Author Topic: Want to build Golden Tee cabinet, need advice  (Read 20853 times)
Huskerfan
  • Last login:October 05, 2021, 11:40:38 pm
« on: March 13, 2013, 05:58:08 pm »
I just called IT, the maker of Golden Tee.  The sales guy said I could just buy a beat up cabinet for the guts inside and then build my own cabinet to house the guts.  With that said here's a GT motherboard and hard drive on ebay.  Do you think this is all it takes to run Golden Tee?
http://www.ebay.com/itm/Golden-Tee-Fore-2005-Arcade-Game-Board-Hard-Drive-Marquee-/290867922934?pt=LH_DefaultDomain_0&hash=item43b91447f6
btw, he said I could upgrade it 2013 specs by paying them $449 but they wouldn't sell me the actual guts, only the upgrade.
nipsmg
  • Last login:Today at 12:08:50 pm
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Want to build Golden Tee cabinet, need advice
« Reply #1 on: March 13, 2013, 08:54:57 pm »
You cannot upgrade that board to 2013, whoever told you that is incorrect.  That type of board can be upgraded to Golden Tee Complete, which has all of the courses (+Extra courses) from all of the Golden Tee Fore! versions.
You will need that board and hard drive and a power supply as well (I believe for the Red board you can use a standard PC power supply, but I'm not 100% sure. You'll have to look itup)  You'll also need an audio preamp of some kind, or at the very least a line level converter for the audio.  You'll need a super jamma harness.  I'd suggest getting it from gatorcade.com. Their jamma cables are very well done, and have most if not all connectors already attached, including daisy-chained ground wires. ALl you need to do is slide them onto the buttons and you're good to go.
Also, if you are planning on using a TV and not a Medium Res or Standard Res arcade monitor, you'll need a video converter as well.  You can use AverMedia's AverKey 300 Pro to convert the video right out of the 3DFX card on the board to SVideo, or get JROK's RGB -> TV converter.  Depending on your TV, you may need a sync board as well.  You can get those directly from him or from gatorcade.com as well.
Good luck!
Huskerfan
« Reply #2 on: March 16, 2013, 05:51:13 pm »
Thanks for responding!  Since that post I've investigated more.  2006 is the year Golden Tee Live came out and any GTL can be upgraded to current standards.  So with that said I think this motherboard should do the trick, right?  http://www.ebay.com/itm/GOLDEN-TEE-LIVE-REPLACEMENT-MOTHER-BOARD-COMPLETE-NEW-/300876197762?pt=LH_DefaultDomain_0&hash=item460d9e6f82
I can get a hard drive for it right here:  http://www.ebay.com/itm/GOLDEN-TEE-GOLF-LIVE-2012-REPLACEMENT-HARD-DRIVE-INCREDIBLE-TECHNOLOGIES-I-T-/300868531809?pt=LH_DefaultDomain_0&hash=item460d297661
A power supply right here:  http://www.ebay.com/itm/GOLDEN-TEE-LIVE-POWER-PUTT-TARGET-TOSS-POWER-SUPPLY-/380257035707?pt=LH_DefaultDomain_0&hash=item588915e5bb
Guess I'd need a video card and of course I'd build the cabinet and control panel but I've done that before.
What do you think?
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #3 on: March 17, 2013, 12:15:02 pm »
I have NO IDEA when it comes to Golden Tee Live what you need.  I really only know Golden Tee Fore! boards.
You'll have to ask someone more familiar with those boards.
ed12
« Reply #4 on: March 17, 2013, 12:24:13 pm »
if u are going to build a golden tee live built by it's-gamming
u will need the >pid< board
this carry's the uniquie id of the game
also they use what is called a black hawk micro system now
plus to boot u will need to setup an account with it's-gamming
to get the current course's :ie: 2013
as the course's are virtuial..there never kept in the on-board system
now if it is a hack,then not all of the above apply's
ed
IG-88
« Reply #5 on: March 17, 2013, 04:37:31 pm »
@ed12 If it's not against this forums rules, could you explain how one goes about doing the "hack" for this?
-HarumaN
Huskerfan
« Reply #6 on: March 18, 2013, 02:38:32 pm »
ed
I thought there was a free standing unit that didn't hook up to Golden Tee.  I think it's the home use one.  And I think instead of the pid you're talking about the cid?
