Poll
Which logo do you prefer for the final artwork? (see page 32)
I like the original (ver. 1)
I like the new (ver. 2)
Author Topic: Mission Control Project: 5 years on, what to do with the leftovers?  (Read 753110 times)
Pixelhugger
  • Last login:October 14, 2025, 10:53:10 am
Re: Mission Control Project - NOLAN BUSHNELL UPDATE
« Reply #1520 on: February 22, 2011, 12:02:28 pm »
What? me render?  ::) Nah - it's all real. I dont think there's anything shown in the book that I haven't already shown in the thread.... Other than the temporary installation of the artwork.
The stuff that remains to be done pretty much comes down to:
Bending lower rear panel on back
Building rear access door
Permanently attaching the drop down keyboard panel
All wiring/lighting
Some kind of hidden or retractable caster solution Hrmmm
Project mega thread HERE
« Reply #1521 on: February 22, 2011, 08:36:54 pm »
I saw a pretty complete shot in Saint's new book - is that a render or are you holding back on us?  ;)
I thought the same thing.
Pixelhugger
« Reply #1522 on: February 22, 2011, 08:57:38 pm »
Well... I haven't posted a full frontal yet, that's true.  :angel:
As seen in the book all the wood is still unfinished and the kick panel area is yet to be redesigned. Most of the front is not technically assembled, but rather suspended there by an elaborate system of toothpicks, yarn and tongue depressors... holding just long enough to click a picture before falling apart in a heap.  ::) In other words, while all the components in the book picture have been seen before in the thread I haven't posted final pictures of the entire cabinet with them in place since it's not actually complete. Close but not complete. So those who want a sneak peak of the cabinet in a semi finished state should buy Saint's book ASAP.  :) Those who don't need a sneak peek should buy Saint's book anyhow to support him and the site!   :cheers:
Encryptor
  • Trade Count: (+34)
  • Last login:December 21, 2023, 08:01:18 pm
« Reply #1523 on: February 23, 2011, 05:13:10 am »
Saint's new book? Is it a new book or are you talking about the new printing of his current book?
Encryptor
Epyx
  • "You're an oddity"
« Reply #1524 on: February 23, 2011, 06:12:23 pm »
new printing of his current book :)
Last Project
Epyx Tutorials:
Tutorials
Pixelhugger
« Reply #1525 on: April 22, 2011, 01:47:10 am »
So here's the long overdue backstory on the arched panels…
After building the basic form to fill the space the arched panel would sit in, I attached the additional arches I had made to support the center.
This is the location the form is meant to fill, though the form itself is temporary and this won't be part of the actual cabinet....
Next, I screwed a couple sheets of bendable poplar onto them to create a "platten" for the panel to be vacuum pressed against. At this point the entire form assembly shown is still all temporary structures. None of this actually goes on the cabinet.
With the form complete, I vacuum pressed the curved panel (made of a sandwich of 3 sheets bendable poplar between 2 sheets of wooden cherry veneer.) For detail on this process see the write up on the coin door kick panel here..
The glue up/bending of this panel was a bit sketchy as the huge volume of air and space left beneath the form allowed the bag to draw inside right at the seam. The immense vacuum pressure was then held by the glued edge of the bag which shortly split apart. Surprisingly despite the bag failure and huge drop in pressure the glue-up process worked long enough that the veneer cured without puckering. At least on the top of the panel. There was a bump in the glue up on the underside that got trimmed off. Dumb luck.
Once the bending was complete, I cut an arch out of poplar to attach to the inside. I used this to route the arched opening that will allow access into the back of the cabinet. (This panel is forms the top/rear of the cabinet)
Then I finished the arched opening with a piece of walnut (the same solid walnut t moulding I used on the CP edge and on the sides of the coin door kick panel…. you can see it to the right of the panel in the pic above.) This stuff is intended for transitions on hardwood flooring… like a small threshold. It has a really nice radiused face which I'd need a shaper to do on my own. Being that I don't have a shaper, and that they scare me anyways, this is a simple solution. I routed the spline off of the tmoulding so it became a flat piece of trim I could bend and then I clamped the bejeesus out of the walnut so it would follow the arch.
This is the arch flipped over to allow me to clamp the walnut to it's edge.
There were three arches like this in total. This was the most dramatic of them, for the top rear. So it covers part of the top of the cabinet, then bends around following the shape of the rear of the cabinet to cover the top part of the back. Another arch covers the top front behind the marquee, and another covers the bottom rear. This leaves a large circular area in the cabinet's back which gets filled with a removable curved door/access panel. More pics on that later.
