Author Topic: My version of the Knievel "Woody" slim LCD...  (Read 26027 times)
Hockeyboy
  • Last login:April 17, 2022, 02:48:38 pm
« on: July 29, 2013, 12:50:22 am »
Well, I have been on this forum for years, waiting for the day to arrive when I could say that I've built my cabinet. Okay, to be honest...*started* my cabinet.  :laugh: That day has come.   :applaud:
First off, how in the hell do some of you woodworkers out there do it? I've got a table saw, a table router, a handheld router, palm sander, scrolling jigsaw, and power saw, but when I start cutting my first pieces everything looks like crap and I have to re-do some cuts or even some pieces.  :cry: And I thought I had some skills... :dunno
Right, enough crying and ranting  :badmood: - on with some build pics! These first four are showing the pieces of 3/4" birch plywood cut for the CP box. Much like Knievel's Woody clone, the box is 14"x33" (wood cut to 12.5" x 31.5"), with the sides rising from 4.5" to 5.5" to get a slope for the CP top.  I also built the base from standard 2x4 pieces with a 1/2" square of MDF screwed into the top (no picture of that).
« Last Edit: November 10, 2013, 07:17:36 pm by Hockeyboy »
Hockeyboy
Re: Yet *another* Knievel "Woody" slim LCD clone...
« Reply #1 on: July 29, 2013, 12:57:59 am »
These next four pics show the CP box cut, dry fit, and held together with a pair of strap clamps. I went to both Home Depot and Lowe's but couldn't find the ones that are about 3" wide that I've seen others here on this forum use. I am thinking that these two 1" wide strap clamps will hold the CP box together just fine as I glue (and screw from the inside only).
Question: the cut pieces are around the bottom board for the CP box - can I just run beads of glue along the bottom board edge where it meets the side pieces, bead some glue along the corner seams, and use those angled pieces of wood with screws to effectively hold everything together, or am I going to have to release the straps, put glue along each and every mitered edge, and glue along the edges where the sides meet the bottom board, and then re-tighten the straps?  Yeah, the answer is obvious: I need to glue the edges of the boards and re-clamp everything and hope that I can still do fine alignments with the clamps and hands before the glue dries and sets.
« Last Edit: July 29, 2013, 09:18:22 pm by Hockeyboy »
Hockeyboy
« Reply #2 on: July 29, 2013, 01:00:15 am »
I've got a scrap piece of the birch plywood and picked up two small cans of stain. Here's what the color looks like with just one coat of the Minwax Poly Shades (thank you again "Master" Knievel for the great idea).
Hockeyboy
« Reply #3 on: July 30, 2013, 03:00:36 am »
How does the saying go: 1 step forward, 2 steps back??  Today I went out and bought the 4' x 8' sheets of birch plywood I will need for the sides of the cabinet, plus some furring strips that I will use to hold the front and back pieces to the sides. I also glued the CP box together and then...disaster... I removed my strap clamps about 4 hrs after gluing to check on things and found out I must not have used enough glue because 2 of the CP side pieces just fell over, and one of those pieces fell onto the garage floor, damaging the corner.  Looks like I'll need to measure and cut another piece... :angry:  Well, maybe it was just 1 step back with 2 steps forward because when I was looking at the bottom of my CP box I had just glued together, I suddenly realized why Knievel mitered not only the edges of his CP box all those years ago, but the bottom piece was angled/mitered on every side as well. Why? Because otherwise you have edges of your CP box showing from underneath, and since I am staining this cabinet, I can't have any cut edges showing. If you look at these 2 pics (from Knievel's build), you'll see what I mean. Unless, someone who has built a Woody-style cabinet has a great alternative idea to this??
Anyway, I've got one 4' x 8' plywood sheet laid out on a table, and have started sketching up dimensions and transferring those onto the sheet. Hopefully tomorrow I can do at least a rough cut on one side of the cabinet.
Hockeyboy
« Reply #4 on: August 04, 2013, 12:34:16 am »
No replies? Comments? Questions?