I was just wondering if I could pick up one of those motherboards and I'd be on my way.
Has anyone built one of these from scratch?
Drnick
  • Plodding Through Life
« Reply #7 on: March 19, 2013, 09:08:59 am »
Yep there is even a thread about it on here somewhere.  Unfortunately in another thread recently someone pointed out that IT no longer sell the stand alone product  :banghead:
http://forum.arcadecontrols.com/index.php/topic,104064.0.html
Huskerfan
« Reply #8 on: March 19, 2013, 02:30:58 pm »
Ya, I was the one that posted to that thread.  :)  Since then I found someone to sell the kit for $2700 but that's still more than I want to spend.  I think it can be done for less than $1000 but I don't know all the parts involved for sure.
Steve Dallas
  • Newbie
  • Last login:January 16, 2019, 12:03:40 am
« Reply #9 on: April 20, 2013, 08:45:50 am »
Any luck getting started, Husker?
ed12
« Reply #10 on: April 20, 2013, 01:02:01 pm »
a golden t golf game,
can be bought complete for $1200.00 canadian
complete and running
most were dynamo cab's
about $250.00
26" wg monitior
its-gamming green mother-board
power-supply
hard-drive.
now golden t live is a totaly dif critter
for that 1 u need the black-hawk box,and cid/pid board
but for the older unit's,lord every game dealer would or should have atleast 4
that they would let go of
just rem.the monitor will be dated,as will the hard-drive
so renew the monitor >cap-kit/etc<
and copy the hard-drive for back-up reason's
snag a roller ball re-build kit..happ control's >about $40.00<
and away u go
they are heavy,so u will need a few big buddie's or a cart with another bud
ed
blezzda40z
  • Newbie
  • Last login:June 26, 2014, 08:37:31 am
« Reply #11 on: June 07, 2013, 09:17:16 pm »
I have found a golden tee live mother board and a cheap I/O board plus gt live 2012 hard drive and graphics card all for a total under 700$ all from differnt sellers.  Will these work together or am i missing something?
i would like to find out before buying and wasting money
eds1275
  • Rock and Roll!
« Reply #12 on: June 07, 2013, 09:34:58 pm »
Why not just grab a few buttons, an old pc, and a trackball and build a cabinet for it? You could be good to go for $300
chopperthedog
  • Last login:Today at 08:39:02 am
« Reply #13 on: June 13, 2013, 08:47:59 pm »
about $250.00
26" wg monitior
power-supply
hard-drive.
and away u go
ed
That's nighthawk box. I absolutely love your insightful cryptic posts, seriously. #nohomo :applaud:
good day.
« Reply #14 on: June 13, 2013, 09:16:22 pm »
Hey look what I found, I drew this up for someone eons ago,  it can be provided without the grass background of course in high resolution.
Useful?
macattack
  • Last login:August 03, 2018, 05:35:16 pm
  • Cabinet builder to the stars!
« Reply #15 on: June 13, 2013, 09:41:23 pm »
If you need a cnc flat pack pedestal, I have them now. Will post some pics next week in a new thread.
Pm me for custom cnc needs...
smalltownguy
  • Last login:February 27, 2026, 07:59:15 pm
« Reply #16 on: May 14, 2018, 03:17:46 pm »
Interested! PM Sent.
gumby510
  • Last login:November 17, 2022, 09:19:44 pm
  • SR-20 NX 2000
« Reply #17 on: May 16, 2018, 01:11:34 am »
Dam necro bump. I’d like to find one to as I have an extra 2018 kit I want to get rid of.
niemeyerw
  • Last login:February 24, 2019, 08:57:29 pm
  • It is what it is.
    • forum.arcadecontrols.com/index.php/topic,157234.0.html
« Reply #18 on: May 16, 2018, 08:49:29 am »
I have a friend that might be interested in the kit you have.  Is it a live kit, and how much are you looking to get for it?
gumby510
  • SR-20 NX 2000
« Reply #19 on: May 16, 2018, 11:35:15 am »
Offline kit I was using in my other cab. Live cids are hard to come by and cost as much as what I want for this one.
smalltownguy
« Reply #20 on: May 16, 2018, 12:46:18 pm »
PM Sent
