Author Topic: Convert Atari 2600 to multi-console (Android 2600:Part 3) - with video  (Read 8453 times)
degenatrons
Part 3 of the Android 2600 project
I bought a broken Atari 2600 VCS on ebay.  The plan is to mod it to house an Android based multi-console system.
I made a start with fitting HDMI out and have replaced the cartridge slot with USB and SD card slots.
Check out progress in this video:
The USB hub fits nicely into the cartridge slot and the USB plugs are visible after cutting the PCB hole
I made a sticker for the SD card adaptor to make it look like an Atari game cartridge:
The HDMI socket is secured with screws and I use washers to elevate slightly to fit dead centre of the hole.
Parts used:
StarTech 3 ft Standard HDMI Cable for Panel Mount - F/M - from ebay
USB Hub 4 Ports + SD Card Reader Slot for SONY PS3 SLIM - from ebay
« Last Edit: June 17, 2013, 10:00:47 pm by degenatrons »
Skivt68
  • Last login:July 21, 2013, 02:21:44 pm
  • "My blackberry's not working" (see sig for video)
Very cool idea!  I'm looking forward to seeing how this project progresses.
Change is inevitable, except from a vending machine.
:)  See my personal text:
mgb
  • North East, US
This is a neat project.
Looking forward to the progress.
Superfrog
    • My YouTube Channel
 :notworthy:
You come with some fine new ideas all the time.....
Fun projects that sometimes pops in your head once a while, and comes along, and see the daylight at Degenatrons  :cheers:
Keep them coming  :applaud:
mcseforsale
  • Creepy Mario Dude
Hmmm...I got an old colecovision hanging around.
AJ
degenatrons
:notworthy:
I'm honoured to receive praise from such a fine arcade builder.  You're the man/frog Superfrog  :cheers:  BTW You made me get into playing Popeye again!
thefox
  • Last login:November 30, 2021, 05:09:11 am
    • From The Old Arcade
« Reply #6 on: June 21, 2013, 05:20:16 am »
What a fantastic idea ! Pure genius.
My old woody 2600 still works (guess they built'em well), but if/when it stops working, I might consider this.
Born in the early seventies
Grew up in the arcades in the 80's
Built "The Fox-Box" in 2012.
https://fromtheoldarcade.wordpress.com/
SlammedNiss
  • Last login:Yesterday at 01:46:31 am
  • Mine Drags the Ground!
Do you happen to still have the cartridge slot?
Superfrog
 :laugh2: Thanks,
That's the nice thing of hanging around on fora  :cheers: everybody can read about there favorite game, build, or software thing.
I can't read all the stuff here passing by, got big eyes in the morning  :censored:
Greetings
  • Last login:Today at 02:27:03 pm
If not, Best Electronics has tons of Atari parts including cartridge slot connectors.
degenatrons
Sorry,  cartridge slot was damaged and I broke it some more during removal  :-[
degenatrons
I adapted the power socket on the 2600 to take 5V DC power.   Atari 2600 has a 3.5mm jack and I want to keep the original socket.
I thought that an iPod Shuffle charger would be a good start because it has 3.5mm jack.
It didn't work though. The ground part of the jack was not big enough for the Atari socket and electrical contact was bad.  I bought a mono jack and replaced the stereo type jack.
This gave better results.  Connections are good and tested with multimetre.  So external power connection is done.
Next for the internal power.  I soldered a mini USB cable to the socket - on the underside of the PCB.
I cut traces on the PCB to prevent the old circuit from receiving power.
I connected the mini USB to the Android stick.
Powered up and working  ;D
« Last Edit: June 27, 2013, 04:02:55 am by degenatrons »
ark_ader
  • I glow in the dark.
You should have bought one of those cheap 7" tabs or maybe one of those reversing monitors for cars for a display.
Plenty of real estate on that console.
I'm contemplating something similar but need more power.
Keep up the good work!  :applaud:
