Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1042290 times)
rablack97
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #440 on: June 29, 2013, 11:45:48 pm »
okie dokie, oh yeah 1ply2 or 2...
Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #441 on: June 29, 2013, 11:49:34 pm »
1 player.
rablack97
« Reply #442 on: June 29, 2013, 11:55:45 pm »
hmmm, 1plyr + t-ball, or is that pushing it...
« Reply #443 on: June 30, 2013, 01:15:37 am »
That may be. I could always include the normal control panel, and then a blank one for you to play with.
TheDude
  • Bartops all the way !
    • BARTOPMANIA
« Reply #444 on: June 30, 2013, 01:18:57 am »
That's a full-size Vewlix, not a bartop.
It looks so, my humble apologies  :lol
lowgunn
  • Last login:February 08, 2025, 02:33:10 pm
« Reply #445 on: June 30, 2013, 02:51:43 am »
Hmmmm why not a bartop viewlix?   I think that could look pretty awesome.
TheDude
    • BARTOPMANIA
« Reply #446 on: June 30, 2013, 04:21:53 am »
termin8tor is building one at the moment and a guy from another acade forum also  does ! ;)
PTD
  • Last login:August 26, 2014, 10:54:16 am
« Reply #447 on: June 30, 2013, 09:54:12 am »
Can someone create this?
rablack97
« Reply #448 on: June 30, 2013, 09:58:10 am »
Yeah that's Selfie's masterful acrylic job isn't it.
Ah ok cool.......waiting on some money on a job i just completed....i'll pm you when ready..... :cheers:
« Reply #449 on: June 30, 2013, 07:32:08 pm »
Cool deal...
As far as other projects go, next is that Vewlix (full size) and then a mini-virtual pin.  After that, I can look at other designs.
The acrylic one is pretty cool, but I currently have no way of bending that stuff.
« Reply #450 on: June 30, 2013, 10:15:28 pm »
Playing around with the vinyl cutter. Need to order some transfer paper, very hard to line up otherwise.
lowgunn
Here's how I lit the buttons:
Cathode vs Multi Colored Led strips (~$30) on amazon?  what do you guys think?  I'm debating about white or red cathodes then my coworker brought this into the equation.   Will led strips give the same glow effects?  thanks in advance.
This is what I used:
http://www.ebay.com/itm/350726861639
total of like $12.50 shipped.
« Reply #453 on: July 03, 2013, 03:38:34 pm »
More MVS progress:
« Reply #454 on: July 03, 2013, 03:39:18 pm »
From the front:
« Reply #455 on: July 03, 2013, 03:40:36 pm »
Hooked the Xbox up while waiting for my rgb to vga adapter:
Articus
  • Last login:September 05, 2013, 11:14:05 pm
« Reply #456 on: July 03, 2013, 04:14:49 pm »
By rgb, you mean component (YPBPR) cables?  If so, wich vga adapter do you recommend?
« Reply #457 on: July 03, 2013, 04:18:54 pm »
This is what I'm talking about:
http://www.ebay.com/itm/330605923350
I'm using to convert the signal from a real Neo Geo motherboard for this project.
bzbee
  • Last login:September 19, 2017, 10:16:02 am
« Reply #458 on: July 04, 2013, 04:22:39 am »
From the front:
Is this still the 19" LCD?
« Reply #459 on: July 04, 2013, 11:47:03 am »
From the front:
No, this is a 20.1" Dell 2001FP.  It just fits, no decasing.   :cheers:
SNAAKE
  • Trade Count: (+29)
« Reply #460 on: July 05, 2013, 04:33:53 am »
doesn't have to be a plastic cabinet tho. wood version of that cabinet would still be really nice.
but I need to stfu and put together the cabinet I already bought lol.. :dizzy:
rablack97
« Reply #461 on: July 05, 2013, 08:03:43 pm »
Ha you got shafted too....i just ordered the same damn board yesterday then came across it cheaper.....
http://www.ebay.com/itm/CGA-EGA-YUV-to-VGA-Arcade-Video-Converter-Genuine-Gonbes-brand-USA-seller-/231001639496?pt=LH_DefaultDomain_0&hash=item35c8c54a48
If you not in a hurry you can bid on the same board from HK and China, starting at 18.88
« Last Edit: July 05, 2013, 08:13:42 pm by rablack97 »
PTD
« Reply #462 on: July 06, 2013, 01:27:12 am »
How do you guys secure the power supply?  Securing the power supply in the computer case is easy because of the screw holes of the computer case but I don't know a good way to secure the power supply.
cdf12345
  • Last login:February 13, 2020, 08:36:10 am
« Reply #463 on: July 06, 2013, 06:11:28 am »
Cool deal...