Next update is for the sides of the coin door/kick panel area. After initially finishing this area I wasn't happy with how the perf panel looked. Turns out that combining the layered perf panel with the wood as I did ended up looking more like a speaker panel or a church organ. I decided to rebuild the sides of the kick panel with some left over curved cherry, adding a piece of walnut  and aluminum to add a step mimicking the CP drop down front.
« Last Edit: April 22, 2011, 01:53:17 am by Pixelhugger »
thatpurplestuff
« Reply #1526 on: April 22, 2011, 02:36:20 am »
Absolutely beautiful craftsmanship.  Can't wait to see a full shot of this thing!
  • Last login:November 18, 2025, 01:53:58 pm
« Reply #1527 on: April 22, 2011, 05:32:03 am »
That is A LOT of clamps.  :laugh: Great to see an update.  :applaud:
dfmaverick
« Reply #1528 on: April 22, 2011, 12:14:29 pm »
Woah.
Pixelhugger and Kneivel updates all in one day?  :blowup:
Love it when a plan comes together. Lookin' great.
Pixelhugger
« Reply #1529 on: April 22, 2011, 05:37:26 pm »
@purple: Thanks! Full frontal and more coming very very soon. There are some pics in Saint's 2nd edition book, although not of any of the stuff from this update and the next couple.
@emphatic. Yeah, you can never have too many IMO. :afro: The blue Irwin clamps are the only things pressing the trim against the glue. The orange clamps are all there to hold the trim against cauls to keep it from floating away from the edge.
@DFM Thanks! More on the way.
Pixelhugger
« Reply #1530 on: April 22, 2011, 05:40:24 pm »
So here is the update on the kick panel trim redesign….
I had some strips of curved cherry which I decided to add some walnut blocks and aluminum to in a stepped design like the front of the CP.
First I cut a template to match the cherry's curvature. Then used the router to cut the walnut block to match.
Next I cut a similar curve from 1/8" aluminum pieces with a jigsaw and sanded/polished the edges and faces.
Here's a before and after of the aluminum edges. I used 320 grit wet/dry sandpaper. Way easier to get an even texture than I had thought.
Here are the finished pieces before trimming to width…..
And this is one epoxied to the walnut block…..
 If nothing else I now have experience for a backup career as a shank maker
Most of this was epoxied together with glue blocks behind the curves.
After completing the new trim pieces, I needed to attach them to the existing trim on the kick panel. I removed the existing trim and cut a profile into the edge to match the new stepped profile pieces. I cut the same profile into the walnut trim on the cabinet side edge.
Here is the left side trim in position with the existing kick panel edge. It protrudes outward in the same arc as the kickpanel itself, so when fully assembled the entire area below the CP has a distinct barrel front feel, with the walnut blocks and aluminum almost feeling like barrel hoops.
The new components required a new base plate for the kickpanel which was made using a template traced on MDF from the parts themselves then cut from walnut with the router.
Here's a crappy phone camera shot from overhead of the new trim in position. You can see how it joins the trim on the kick panel to the left and the heavy walnut "wing panel" walnut trim of the cabinet side on the right. You can also see one of the poplar glue blocks I used at the top and bottom of the new trim to wedge it against the dados/profiles of these heavier pieces the new trim slots into.
I'll post much better pics of this final assembly next.
« Last Edit: April 22, 2011, 05:48:42 pm by Pixelhugger »
SNAAKE
  • Trade Count: (+29)
  • Last login:November 16, 2025, 04:44:38 pm
« Reply #1531 on: April 24, 2011, 07:22:33 pm »
so like what are you making here ???
« Reply #1532 on: April 25, 2011, 10:31:14 am »
I hope you're kidding...
Pixelhugger
« Reply #1533 on: April 25, 2011, 11:39:33 pm »
Sorry this update is a bit obscure. I'm rebuilding the portions to the left and right of the coin door/kickpanel. Originally these areas were just flat perforated metal panel, but since that didn't turn out looking as I had hoped, this is a redesign of the area. Should make a bit more sense when I get the front angle pics posted.
SNAAKE
« Reply #1534 on: April 26, 2011, 06:14:29 pm »
I was :burgerking: lol
Pixelhugger
« Reply #1535 on: May 13, 2011, 06:16:47 pm »
Just discovered I don't have space to mount my HAPP P2 button with the ponyboy's leaf switch adapters I'm using.
Apparently Happ makes/made button plungers for the P1/P2 start buttons with different plunger alignments. I need a 2 player button with a switch bracket/plunger aligned vertically like the 1P button seen in the photo below. (I need the bracket to be aligned with the player graphic when the button is installed. Alignment is determined by the plunger on the player graphic)
ARGH.....