A little more work today - I followed up from my little mishap last week and re-cut my CP box piece that got damaged, and re-did another piece. I can see why so many people just paint their cabs, or put laminate on, or do anything besides use furniture-grade plywood and stain because everything has to be perfect or all the flaws in your workmanship will show. The CP box is now glued on the four sides with some blocks screwed in at the corners to give added support. Also, I mentioned in my last post that the edges of the plywood were going to show, but I think I found my workaround/fix/solution: veneer edging, and it's even birch to match my plywood!
Hockeyboy
« Reply #5 on: August 04, 2013, 12:44:17 am »
Also, the base dimensions were wrong...I don't know what I was thinking, but now it is cut to be 18" deep by 23 1/2" wide (inside dimension) so that when the plywood sides are attached, for a total of another 1 1/2", the width of the cabinet will be 25" (not counting the control panel) and the depth will be right around 20" deep at the bottom. I really like the slim style of Knievel's Woody, but I also think I am going to add 2-3" -- it shouldn't hurt anything and might even be more stable. [face-praying] I also cut down the piece of 1/2" MDF base to match (it had already been attached), and re-attached it. The last two pics are the scrap piece with 2 coats of the Minwax Polyshades, and a pic showing the colors. Of the two I picked out, I think I really like the one on the left: American Chestnut Satin.
I have rough dimensions sketched out on the huge piece of 4' x 8' plywood, but I need to cut that sheet in half, then start cutting out one side. Hopefully all goes well because these are expensive sheets: $52 each at Home Depot.
dfmaverick
« Reply #6 on: August 04, 2013, 01:44:47 am »
Knievel made his Evolution cab 6" deeper than the Woody, so adding depth should look fine. I actually like the profile of his Evolution over the Woody.
I also recall reading that Knievel would rather have laminated than stained after he found a matching laminate once he was already done.
Looking good so far. I like the darker color also.
Sig00
  • Last login:July 03, 2021, 06:12:55 pm
« Reply #7 on: August 04, 2013, 09:25:47 pm »
Not many comments yet. o.o Looking good, glad you haven't let the mishaps hold you up too much! I'll be watching your thread and hopefully pick up a few things I didn't think of (just started my own 32" LCD build about a week ago as well) already. Lookin' good, keep it rolling!
Player 3
  • Last login:December 21, 2014, 08:21:49 pm
  • The Alternative Idiot
« Reply #8 on: August 04, 2013, 11:49:40 pm »
Don't act like another Woody-like is bad. It's a nice cab if you ask me.
Brian74
  • Yep... I built that!!
« Reply #9 on: August 05, 2013, 12:47:57 am »
I know how you feel when you screw something up and have to redo it. My woodworking skills suck  :censored: Thats why I reuse cabinets. I can handle making a new cp, thats about it. Looks good so far, keep going.  :cheers:
Hockeyboy
« Reply #10 on: August 05, 2013, 04:06:49 am »
He did state that, and while I thought about it for a while, after doing some research I found that buying 5/8" MDF and 1/8" laminate together would have really made my materials costs much higher.
Nope, if I've got one thing going for me, I'm stubborn, lol!  ;D  I've learned a few things over the years, and that is definitely helping.
Yeah, true, and after some searching on these forums, I haven't seen many others try the natural wood with stain, so I am really hoping it all comes together.
I'm finding it's not really my skills that are lacking, but the precision of my power tools. The table saw I bought *years* ago cost right around $200 - it's a Delta, and while I can tilt the blades up to 45 degrees to get angled cuts, the fence that came with the table saw is not great, causing me to re-cut some of my pieces.
Thanks for the support!! Updates tomorrow, with new pictures.
Hockeyboy
« Reply #11 on: August 05, 2013, 08:49:43 pm »
Today was spent doing the "mirror image" - where you take your first side that you've cut out and make an exact mirror image. I know it's been discussed in the past, but this is how I did it:
1) Take the side that's already cut out and lay it "upside-down" onto your blank sheet of material.
2) Trace your piece you have already cut using a pencil.
3) Remove cut side and temporarily store.
4) Take a jigsaw and cut close to the pencil lines, giving yourself no more than 1/4" of extra material.
