: August 11, 2013, 06:45:27 pm »
I take it your name is Mike, bro?
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
« Reply #9 on: August 12, 2013, 02:49:14 pm »
looking good so far, I like the credit button and the T-Molding additions, taking the finish up a notch, very cool
spaceclown
« Reply #10 on: August 14, 2013, 10:18:49 am »
Here r some pics of my build. first is the barrel with the JD stamp. I then cut the top out and the sides.
spaceclown
« Reply #11 on: August 14, 2013, 10:23:58 am »
next, I stained the outside, painted the rings, cut and painted the two top rings.
spaceclown
« Reply #12 on: August 14, 2013, 10:26:28 am »
Hereare the parts i used.
spaceclown
« Reply #13 on: August 14, 2013, 10:29:19 am »
I built a shelf to put the pc on. I didnt want it sitting on the bottom of the barrel and the control panel/monitor box might not of held it. i just trhew it together.
spaceclown
« Reply #14 on: August 14, 2013, 10:35:54 am »
For the Control Panel I used the artwork as a template. I then drilled holes for the buttons and joystick. lastly i routered the edegs for Black T_molding to go on later.
spaceclown
« Reply #15 on: August 14, 2013, 10:40:54 am »
For the box i used the monitor to determine my size. If youll notice the screen width is the same width as the control panels.
spaceclown
« Reply #16 on: August 14, 2013, 10:47:54 am »
Here r my speakers. just $20 dollar USB powered ones. I had to find real small ones as I didnt have more than 2 inchs of space between the control panel and the monitor and I didnt want to put them on the side of the barrel. Would just throw the whole thing off. ;D
lcmgadgets
« Reply #17 on: August 14, 2013, 10:51:23 am »
Those r some sweet builds!  :applaud:
Professor Hayashida
spaceclown
« Reply #18 on: August 14, 2013, 10:53:57 am »
I forgot to take a pic of cutting a hole in the front of the box for the credit button.  :( Next was the vinyl laminate and T-Molding.
spaceclown
« Reply #19 on: August 14, 2013, 10:55:50 am »
I added a speaker cover and lighted credit button.
spaceclown
« Reply #20 on: August 14, 2013, 11:04:42 am »
here are some other parts. I used an X-Arcade board for the controls as it plugs right into a USB port and is easy to config with MAME. I added a fan to keep everything cool. I put a fuse Power box to plug in the power cord. For volume control a wired a Dual Ganged audio tapper. Im using an electronic control relay running of 12 volts on the PC power supply that will turn my monitor on when i power up the PC.
spaceclown
« Reply #21 on: August 14, 2013, 11:07:48 am »
Here is a look into the belly of the beast!! >:D
spaceclown
« Reply #22 on: August 14, 2013, 11:18:30 am »
So here it is almost done. just need my artwork printed to finish the control panel. I also need to figure out a way to secure my control panels to the box. I was thinking on using magnets since i need to remove them first if i ever need to take the box out. there's also a cool pic of the back showing the Volume Control, Fan, etc. :applaud:
spaceclown
« Reply #23 on: August 14, 2013, 11:24:02 am »
I made up an instruction card even though Mala has instructions on the screen I needed something to show how to exit a game and get back to Mala. It doesnt work though. The wife & kids still ask me how to work the thing. LOL..   :P Thanks for looking. Im sorry to post so much at once. Ill do my best to explain anything in more detail and to answer any questions. Ill post more as i complete the build..
Maximus
    • Arcade Icons
« Reply #24 on: August 14, 2013, 11:59:50 am »
nice instruction card, I like it!!
Are you going to shim the cuts in the barrel so they mate up with the CP properly? I had to do that with mine..... it sucked.
spaceclown
« Reply #25 on: August 14, 2013, 12:30:37 pm »
Im actualy just going to leave it like it is because my control panel box slides out from the 2 player side. If I Added slats on that side i couldnt get the panel out. I could add them on the one player side though.
I was thinking about attaching the slats to the cox on the 2 player side and attache them to the barrel on the one player side. that way i could still slide it out and have slats.
Them main thing i dont like would be having slats without a band on it.  ;)
Maximus
    • Arcade Icons
« Reply #26 on: August 14, 2013, 12:37:50 pm »
Yeah it's a tough cut to do in the first place and I hear you on the band.
