Author Topic: GroovyArcade live-CD 2020  (Read 658908 times)
Substring
  • Last login:January 05, 2026, 04:59:45 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
Re: GroovyArcade live-CD New Release 2019
« Reply #840 on: July 20, 2019, 01:44:43 pm »
Groovyarcade us a full OS and doesn't require Windows. There are menus to help install and configure it. It's based on Linux
keilmillerjr
  • Web Developer.
« Reply #841 on: July 20, 2019, 02:14:35 pm »
So where can I find an up to date tutorial on setting up groovy arcade? Do I still need emudrive software with groovy arcade?
GroovyMame is a fork/patch for mame that has optimizations oriented towards crt’s. - Calamity
Crt Emudriver is a modified windows video driver and tool bundle to get 15khz out of compatible video cards. - Calamity
GroovyArcade is an arch linux distro image that is already set up with groovymame and front end. Compatible with lcd and crt. - Ves / Substring
aj8302
  • Last login:April 02, 2020, 08:48:34 pm
« Reply #842 on: July 20, 2019, 02:24:31 pm »
So no other software required to get it going with my crt? I have seen a few videos of the setup just wasn’t sure if there was anything I needed to do before hand.
Substring
« Reply #843 on: July 20, 2019, 03:55:01 pm »
You can just try it in virtual box to get an idea of the thing
aj8302
« Reply #844 on: July 20, 2019, 08:28:35 pm »
I will give that a tray I have a dedicated pc for it so it doesn’t matter what operating system it has as long as it works lol. Just looking for the simplest way to get the crt going. I had it working with emudrive and groovymame. But every time I would restart my pc it would go back to 31khz.
keilmillerjr
  • Web Developer.
« Reply #845 on: July 20, 2019, 08:30:49 pm »
I use a jpac. It will split 31khz picture to 15khz for protection (boot). It also amplifies the video signal, needed for some monitors. You might have to blindly select your video option in the groovy arcade menu.? Its been a while. Google an image of groovy arcade if you get no picture.
aj8302
« Reply #846 on: July 20, 2019, 08:43:28 pm »
I use an ipac then a vga cable I converted to 9 pin at one end to plug in to the crt.
aj8302
« Reply #847 on: July 25, 2019, 01:40:25 pm »
So everything starts up great and looks good on my crt but when I try to install it on the HD and it asks to select one it just tells me it can’t because it’s already partitioned but as far as I can tell it’s not. Any suggestions?
Substring
« Reply #848 on: July 25, 2019, 02:23:11 pm »
You have to delete existing partitions using the menu. It will take you to cfdisk where you must delete 1 by 1 each partition, write the new partition table, then go back to the menu to install
Gurudumps
  • Last login:August 26, 2019, 05:34:47 am
  • I ain't no newbie!
« Reply #849 on: July 25, 2019, 02:25:07 pm »
yeah I had that issue myself. Wipe the HDD clean with no partitions then install and it will work. That's the easiest way  8)
Dumping ROMs for MAME since 1999!
aj8302
« Reply #850 on: July 25, 2019, 02:42:49 pm »
When I check disk manager I have no Partitions only a 12 GB Unallocated Partition that I cannot remove or extend my c drive too.
aj8302
« Reply #851 on: July 25, 2019, 02:44:46 pm »
What menu? This is my first time building an arcade with a crt.
Gurudumps
« Reply #852 on: July 25, 2019, 02:49:17 pm »
Extend your partition to? If the drive is blank you can't extend anything to anything.
I advise plug the drive into a PC that you know well and use the OS to remove the partition.
In Windows it can be done by right clicking on My Computer and selecting Disk Management then select the new HDD (not your C: drive!!) and delete the partitions. Or use the menu in GroovyArcade to select the partitioning program and remove everything, or some other 3rd party program.
You can also use Windows through the command line with Diskpart, but be careful as it is easy to select the wrong thing and do some major damage to the wrong drive. Google for a tutorial, the info is out there.