5) Place your newly cut side down, and your first side on top, carefully lining everything up around the perimeter and clamp around the edges.
6) Carefully flip both pieces over, so that your first side is now on the bottom, and your piece to be final cut is on top.
7) Run your router with the flush trim bit with bearing around the entire perimeter, going back as needed to trim away excess.
There was TONS of sawdust when I did this, even though I trimmed down to about 1/4". It got all over the driveway, me, my wife's car... :-[...uh-oh...I offered to run it through the car wash but she said it will just get more sawdust on it so don't worry about it now. I did take my leaf blower and blow most of it off for her.  I can easily see why people who make their cabs from MDF talk about the wearing of a dust mask -- there's gobs of sawdust and because you have to bend down to carefully watch your router as it's running, you get a constant stream of sawdust blowing right towards your face. Good thing I was wearing safety glasses.
The 3rd pic is a close-up of the cloning process where I had to stop and move the clamp so I could continue with the router.
The 4th pic - success!! The two pieces look identical! I am glad I added in an extra 2" - I like the way this looks.
« Last Edit: August 07, 2013, 03:12:09 pm by Hockeyboy »
Hockeyboy
« Reply #12 on: August 05, 2013, 09:06:19 pm »
I also cut out the t-molding slots after I finished both pieces. Measuring the depth isn't that hard - just get the middle of the 3-wing slot cutter to 3/8" and you are set. I also made sure the nut on the bottom of the bit was on very tight as I remember reading on someone's project how their slot cutter almost got away from them, or was loose, or something just like that. The last thing I need right now is to have my slot cutting wing fly off the shaft and catch me in the flesh.  :(  Anyway, the test cut on the scrap looked to be perfect to me, so away I went. Just have to remember to slow down when hitting your corner or your edge and you'll be fine. Also, do NOT try to pull your router out of the slot when you finish a side or corner because you'll unavoidably tilt your router and screw things up. I found that out during the test cut. Anyway, 2 sides, with slots!!  :applaud:
I also cut out some other pieces, but haven't taken pictures of those: the speaker plate/shelf, the admin panel, the toe kick plate, the monitor cut-out plate (made from 1/2" MDF), the monitor mount (4 holes drilled so screws will go through it into the holes in the back of the monitor), and a couple supports that will stretch across the cab in the back. If you go back and look at Knievel's Woody, http://forum.arcadecontrols.com/index.php?PHPSESSID=06da047e48b2b66c8b8820ed5c4bb21f&topic=55789.0;all you'll notice in his first pic he posted, the side of his cabinet has some slots along that one edge (I included the pic below, #4). Knievel used biscuits to join up the large back piece to his 2 sides and made his door at the bottom front of the cabinet. I, on the other hand, am going to use a 2'x4' sheet of the birch plywood (that was picked up in another section at Home Depot and it will be trimmed down to 23 1/4") as my door in the back, so I won't have the same strength he had by using biscuits to join things together. So, I'm going to glue and screw supports on both the front and back to help hold the front, back, and side together.
(Edits for typos)
« Last Edit: August 07, 2013, 03:15:22 pm by Hockeyboy »
Hockeyboy
« Reply #13 on: August 12, 2013, 12:11:20 am »
A couple days ago it was my birthday, but I decided to do some cabinet work anyway (I took the day off from work).  ;D  I mentioned before that I used the Minwax Polyshades...well, the first coat looked great on two of the small pieces, but when I tried coating a couple larger pieces...  :angry: ... it's not easy to work with, it "blotches" easily, and you can't go back and touch up any areas because the polyurethane is mixed in and it will just smear. So, 4 pieces, including my big back piece of 23.5"x48" - ruined.  :cry:  There's also 3 trips to Home Depot to get the right color of stain, more hardware, more wood (I grabbed another 2'x4' "project panel" to use as the large back piece), and just more planning and thinking.
I think I've got all the pieces cut out now - at least, the pieces of the 3/4" birch plywood. They are all sitting in the garage, with a fresh coat of pre-stain wood conditioner, and I'm about to sand them smooth once they are fully dry. There's also a tall picture of the two sides stacked against each other, and you can see all the furring strips are in place. I think I'm about ready to start assembling!
I'm going to go with 3/16" tinted/smoked tempered glass, with some holes pre-drilled in the corners so I can mount it to my bezel cut-out.  Question: Is there another way to mount glass to the front of the cab?
Hockeyboy
« Reply #14 on: August 12, 2013, 12:14:07 am »
After trying to unsuccessfully take the stand and make it completely square, I decided to try something different. I mitered the 4 pieces to have 45 degree corners and used metal brackets to hold everything together. It was more work, but in my mind, it was worth it because now it's square and doesn't wobble at all...I grabbed another stud from Home Depot to build this, just in case the 2x4s I had were slightly warped. It's upside-down so you can see the brackets in the corners.
talkgeek
« Reply #15 on: August 12, 2013, 06:38:33 am »
 :applaud: I'm keen to see how you progress - I think the "Woody" is a classy build (and possibly one my wife would allow in the house) .. but my cabinet making skills are far to basic at this stage to attempt - will just have to experience it vicariously through your posts  ;D
Hockeyboy
« Reply #16 on: August 12, 2013, 01:43:33 pm »
Oh, hey, I'm quickly finding out my cabinet "skills" are far less than I thought they were.  :laugh2:  Thank you, though.
Seriously, this build has been fun for me, even though I'm progressing at a slow speed vs Knievel's original Woody (that he put together in...what...3 days?  ;D).  I've been on this forum for years, reading, researching, and wishing...and now that I've finally started, I'm finding that careful planning can only go so far. And, I just haven't seen that many actual Woody cabinets - meaning ones that are made with actual cabinet-grade plywood. There's another person here, Ambush, who put together a similar build (about two years ago now?), but even he went the primer-and-paint route.
mcseforsale
  • Creepy Mario Dude
« Reply #17 on: August 12, 2013, 01:52:12 pm »
Looks great.  Subscribed
AJ
AGarv
« Reply #18 on: August 14, 2013, 01:52:41 pm »
I have always liked the appearance of natural wood cabs - looking forward to seeing this one after it is stained!
Drnick
  • Plodding Through Life
« Reply #19 on: August 14, 2013, 03:13:31 pm »
There are many ways of dealing with this.  In my bartop I have a support piece under the bottom of the glass with a groove cut into it. The glass slots into this groove The rest of the glass sits up against the monitor bezel which is supported from behind.  Once the control panel goes into place the glass cannot go anywhere. On Kneivels design it looks like he has a gap between the bezel and the front admin panel I can only assume that he has a support bar of piece of channelling for the glass to sit in just above the buttons. Unfortunately I couldn't see an image of the admin panel from the back.
It doesn't look like it makes for a quick and simple removal of the glass but it does look clean and neat. I would not get Holes drilled unless absolutely required. I can see it required for a pedestal style unit with a completely flat face, but not on a cab with an angle.
mcseforsale
  • Creepy Mario Dude
Hockeyboy
« Reply #21 on: August 14, 2013, 05:45:21 pm »
Well, the last couple of days have been spent doing last cuts, sanding, and prepping for stain. Prepping = applying Minwax Pre-Stain Wood Conditioner to everything. This is a plywood product and the actual birch veneer is thin so I don't want the stain to color any large swirls or spots darker than others - an even finish is what I am shooting for.  I had several of my pieces laid out and forgot to take a picture of them before and after staining -- I set them aside to do the large pieces (specifically, the large pieces entail the back door and the 2 sides). The stain color is Minwax Gunstock #231.
Pic #1 is one of the sides, interior shown, with stain around the edges. When this is all put together, in some of the areas, the other pieces will be recessed and I wanted to make sure you still see stain everywhere you are supposed to.
Pic #2 is the back door - 23 1/2" x 48" - all stained. Yes, I'm doing my door in the back, not the front. I'm hoping that doesn't turn out to be a bad decision from a structural standpoint, but I've also got a couple braces that I am going to put in the back to help hold everything together.