AGarv
« Reply #27 on: August 15, 2013, 10:21:38 am »
Very cool, it looks like the Barrel of Kong is turning into a sub-type of MAME cab.  I can see why - much more wife-friendly than traditional cabs. I live in Lexington KY so bourbon barrels are readily available...
eds1275
  • Last login:March 11, 2026, 11:07:08 am
  • Rock and Roll!
« Reply #28 on: August 15, 2013, 04:45:59 pm »
The way I made arcade machines wife friendly was to give her $20 in quarters and made her play arcade games until she was hooked.
MastarArcade
  • Last login:May 20, 2014, 02:42:08 pm
« Reply #29 on: August 16, 2013, 12:29:38 pm »
Just wanted to say that this is an awesome concept, and thus far, looks great.
spaceclown
« Reply #30 on: August 17, 2013, 06:20:22 pm »
Got my CP Overlays today. Here are some pics with the overlays on and T-Modiling around the Control Panels. Ill post process pics later. I lost my camera cord.  ???
spaceclown
« Reply #31 on: August 19, 2013, 09:38:37 am »
As promised here are the pics of the Overlay  & T-Molding install on the Control Panels. The artwork is great nice and clear. Game On Graphics does a really good job printing these out. Ive used them for all my builds. Only took 2 weeks to get, including shipping. ;D
spaceclown
« Reply #32 on: August 19, 2013, 09:46:33 am »
Had a thought last night. I dont like the size of the HAPP Dust Washers around the joysticks. they just are to big and cover more of the art work than i like. So i have decided to get custom cut and printed ones. Here is my design. These will only cost $12 including shipping. Im using the Sanwa JLF joystick size (with shaft cover). These are smaller which will show more art work and will fit closer to the joystick shaft as the diameter of the washer hole is smaller than the HAPP ones im using now.
jmike
« Reply #33 on: August 19, 2013, 09:59:32 am »
Really like that custom washer. Is it a local vendor/fellow member on this site?
spaceclown
« Reply #34 on: August 19, 2013, 10:12:57 am »
They are from a website. "Art's Hobbies". They do alot of custom Fighting Stick mods. Most everything is on either acrylic or plexi. They have some cool stuff. I was thinking bout making a couple of fighting sticks for XBOX 360 or PS3. Just google them. I dont no the policy on posting links. sorry.
MastarArcade
« Reply #35 on: August 19, 2013, 01:00:08 pm »
...so I previously posted earlier in the thread about how I thought this was a cool concept.
Later on that evening, I went home and showed my wife, and amazingly she not only agreed, but she is now on the hunt for a barrel and is on a mission to get me to build this :o
Thanks to both griffindodd/Maximus & spaceclown for the inspiration  :applaud:
Do you mind me asking what the dimensions were of your barrels?
Maximus
    • Arcade Icons
« Reply #36 on: August 19, 2013, 01:40:17 pm »
I love all the extra touches you are adding to this especially the FE theme, looks great.
  • Last login:Yesterday at 04:20:03 pm
« Reply #37 on: August 19, 2013, 03:53:19 pm »
I dont know the policy on posting links.
Sounds like you haven't read the rules yet.    ;D
Nothing wrong with posting links as long as you don't run afoul of rule 5 by posting links to X-in-1 boards, ROMz sites, etc.
5. Nothing illegal! Do I even need to explain this one? Need a ROM to repair an arcade board you own? Fine to talk about. Need a ROM to complete your MAME collection? Don't bother to post here. If someone posts such a request, please don't answer it -- no direct answers, no hints, no private messages.
It's always good to hear reviews of vendors in addition to the usual sources.
spaceclown
« Reply #38 on: August 19, 2013, 08:46:36 pm »
Yeah its a MALA theme. Here are some pics of the PC starting up and MALA running.
1st is the PC logo. which used to be the windows logo. I replaced with my own. That white ball is the flash on my camrea and not part of the logo. Just imagine its not there. LOL  :laugh2:
2nd is the windows desktop. Its only up for a second before MALA but looks cool better than the standard theme.
3rd is the Front End MALA. as you can see when you scroll through the games it changes the picture and shows a picture of the actual game Marquee with an in game snap I took. It gives a description of the game and even a counter of how many times a game has been played.
last is a load screen right before the game starts. Just adds to the excitement and gives time to take a sip of beer or wine before you start..  :P
« Last Edit: August 19, 2013, 08:49:11 pm by spaceclown »
blashyrk
  • Last login:May 14, 2017, 02:56:16 am
« Reply #39 on: August 21, 2013, 10:50:50 am »
Very nice, damn now I want one. What kind of monitor do you use ?