Anybody have one to sell/trade? I have some super tasty 3.5" NOS WICO ball top shafts in Red, Orange, Purple, Yellow, or Green
thatpurplestuff
« Reply #1536 on: May 13, 2011, 10:47:16 pm »
I've got 1p and 2p white happ buttons that match your "right bracket" picture... the switch brackets run in the same direction as the dude(s) standing on the button.  Message me your address and one/both are yours!
Endaar
  • Last login:December 31, 2024, 05:51:19 pm
« Reply #1537 on: May 14, 2011, 09:54:21 am »
Admittedly I'm not completely awake yet, but couldn't you just pop the 2P button itself out of the 2P housing and put it into another 1P housing?
Endaar
thatpurplestuff
« Reply #1538 on: May 14, 2011, 02:09:10 pm »
Endaar- Nope... the housing is actually inconsequential as the moving part of the button is what determines whether or not the dude is vertical or horizontal.  The little prongs that align with the housing are what determine the direction the dude will face.
Pixelhugger
« Reply #1539 on: May 14, 2011, 11:56:43 pm »
You sir, rock.
PM sent.
Pixelhugger
Re: Mission Control Project - Rear door complete
« Reply #1540 on: June 17, 2011, 09:11:31 pm »
On to the back.
As I've mentioned before, the top and back of the cabinet always posed a big design problem for me. Ultimately the vacuum formed panels along the top, and parts of the back solved the problem of the cabinet's curves otherwise becoming a facade hiding a flat top and back, which I definitely wanted to avoid.
I still had to deal with putting a door or access panel on the back of the cabinet, since the permanent installation of the bezel meant the monitor couldn't go in or out through the front.
I decided to create a panel that followed the contour of the back of the cabinet. I wanted the back to have the same level of finish and detail as the rest of the cabinet, particularly if it is to ever sit away from a wall, where it would be visible. For the surface of the door, I used aluminum perf panel, which has the added benefit of venting the cabinet directly behind and above the monitor.
This perforated panel is bent and held in shape by a 3/16" channel cut into 3/4" walnut sides which give the hatch its structure and add a bit of trim to the back.
It gets bolted into place, since it'll rarely be opened, and since I needed to child proof it against curious little hands, given it leads straight into the neck of the monitor and access to the anode cap…  The bolts (and nuts) that hold the door in place are then hidden by a pair of stainless steel rocket logos (waterjet cut by Cornchip) which spin down onto the remaining  length of the bolt shafts and recess themselves into the walnut handle across the mid section of the door.
Confused? So was I.
First I used the same template approach I used on most of the cabinet to cut the walnut door sides. That is….
1) Create the shape in a graphics program (Illustrator)
2) Print out at full size
3) Spray mount on MDF
4) Cut the MDF to the final shape
5) Use the MDF as a template to route the actual wood.
Once I had two matching sides, I rounded their edges with the router then screwed them onto a sheet of MDF to hold them in position next to each other (back to back) while I routed the various dados I'd need to brace the door with poplar… ummm…. braces. This allowed me to get the dados in exactly the same location on both sides quickly and accurately. I was really really nervous about keeping the door square… partially because of the fact that, like the rest of the cabinet, it toenails down at an angle (wider at the top than bottom, blah blah blah) and partly because there simply wasn't going to be much structure holding it together. It was going to be like a very large and curvy picture frame, with quite a bit of twisting/flexing torque applied to it by the large sheets of "forced into position" curving perf panel. Anyhow, I tried to keep things as accurate and symmetrical as I could.
With the dados cut, I marked their locations on the poplar braces that would get slotted into them. Hoping to create a sort of multi directional self stabilizing auto aligning locking mechanism structure, I continued the dado along the poplar. There are two of these poplar braces, each in the shape of a T as you can see in the wider shot.
Next I measured the horizontal dimensions for a handle to be cut from walnut to give the center of the hatch some support, and allow for an attachment point (the bolts mentioned above)
I created a template for the handle (as detailed above) and routed it from walnut.
Front:
Back:
Using the same template I had used to cut the door sides, I inset a 3/16" channel along the inner face of each side to allow the perf panel face of the door to be held inside.
After measuring the length and various widths I needed for the perforated panel, I trimmed it to the appropriate shapes to fit into the angled door. The perf panel wobbles and shakes like crazy when being cut. Sandwiching it down made that a lot easier. Who'da thunk?
I tried using epoxy to attach some threaded "weld nuts" on the back of the stainless logos with mixed results. Ultimately one is (so far successfully) attached with epoxy, while the other failed and was reattached using JB Weld… technically an epoxy I guess but apparently much much stronger and better for smooth surfaces than the stuff I was using.
