Author Topic: Dumb Question - Is this Widescreen or not?  (Read 1539 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: March 13, 2013, 10:26:53 am »
Ok, I think I sourced out a 22" LCD monitor as opposed to a widescreen.  I'm thinking of getting it and using it for both horizontal and vertical games - I hope it works well.
I'm posting below the specs.  Since it doesn't mention 1920x resolution, does that mean that it's not widescreen?  Not sure how to tell otherwise  :timebomb:
Product Specifications:
Number of Screens: 1
Screen Size: 22"
Screen Mode: WSXGA+
Maximum Response Time: 5 ms
Horizontal Viewing Angle: 88°
Vertical Viewing Angle: 88°
HDCP Support: Yes
Maximum Resolution: 1680 x 1050
Contrast Ratio: 1000:1
Brightness: 250 Nit
DVI: Yes
VGA: Yes
Height: 13.50"
Width: 19.89"
Depth: 2.57"
Height with Stand: 15.39"
Width with Stand: 19.89"
Depth with Stand: 8.73"
Weight (Approximate): 10.36 lb
Weight with Stand (Approximate): 11 lb
Standard Warranty: 3 Year
Re: Dumb Question - Is this Widescreen or not?
« Reply #1 on: March 13, 2013, 10:48:20 am »
16:10 aspect ratio.
JDFan
« Reply #2 on: March 13, 2013, 11:36:12 am »
1680 x 1050 resolution would be a 16x10 widescreen. for a non widescreen 4:3 display look for a native resolution that the first number divided by 4 then multiplied by 3 = the second number (ie. 4:3 resolution like 640x480 (640/4 = 160 X 3 = 480) , 800x600, 1024x768, 1280x960, 1360x1024, etc. )
« Last Edit: March 13, 2013, 11:40:39 am by JDFan »
« Reply #3 on: March 13, 2013, 11:47:23 am »
Jesus, that sounds complicated. I figure by dividing the first number by the second number. 16/10=1.6, 1680/1050=1.6; 16/9=1.777, 1280/720=1.777; 4/3=1.333, 640/480=1.333. But maybe my way is complicated... :dunno
  • Last login:Yesterday at 08:08:49 am
« Reply #4 on: March 13, 2013, 12:03:59 pm »
16:10 is actually better if you're stuck with widescreen.
You get a little bigger 4:3 image than you would with the same diagonal size 16:9 widescreen.
Some of the widscreen Taito Type X games run at 16:10 on my 16:9 monitor, so I have slight black bars on each side.
(I don't want it stretched)
If you're looking for a 22" 4:3 monitor though, that's not one.
« Reply #5 on: March 13, 2013, 12:39:28 pm »
+1.  It's widescreen. 16:10
Where exactly are you located?  I'm looking to unload some 4:3 LCD monitors that I had originally saved for MAME projects but no longer have the time to complete.  I have two 20.1" LCDs and four 17" LCDs.
PM me for details.  (Pics below).
DeLuSioNaL29
Drnick
  • Plodding Through Life
« Reply #6 on: March 13, 2013, 02:15:20 pm »
@ DeluSioNal,  I'm looking at your monitor on my monitor which is exactly the same  :laugh2: Thought about taking a picture for some Xhibit jokes  :lol
vorghagen
  • Last login:September 05, 2017, 01:06:59 am
« Reply #7 on: March 14, 2013, 09:50:53 pm »
For monitor resolutions, display names and aspect ratios I find this graph particularly useful.
Helpful to find an actual resolution when only given the dispaly name (WSXGA+, WSVGA etc)
Gives the aspect ratio of a particular resolution.
And provides a list of all the resolutions for a given aspect ratio.
If you're looking for 16:10 ratio it's listed as 8:5 in the graph.
Never argue with an idiot, he'll just drag you down to his level and beat you with experience.