A mini pin would be amazing, I have a setup right now that I just haven't gotten around to building a box for. 19" 4/3 back glass and 24" playfield. I really hope your design can accommodate a 24" playfield. It probably wouldn't be too hard as there should be more room to work with compared to a bar top mamecab.
rablack97
« Reply #464 on: July 06, 2013, 10:57:16 am »
i use l brackets, there are some wider ones from Home depot or lowes that have like 3 random holes so you can screw into the PSU and then into the actual machine....
these are coollll
JDFan
« Reply #465 on: July 06, 2013, 11:23:19 am »
L-brackets work well but I've also used Velcro strips.
05SRT4
  • Check out my Pow Pow
« Reply #466 on: July 06, 2013, 02:20:47 pm »
PSU, AMP, and CP are all held by Velcro on mine. Works great and is awesome for if you need to remove or make changes.
« Reply #467 on: July 06, 2013, 10:10:32 pm »
Some MVS progress, transfer tape makes all the difference:
« Reply #468 on: July 06, 2013, 10:11:40 pm »
Running the neo geo motherboard:
« Reply #469 on: July 07, 2013, 01:22:50 pm »
More vinyl goodness:
tron84
  • Last login:November 15, 2017, 06:45:56 am
« Reply #470 on: July 07, 2013, 01:31:13 pm »
Looking good, Mr. Carter!!!!  :cheers: ;D
Nice work.... :applaud:
« Reply #471 on: July 07, 2013, 02:46:40 pm »
The Sweathogs approve. :cheers:
tron84
« Reply #472 on: July 07, 2013, 04:28:43 pm »
Well I got my barstick in yesterday.  I got it put together last night.  Now I need to get the parts for it & the marquee. Then figure out something for a colored 1/2" t-mold.  Might try to see if the dye takes to it or not. ;D  I am kicking around of doing Kung Fu Master for this, one I love that old school game.  I grew up playing it in the day.  Plus the marquee is pretty cool.  ;D  My other thoughts are Rampage or Raiden, well see.
But here she is, its pretty.... Thanks Huraman looks great!!! :cheers:
Once it is finished, I will update.
« Last Edit: July 07, 2013, 04:30:24 pm by tron84 »
PTD
« Reply #473 on: July 07, 2013, 05:58:03 pm »
How do you place and secure the motherboard to the bartop cabinet ?
bzbee
« Reply #474 on: July 07, 2013, 06:31:02 pm »
That looks OUTSTANDING!!! I can't wait to see the finished product.
404
« Reply #475 on: July 07, 2013, 06:31:36 pm »
You can try automotive vinyl dyes on a white piece of t-molding. it's 1000x better than most of these paint cans that are supposedly made for plastic.
Popular brands are SEM, VHT, Plasticote, Color Bond and dupli-color.
tron84
« Reply #476 on: July 07, 2013, 07:06:31 pm »
Ok, thank you for the info. :cheers:  That is good to know, will give it a try.
« Last Edit: July 07, 2013, 07:10:04 pm by tron84 »
404
« Reply #477 on: July 07, 2013, 07:16:54 pm »
have no idea if it will actually work on t-molding but i do know that lots of guys that paint vinyl and plastics swear by it. worth giving it a shot.
« Reply #478 on: July 07, 2013, 07:33:52 pm »
Just used a few wood screws to secure it to the bottom. One part of the micro-atx mobo peeked out from under the monitor and just under the cp.
tron84
« Reply #479 on: July 07, 2013, 07:34:18 pm »
It is worth giving it a try.  Something out there has to dye the T-mold. ;D  I just cant believe that there are only black & white for 1/2" T-mold.  Found red, grey & charcoal but have to get 500'.  No thank you, dont need that much 1/2". ;D
