Author Topic: The ELAMINATOR - 11/16" T-molding Red and Blue Surplus  (Read 7543 times)
rablack97
« on: April 16, 2013, 12:59:59 am »
Figured I'd try my hand at laminating, here are some pics of my current build, no real theme yet (ELAMINATOR) just sounded cool.....
Just laminated the whole thing, just to see if i could do it.....
It will be KADE driven.....COINOPS/VISION Frontend..
Need some opinions on the buttons color scheme, which one?......
T-molding will be red or black not sure yet.....
Also, might switch out the white t-ball with this....
« Last Edit: April 19, 2013, 08:34:24 am by rablack97 »
Drnick
  • Plodding Through Life
Re: The ELAMINATOR - KADE Driven
« Reply #1 on: April 16, 2013, 02:42:41 am »
Nice job  :applaud: I would go with red-red or the black outer with red button.
rablack97
« Reply #2 on: April 16, 2013, 09:09:57 am »
If i go clear, the outer circles would be lit up red and the t-ball lit it red as well.
Not sure if i should go, lit or unlit buttons.....
sharpfork
    • KADE
« Reply #3 on: April 16, 2013, 09:35:51 am »
The lamination work is really solid!
I personally don't like brightly illuminated buttons on a bartop because they are too close to the screen.  If you can light them up in a subtle way, it might be cool.  Otherwise, I'd go with non lighted.
subscribed!
sharpfork
    • KADE
« Reply #4 on: April 16, 2013, 10:05:46 am »
subscribed!
  • Last login:Today at 03:09:28 pm
« Reply #5 on: April 16, 2013, 12:36:49 pm »
For button lighting that won't sunburn your retinas, use 12v LEDs powered by 5v.   ;D
rablack97
« Reply #6 on: April 16, 2013, 12:59:11 pm »
Only the outer rings would be lit up and I have a design for the clear trackball so that not blinding either.
Its not blinding at all, very subtle, red has a 2.2 forward voltage so it's not as bright as green and blue anyway....
I'll have to wire a few up and see how it looks.....
« Reply #7 on: April 16, 2013, 01:08:50 pm »
Those are still bright as ---steaming pile of meadow muffin---.
Unstupid
« Reply #8 on: April 16, 2013, 01:25:41 pm »
I like the contrast of the red outer ring with the black plunger..  If you do go for the lighted buttons use the outer ring of the milky white IL buttons at paradise arcadeshop.
  • Online Online
  • Last login:Today at 06:17:10 pm
« Reply #9 on: April 16, 2013, 01:41:53 pm »
OK, what are you really going to call it?  >:D
« Reply #10 on: April 16, 2013, 02:00:10 pm »
Then it's time to add another resistor between the 5v supply and 5v daisy chain or between the ground daisy chain and ground. (Not to be confused with the current limiting resistor built into the LED holders.)
For an example, see R2 in the lighting circuit here.
« Reply #11 on: April 16, 2013, 02:08:38 pm »
Then it's time to add a diffuser or other means to block/deflect the light from your eyes.
Agree 100% ;D
  • Online Online
« Reply #12 on: April 16, 2013, 02:12:59 pm »
Scott- what's the value/size of that R2? 11 ohm, 1/2 watt?
« Reply #13 on: April 16, 2013, 02:29:44 pm »
The circuit uses a 10 ohm, 1/4 watt, 5% tolerance -- Radio Shack P/N 271-1301.
The extra ohm comes from the male .25" QDs on the resistor to connect to the 5v supply and the 5v daisy chain.
A 1/2 watt resistor would work just fine, but the 1/4 watt has worked on mine for over a year.
« Last Edit: April 16, 2013, 02:38:19 pm by PL1 »
  • Online Online
« Reply #14 on: April 16, 2013, 02:30:57 pm »
Thx.
rablack97
Re: The ELAMINATOR - 11/16" T-molding Red and Blue Surplus
« Reply #15 on: April 19, 2013, 08:36:40 am »
Ordered the t-molding, and because i try to be a perfectionist, i bought some of the elusive 11/16" red and blue.
Check out this thread if you want to buy some from me, no minimum, and flat rate shipping.
http://forum.arcadecontrols.com/index.php/topic,131791.0.html
« Reply #16 on: April 19, 2013, 06:39:40 pm »
Sweet build.  Here's a few pics of my recent cab.
Turn about is fair play yo  >:D
 :laugh2:
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
« Reply #17 on: April 19, 2013, 06:42:30 pm »
Nicely done sir, once you do you're first sheet there's no turning back, I love working with laminate, takes the project finish to a new level.
rablack97
« Reply #18 on: April 20, 2013, 09:52:33 pm »
 :laugh2:
i don't mind if you post pics in my thread   :dunno
I was just illustrating a flush mounted trackball yo.... :)
That rig is nice though and you turned that around very quickly...... :applaud: :applaud: :applaud:
rablack97
« Reply #19 on: April 29, 2013, 06:48:06 pm »
Small update.....
CoryBee
  • Bopity Boopy
« Reply #20 on: April 29, 2013, 10:13:26 pm »
*Fixed that for ya*
Looks good :)