Pic #3 is one of the side pieces, laid out, ready for staining. The birch plywood is very light in color. Makes me wonder if I should have gone with the Red Oak in the first place??  :dunno
Pic #4 is fresh coat of stain, still wet. Damn, I sure wish it looked like this after wiping. I love this rich color.
Pic #5 is both side pieces, stained and wiped, very close to each other to see the color comparison. Both of these were cut from the same large sheet of 4' x 8' birch ply, but sometimes there are swirls or wood patterns that are more prominent on one side than the other.
I'm hoping that when I finish these with urethane, the color will deepen just a little.
Hockeyboy
« Reply #22 on: August 14, 2013, 09:12:19 pm »
Earlier, I forgot to mention that some ordered parts had arrived. The threaded wood inserts for mounting the motherboard, amplifier (and other computer parts), the Y-splitter cable that goes from 3mm headphone jack to 2-RCA plugs (because that's what the auto amplifier uses as inputs), the 20W auto amplifier for the speakers, the 12VDC adapter to power that amplifier, and 40 ft of textured leather t-molding from gamemolding.com. The website wasn't taking payments last week, but on the home page, the site owner, Preston, had put a message saying just shoot him an e-mail. Well, in less than 2 days of e-mailing my order and getting an invoice, my order was shipped, and arrived in just 2 business days! And, while I'm not going to say one site is better than the other, gamemolding.com charged me about half of what I was going to pay over at t-molding.com -- I just wanted to give Preston a big thank you for being so quick with the order. I put a small piece on one of the smaller boards and it looks great!
mcseforsale
  • Creepy Mario Dude
« Reply #23 on: August 14, 2013, 09:21:52 pm »
+1 for Preston.  He helped me out on my woody/revolution as well.
AJ
Hockeyboy
« Reply #24 on: August 15, 2013, 09:04:33 am »
I'm gonna have to do some more looking to see what you guys mean -- if I understand correctly, the glass will sit behind the small admin panel (that will be sitting just above the control panel) in a little groove and the CP box + the admin panel will hold the glass in place?  Sometimes it's a pain to be a very visual-oriented person.  :-\  I don't want to have to drill holes in the glass, but the glass shop said they will do it, no problem, and I'd use black painted screws and black neoprene washers on both sides of the glass to keep it from cracking. I can get 3/16" glass, about 2'x2', for about $60, and for abour $90, they will temper it. Either way, they can also tint it as well for those prices.
dfmaverick
« Reply #25 on: August 15, 2013, 09:17:18 am »
Knievel tries to show how he did it in the Evolution thread:
The glass slides up behind the speaker panel and then the bottom drops into a slot routed in the top of the admin panel. I use 1/4" thick glass so it's heavy and won't go anywhere.  :)
Here's a pic, different machine but the same idea..
« Last Edit: August 15, 2013, 09:21:21 am by dfmaverick »
Hockeyboy
« Reply #26 on: August 15, 2013, 09:38:50 am »
Ah, thank you!!  I had seen that thread before, but didn't pay close enough attention to that detail. Perfect -- now I don't have to have holes drilled!
Okay, another question: what percentage of smoke/tint am I supposed to ask for on this piece of glass? The bezel area around the monitor is going to be painted flat black.
Thanks again to all who are helping me out on this -- this isn't supposed to be rocket science, right?  :D
mcseforsale
  • Creepy Mario Dude
« Reply #27 on: August 15, 2013, 09:43:18 am »
I got the transparent solar grey from Tap.  I just sent them an email asking for the gradient of the plexy.  We'll see if they respond.  But, it's nice and smokey and not too dark.  I only had to up the brightness on my NEC Multisync 19" by a couple of quick pushes of the button.
http://www.tapplastics.com/product/plastics/cut_to_size_plastic/acrylic_sheets_transparent_colors/519
AJ
mcseforsale
  • Creepy Mario Dude
« Reply #28 on: August 15, 2013, 11:01:11 am »
OK,
Dave over at Tap just emailed me back and said that the solar grey is 27% light transmission.  Good to know.
AJ
Hockeyboy
« Reply #29 on: August 16, 2013, 07:58:40 am »
AJ
Thanks again. Now I've got another decision to make - glass or the TAP plastic (acrylic)?? It's not the cost - a quick calculation showed the TAP order would only be ~$40 - but which is the better way to go.
Also, I've been thinking of various ideas and names for this cab...my wife came up with In The Doghouse... :laugh2:  I get it, honey... :lol  I'm leaning towards Rainy Day Games because I live in the greater Portland, OR area, and it rains a lot here.  Around the text I'd have several of the video game characters, and maybe some sort of rain-streaked background.  We'll see...
« Last Edit: August 16, 2013, 08:39:22 am by Hockeyboy »
mcseforsale
  • Creepy Mario Dude
« Reply #30 on: August 16, 2013, 10:09:20 am »
I'd say with the relative humidity of your area, you should be fine with Tap.  In drier climes, I'd recommend glass since it is less static prone.  The only problem with plexi is you can't, and I MEAN YOU CANNOT use windex on it.  I use a light carnuba on mine after I clean it with soapy rag...oh, and no paper towels.  Paper towels have fibers in them that are harder than even glass, so eventually it'll haze.
I have nothing but good to say about Tap and my plexi.  It came cut to EXACT measurements and fit the first time.  It also came FAST.
As for glass, you'll need tempered if you have kids, or rowdy buds.  I simply couldn't find a glass shop in my area that would take my order for less than $120, so I went with Tap.
AJ
AJ
Hockeyboy
« Reply #31 on: August 20, 2013, 01:51:06 am »
Okay, I've been having some fun, and some tedious time this past week. Mostly, I've been finishing up staining, then applying coats of urethane, sanding, and applying another coat of urethane. Most pieces now have 3 or 4 coats except for the 2 big side pieces that don't have any urethane yet.
Following the direction and advice of mcseforsale, I ordered my sheet of acrylic from TAP plastics. Solar grey, 3/16" thick. Then I thought: how am I going to insert the acrylic? He pointed to the way in a picture, and I figured I better cut a slot in my admin panel...but how? Aha, I've got it! Turn my table saw into a dado cutter -- set the blade depth by turning the blade depth crank to 1/4", set the fence to 1/4" wide, and make a pass. Perfect! One narrow slot, 1/4" deep. Now, adjust the fence, make another pass, and nibble away some more. One more adjustment, one last pass, and now I've got a little square groove/slot that is 1/4" x 1/4" at the top of my admin panel. My acrylic is 3/16" so it should fit just fine.
I've been going back and forth on what to do with the actual computer. I really don't want to just keep it in a case, especially since I got one of those tall CoolerMaster Hyper212 heat sink/fan units -- those things won't fit in just any case. I want to mount all the computer parts onto a board, and I've got the threaded inserts, nylon stand-offs, and long screws to mount the motherboard, so that part is easy. But, how and where do you mount the hard drive? Do you mount a DVD drive, or do you even need one in there after you've got everything loaded and installed? What about the power supply?? Lastly, the video card tips back and forth because it's not mounted or screwed down like you would do in a case - how do you keep that from moving? :dizzy:  Yeah, a lot to think about...also, is Windows XP a good OS to install all this with for a MAME PC? I've got copies and licenses for XP, but I've also got the Windows 7 install DVD and I could just install that into the PC and not do any updates or registration? (Also, the Windows 7 install DVD is a 64-bit install...of course I want that for my gaming computer, but I really don't think I'd need all that extra horsepower and speed for a MAME PC.)
I had a small mishap tonight. After staining and applying 3 coats of urethane, and after cutting my slot for the acrylic, and even after gluing on some of that birch veneer edging and staining that, I decided to drill the holes for the admin buttons...man...as the 1 1/8" spade bit was rotating, the drill jumped in my hands and popped out and made a scratch in the wood just beneath the button hole.  :badmood:  I dabbed some stain in the gash, but since it's through the veneer, the coloring doesn't look right, even with a button in place. And, my wife was quick to point out that I would know it was there...all...the...time...and it would just drive me crazy. Yeah, she's right, it would. Well, luckily, now that I knew how to build this piece, doing another one took all of 15 minutes to re-cut. Lesson to be learned? Do all your cuts and drilling before you spend a bunch of time doing the finishing work.