« Last Edit: July 25, 2019, 03:04:39 pm by Gurudumps »
Gurudumps
« Reply #853 on: July 25, 2019, 02:52:08 pm »
and read this for a set-up guide. it's still relevant even with the 2019 release.
http://forum.arcadecontrols.com/index.php?topic=144155.0
In GroovyArcade, the menu item to wipe the HDD is '3. HD Installation and Partition Tools' then '3. Partition Manager (CAUTION!)'
« Last Edit: July 25, 2019, 03:04:56 pm by Gurudumps »
aj8302
« Reply #854 on: July 25, 2019, 02:57:02 pm »
Yup that’s the guide I’m using but can’t get past the last part to install. When I look in disk management. It shows my C Dr. and it also shows shows 12 GB unallocated the last partition I had I was able to extend my C volume to get rid of it but I can’t seem to be able to do it with this  unallocated 12gb
Gurudumps
« Reply #855 on: July 25, 2019, 03:03:16 pm »
C drive? Eh? If you are using GroovyArcade it is Linux-based and there's no C drive. Use a new/blank HDD, install from a CD or USB drive, follow the guide and it just works. If not, try a different blank/new HDD.
This thread is about GroovyArcade. If you are not using that, you are in the wrong place ;)
« Last Edit: July 25, 2019, 03:05:38 pm by Gurudumps »
aj8302
« Reply #856 on: July 25, 2019, 03:11:40 pm »
That’s what I’m using but I was trying to use an old pc that still has windows in it.
aj8302
« Reply #857 on: July 25, 2019, 03:18:20 pm »
Can I add a second hard drive to my windows pc and run it off that?
aj8302
« Reply #858 on: July 25, 2019, 05:09:41 pm »
So In stalled a second SSD and was able to install groovyarcade on it with no problems. Now every time I start up the pc should it load to groovyaravde running at 15khz or do I need to do something extra?
Gurudumps
« Reply #859 on: July 26, 2019, 01:09:50 am »
if you set your pc BIOS to use the 2nd HDD as the boot drive then yes it will boot that drive every time.
if it still tries to boot from the old drive, you need to go into the BIOS and change the boot drive so that it boots from the SSD.
aj8302
« Reply #860 on: July 26, 2019, 08:30:14 pm »
Thank you for all the help!!! I am happy to report it’s all working amazing now!!! Just a couple more help questions lol during first boot up is is in 31khz or 15khz? And second question can I make it so it automatically boots to a specific game?
Gurudumps
« Reply #861 on: July 27, 2019, 02:03:34 am »
the initial boot will be at 31k. To stop your monitor being possibly damaged with the wrong sync rate, you need to use a JPAC (from ultimarc.com) which will block the sync until the software changes it to 15k.
To boot into one game, go into the file manager from the groovyarcade setup, then navigate to /home/arcade, then cursor down to .xinitrc
This file is used to load the frontend UI or game menu. press F4 to edit it. The last command in this file will be the something like 'advmenu'
change it to load MAME or whatever else you want to run.
lettuce
  • Make It So!
« Reply #862 on: July 28, 2019, 09:31:08 am »
So i flashed and install Crt Emudriver on my GPU years ago and havent really touched Groovyarcade installation for a good 5 years, should i be looking up updating Crt Emudriver before i start a fresh install or is there an update option on the GroovyArcade installation? Also has there been any new firmware upgrades in the last few years that i need to flash my card with?
Gurudumps
« Reply #863 on: July 28, 2019, 09:42:00 am »
The only reason to update is if you want the latest MAME version. I doubt Groovyarcade has that so you would need to run your own install of MAME for Linux/Windows if you want the newest MAME. If you just play the same games, everything works and don't care about new updates of MAME there's no need to mess with it.
lettuce
  • Make It So!
« Reply #864 on: July 28, 2019, 09:52:39 am »
Oh so the latest release of GroovyArcade image doesn't have a relatively new version of MAME installed?. Is there an option to update MAME in any of the setup steps for GroovyArcade installation?
Gurudumps
« Reply #865 on: July 28, 2019, 10:10:44 am »
GroovyMAME is a special custom version of MAME. The Groovyarcade iso won't have the latest version.