After measuring the diagonals to check for square, I glued up the door, sandwiching the perf panel in between the sides in the slot I had routed.
After the door was glued, I attached a heavy grade vinyl window screen material to the back of the perf panel to prevent the previously mentioned curious fingers from poking a coat hanger through the back and into the monitor neck…..*thinks of Nostrebors avatar pic*
Here are pics of the doors curvature
mgb
  • North East, US
Re: Mission Control Project - Curved rear door UPDATE
« Reply #1541 on: June 17, 2011, 09:16:42 pm »
Simply beautiful  :applaud:
« Reply #1542 on: June 17, 2011, 10:43:59 pm »
Stunning!
  • Last login:November 13, 2025, 01:36:49 am
« Reply #1543 on: June 18, 2011, 12:20:37 am »
That looks outstanding!
« Reply #1544 on: June 18, 2011, 09:09:23 am »
Outstanding is right! :applaud:
I have been thinking of how I should mount my invaders and marquee to stand off the cabinet. I was leaning toward JB Welding some all-thread to the backs of them but this seems to work great. I will be following your example when I get to that point in my project. :)
« Last Edit: June 18, 2011, 09:14:18 am by Nephasth »
« Reply #1545 on: June 18, 2011, 09:24:13 am »
If you're talking metal to metal, I found some solder in the plumbing section at lowes. It comes in a syringe tube and is Solder and flux together.
You use a torch to solder it, but I've found that (at least for copper-copper and copper-brass) it's a very solid joint when done right.
But JBWeld rocks too. Be sure to scuff up the areas being joined first, if they're really smooth.
Pixelhugger
« Reply #1546 on: June 18, 2011, 10:59:29 am »
Yeah, the nice thing about the weld nuts for attachment is that you have a large surface area around the base. I love the story on the JB Weld packaging about the farmer who glued a cracked engine block back together.
« Reply #1547 on: June 18, 2011, 11:29:49 am »
I sure hope that cab is going in the middle of the room, preferably with a spotlight on it. It'd be a shame to back it up against a wall!
Pixelhugger
« Reply #1548 on: June 18, 2011, 12:26:59 pm »
If I had my way it would be on a rotating turntable with a fog machine behind it.O
korbitz
  • Last login:June 30, 2017, 01:09:54 pm
« Reply #1549 on: June 18, 2011, 12:37:11 pm »
Uh-oh, hes getting creative ideas again  :applaud:
« Reply #1550 on: June 18, 2011, 02:36:07 pm »
Good God!  :notworthy:
  • Last login:November 13, 2025, 08:40:37 pm
« Reply #1551 on: June 18, 2011, 04:29:37 pm »
Dude, you dodged a bullet with the end of the world not coming on May 21, 2011, but 2012 is coming up quick...
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #1552 on: August 02, 2011, 01:07:01 pm »
So, how do you stay in love with a project this long?  If I don't finish quickly, I tend to loose interest and it doesn't get done.  I need to have the level of commitment you have.
Since I first saw the pixelhugger thread I've:
Designed and built a MAME cabinet which is a turd by comparison
Raised a son for a few years
Had a second son and raised him to the age of two
Changed jobs twice
Started and Architectural Consulting firm.
You can't keep something this good from the world; unless you happen to be raising kids too, in which case it will be eighteen years before you can finish it.
« Last Edit: August 02, 2011, 01:14:17 pm by Mark70 »
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
Pixelhugger
« Reply #1553 on: August 02, 2011, 02:27:03 pm »
Good to see you back in the thread Mark. Crazy timing, tho'.. I thought for sure I'd be the one to bump the thread tonight. Just you wait.....
You ain't seen nothin' yet.   :cheers:
jordancbr
  • Last login:April 11, 2025, 06:00:52 am
« Reply #1554 on: August 02, 2011, 02:49:37 pm »
Uffffffffff i love!!!!  :notworthy:
Mark70
« Reply #1555 on: August 02, 2011, 03:13:42 pm »
Oh, now I can't wait for the update.
What would it take to convince you to do a video on finish.
Pixelhugger
« Reply #1556 on: August 02, 2011, 03:30:32 pm »
 Just wait. This one's been in the works for a looong time now. Although, your posts are eerily timed... more Jungian collective subconscious crap? :o :o :o
Pixelhugger
« Reply #1557 on: August 02, 2011, 08:51:48 pm »
And by tonight of course I mean tomorrow night.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #1558 on: August 02, 2011, 09:35:40 pm »
Lmao . . . I know how that goes.
Best Kid iPad Apps
« Reply #1559 on: August 04, 2011, 04:51:04 am »
Or maybe the night after tomorrow night? ;)