I also ordered 2 Logisys CCL front light bars. http://www.outletpc.com/c7918.html  I may need only one, but I ordered 2 just because I don't know how much light they put out.
Okay, the pics!
#1 is the square slot I cut out using my table saw. Look at the bottom.
#2 is the CP box, flipped over. You can see the bottom board and the plywood boards that form the box - they have the birch veneer glue-on strips and are stained as well. Not many people are going to get on their hands and knees to look at the bottom of a control panel, so I think it will look fine.
#3 is my mishap piece and the new board, already cut and 'slotted' with the square slot. I put the Minwax Pre-Stain Wood Conditioner on and wiped off the excess, but I won't apply the first coat of stain until tomorrow when it has a chance to dry fully.
#4 both speakers mounted in the plywood piece. The open style grilles were painted flat black by me - the original color was a silvery grey. The silver that you see is part of the actual speaker.
Hockeyboy
« Reply #32 on: August 27, 2013, 02:41:21 am »
Okay, more updates...everything is now stained and protected with urethane, 3 coats everywhere. I've been doing that the past several days after coming home from work, light sanding and then a coat of urethane, that is. I've also been in touch with SlammedNiss who sent me a sheet of the button stickers (those arrived in the mail -- thanks Slammed!) and mcseforsale who got me the CP layout in a file - many thanks to mcse as well!
I mounted the CCFL fixtures onto an old piece of melanine-coated shelving that I had lying around. (Pic #1)
You can see they have simple connection points for 12VDC so I took a Molex connector used for hard drives and spliced it (it's the connector at the bottom of the picture). I'll just plug it into a HDD connector and since each light only uses a few millamps, I shouldn't overload the 12V rail on the power supply. The wires aren't actually connected yet - I'll do that when the power supply and the lights are installed in the cabinet so I know how long to make them. The front side is white so it will help to reflect the light forward - I actually don't think I'll need that because the CCFL is a frontal light bar, but they are mounted on it anyway. I also angled the back of the piece so it "nestles" nicely in the 2 pieces that are at the top of the cabinet and the speaker plate. (Pic #2)
This next picture shows the base glued, screwed, and clamped in place to one of the cabinet sides. The screws are 2" so they can go through the 1.5" of 2x4 and 1/2" into the 3/4" plywood, from the inside, so you don't see any screws or connection points on the outside of the cabinet. (Pic #3)
Next is the CP box, fully stained and protected with urethane. I have not made the top yet, so it's still just the box. (Pic #4)
Both cabinet sides, plus a couple braces, now attached! This almost looks like an arcade cabinet!! (Pic #5)
These next 2 are the incoming power outlet I've rigged up. The output terminals are going to be directly connected to the Smart Strip outlet - this way, I won't have to cut some weird hold into the cabinet. Well, I will, but it will be to mount this outlet switch into the back of the cabinet - probably through my door in a lower corner. ;-) (Pic #6 & 7)
Hockeyboy
« Reply #33 on: August 27, 2013, 02:50:32 am »
A couple other updates:
The lower portion of the front of the cabinet. That's not a door, but an actual panel. I set it back 1/2" from the edge, and it's on an angle from the bottom up to the point where it goes underneath the control panel. You can see at the left-hand side the "admin" panel in place. (Pic #1)
The very bottom of the arcade cabinet where my angled front panel meets my kick plate piece. A close-up view and a view with all of the cabinet. (Pic #2 & 3)
I'm ready to stand this sucker up and see how vertical looks!
mcseforsale
  • Creepy Mario Dude
« Reply #34 on: August 27, 2013, 07:17:25 am »
Looks real good!!!
AJ
Hockeyboy
« Reply #35 on: August 28, 2013, 05:30:23 am »
Didn't get a ton of time today - real life has a terrible way of creeping into this hobby sometimes. Most of the threads I've read you guys are on your second cabinet by this time.  ;D  I did, however, get to smoke/roast up some chicken pieces today on the Traeger -- my wife brined up the leg quarters and breasts and drumsticks last night and they cooked on the Traeger for about 1 hour and they were golden brown and oh-my-god-DELICIOUS!!