To find the newest available version read the appropriate sticky thread http://forum.arcadecontrols.com/index.php/topic,151459.0.html
Unpack it and copy the mame executable file to the same location where groovymame is. I assume you'll have to rename or delete the old groovymame and rename the new one to the same file name then it will work and you'll have the newest available version of groovyMAME.
Substring
« Reply #866 on: July 28, 2019, 11:29:54 am »
There is a menu option in gasetup that may download a newer groovymame. Somewhere in system updates
Gurudumps
« Reply #867 on: July 28, 2019, 12:18:33 pm »
Yes but that requires a working internet connection that may or may not be available or working on the PC that's inside the arcade cabinet. With the default GroovyArcade install, out of the box the internet connection on my PC wasn't working. It was just easier and quicker to manually download and copy the file across from a USB stick using the GASetup program through the file manager :)
aj8302
« Reply #868 on: August 14, 2019, 11:54:23 am »
What version of mame is in the current groovyarcade?
Substring
« Reply #869 on: August 23, 2019, 11:37:19 am »
Out of curiosity : has anyone ever tried the real time linux kernel patches on a groovyarcade setup ?
  • Last login:Today at 02:44:21 am
« Reply #870 on: August 23, 2019, 11:40:19 am »
Real time kernel patches? Is that possible?
Gurudumps
« Reply #871 on: August 23, 2019, 11:51:04 am »
Other than to break it there's no point even trying. Nothing needs to be updated, GroovyArcade works just fine as-is.
Substring
« Reply #872 on: August 23, 2019, 01:02:31 pm »
Yes sir : https://wiki.archlinux.org/index.php/Realtime_kernel_patchset
Doozer
  • Z80 ERROR
« Reply #873 on: August 26, 2019, 03:27:54 am »
Yes, it is possible but I do not see what could be the benefit for GM? Current scheduler are fine and can deal with low latency requirements.
Do you have something precise in mind?
« Reply #874 on: August 26, 2019, 03:58:29 am »
By "real time kernel patches" I understood patching the kernel in real time, instead of patching the kernel for real time.
I believe we already tested a real time kernel in the past with the help pf Cools, but it didn't seem to make a noticeable difference, e.g. in latency.
Doozer
  • Z80 ERROR
« Reply #875 on: August 26, 2019, 04:44:02 am »
You mean live kernel patching. It is rather complex and might not be workable for 15Khz. I will check what is feasible.
Doozer
  • Z80 ERROR
« Reply #876 on: August 26, 2019, 07:25:25 am »
Implementing live patching for the kernel would require more time and be as constraining as patching the kernel. Live patching is more about uptime (to meet high availability requirement) and answer the requirement to reduce the number of reboot. I don't think going this way has any sense for 15kHz.
Talking about 15kHz, I just want to drop some info here about one potential idea. On the market, the USB to VGA adapters are built over DAC chip (Fresco FL series) with possibility to enjoy 1080p (bandwidth 100-150 MS/s). It is possible to use such adapter to provide OS agnostic 15kHz support (after driver is loader). The point is that they are dirt cheap and using USB protocol (USB 2.0 compatible). It sounds perfect for the creation of a USB 15 kHz solution. I might look further into it when I am done with other projects.
E.g. cellular SDR with constant radio modulation output by disabling H/V signals.
https://osmocom.org/projects/osmo-fl2k/wiki
Substring
« Reply #877 on: August 26, 2019, 12:58:28 pm »
those may have pretty poor performance with no 3D acceleration ...
Doozer
  • Z80 ERROR
« Reply #878 on: August 27, 2019, 02:29:43 am »
Performance wise you are right. This device would have basic 2D performance but enough bandwidth (150MHz) to display any resolution/refresh rate with no delay impact. MAME is only 2D and implement all 3D API in software. Should not be a big issue.
Substring
« Reply #879 on: August 27, 2019, 07:57:32 am »
I don't know about MAME, but quite many mulators render through opengl or d3d, hence my comment. But that's still a funny thing to try!