Anyway, back to the cabinet. Today, I actually got it set on the ground and had it standing. My god, it's a thing of beauty when you finally stand your arcade up for the first time. I brought the CP layout file over to Kinko's and the guy at Kinko's asked what I was printing out and when I told him he was sooooo jealous. "A real arcade machine? In your house?!?" Sometimes, you can't get a a big enough smug smile going.  :laugh:
Pic #1 is the back of the cabinet with the monitor mounted and the t-molding applied to all the edges. You can see a couple of cross pieces to help hold things together since I'm not gluing/screwing/biscuiting in the back. Also, it pays to do your research about applying t-molding. My son was watching me clip off spots of the spline so I could go around and into corners and said I was a genius for thinking of that. I could have run with that but I deferred to the experts here on BYOAC and said I read how to do that here. I've got two small spots where the router blade bit a little (I mentioned previously that you don't pull the router from your slot while it's still running) and the slot won't effectively hold the spline but a teeny bit of super glue fixed that. Also, there were a couple of areas along the plywood veneer where portions of a specific ply popped loose and it left some holes/gaps. I filled those areas with some epoxy resin last night to give them some strength when I tapped in the t-molding.
Pic #2 is the side, showing off the stain and urethane. The CP box is just placed on the arms and not attached yet. I wasn't really sure if I'd like that Min-Wax Gunstock color as it's a little more orange than I would have liked, but I think it looks VERY nice on this cabinet.
Pic #3 is the front with CP box. You can see I've got a front panel and a kick plate piece along the bottom. I'm still debating on whether or not to add some lighting or tiny molding to the bottom front, just to give it a little more "look" or not -- my wife actually suggested some small LED lighting running along both sides and I had to admit the lighting examples she showed me looked very nice indeed. Question is do I want to trying to bling up the cabinet??  Opinions?
So, if you look at #3, specifically at the bezel and frame, my wife had a couple of questions. Should I have a bigger monitor? It's a 19", which matches what others have done, and matches Knievel's Woody (where I got my inspiration). There's already close to 3" of frame all around the monitor and I would hate to have more frame "real estate" but she asked why I didn't mount the monitor fully behind the frame with only the actual screen showing and not the bezel of the monitor (not my painted black wood frame). I also pointed out that I need to have the frame go around the monitor so I can adjust the buttons on the monitor if needed, but that brings up another question: how do you guys turn off and on your monitor if the power button is blocked by the wood frame around your monitor? Do you drill a small finger-sized hole? Do you buy a monitor that has a remote control?
Thanks for reading through. I welcome any thoughts and opinions, and any questions.
TopJimmyCooks
« Reply #36 on: August 28, 2013, 09:15:48 am »
looks tasty.  on the monitor power, my power button is concealed.  I use a smart power strip (the good ones are $33 from newegg).  However, my display is actually not controlled by the smart strip.  the smart strip handles the marquee light and some other stuff.  many displays turn them selves off when they lose signal, ie. when you turn the pc off.  newer displays even have this as a menu option.  If you don't have that option you need a smart strip.
AGarv
« Reply #37 on: August 28, 2013, 09:38:39 am »
Looking good buddy.  For #3, I think that your current monitor size is fine.  If your monitor has a sleep function, then I don't see any issue with removing the glass/bezel for those infrequent occasions that you need to make adjustments (i.e. don't drill a hole or hack your monitor).
For the kick-plate, what about adding something to make its function more apparent and create some contrast, e.g. metals studs?  A coin door would add a lot IMO also.
monkeychunkuk
« Reply #38 on: August 28, 2013, 10:30:00 am »
Nice work I love these woodwork builds
  • Last login:Yesterday at 01:44:48 pm
« Reply #39 on: August 28, 2013, 02:36:29 pm »
Some monitors automatically switch back on when power is restored after an interruption like unplugging it or the smart strip switching off.
Turn your monitor on, unplug it and plug it back in to test this -- you may need to change a menu setting, too.   :dunno
