Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1055265 times)
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #400 on: June 24, 2013, 11:17:10 am »
Bartop row...
« Reply #401 on: June 24, 2013, 11:42:04 am »
These are taken from his plan pictures he posted, inverted so its black lines on white, and scaled up.  The lines are a little yucky, but that why you cover them with art.
ebarlow99
« Reply #402 on: June 24, 2013, 01:15:33 pm »
love the 3 designs!! look great!
JDFan
« Reply #403 on: June 24, 2013, 01:19:52 pm »
Just a suggestion but you might want to change them to 300PPI instead of 72 --- figure if they are being used for artwork you'll want at least a 300PPI final image and some users may not realize they need to adjust it before drawing up the art for printing. Also if you want to clean up the holes if using a 300PPI image using a brush size of 338 pixels will place a 1-1\8" Diameter circle with a single mouse click where desired.
« Reply #404 on: June 24, 2013, 01:43:25 pm »
Feel free to do all that, Im at work using MSPaint :p
JDFan
« Reply #405 on: June 24, 2013, 02:03:41 pm »
OK here you go (Note : don't have one to verify sizing is correct so if someone could test print and verify dimensions prior to using as a template - just to make sure it would be helpful for others !!:
« Last Edit: June 24, 2013, 02:06:26 pm by JDFan »
« Reply #406 on: June 24, 2013, 02:04:49 pm »
OK here you go :
Hey thanks for that! My photoshop skills are severely lacking... lol
JDFan
« Reply #407 on: June 24, 2013, 02:49:00 pm »
OK here you go :
Had a bit of time so went ahead and did the sides also in case others needed them -- Just need someone to print a test copy and verify the dimensions are correct (went by the 21.43 inchx18.6 measurements in the posted files and added a 1\2 inch border around the oputside - so they should be correct but would be best to get confirmation before using for sending out for final printing !! (IE> Use at your own risk as I do not have a panel to test the dimensions are correct so PLEASE print a test print to verify before investing $$ for printing art using them !!)
« Reply #408 on: June 24, 2013, 02:57:21 pm »
« Reply #409 on: June 25, 2013, 12:42:23 am »
What are the dimensions on the verty?
« Reply #410 on: June 25, 2013, 09:12:29 am »
Is awesome a dimension?  :P
15" wide X 20.81" deep X 26.14" tall
« Reply #411 on: June 25, 2013, 10:30:54 am »
First post updated with vertical pricing.   :cheers:
stoopid2001
  • Last login:February 12, 2019, 09:12:05 pm
« Reply #412 on: June 25, 2013, 12:10:51 pm »
I'm having a fit issue with a mag stik plus on the 2 player-
With the stik "installed" it will hit the 2 buttons on the admin panel, not letting the control panel sit forward enough.
« Reply #413 on: June 25, 2013, 12:13:25 pm »
You may have to find shorter barrel buttons to place there.
stoopid2001
« Reply #414 on: June 25, 2013, 12:23:54 pm »
I just emailed paradise arcade for some length measurements.  They sell short and long (standard) barrel buttons but don't list the dimensions on their site.  Hopefully the pics will help the next noob when choosing parts! :laugh:
degenatrons
« Reply #415 on: June 25, 2013, 01:01:31 pm »
I workaround this problem with these black washers,  they're about 6 or 7mm wide.  You get these with the thinner LED button sets.  Can be adapted for regular buttons by cutting of the lip on the inside.
« Reply #416 on: June 25, 2013, 02:52:43 pm »
First customer to order a MVS-inspired kit gets free red vinyl for the sides!   :cheers:
cdf12345
  • Last login:February 13, 2020, 08:36:10 am
« Reply #417 on: June 28, 2013, 01:38:35 pm »
I was just about to post the exact same issue with the 2player bartop
I would recommend flipping the admin panel on the 2 players so the button slots are not in front of the joysticks.
stoopid2001
« Reply #418 on: June 28, 2013, 01:47:56 pm »
My 2 player admin panel is the other config.  Inspired by degenatrons washers, I cut a piece of 1 1/4 pvc pipe to use as washers.  Paradise arcade sells short barrel buttons that are 54mm instead of the 60mm standard ones.  I don't think the 6mm would have solved the problem though.
« Last Edit: June 28, 2013, 01:49:31 pm by stoopid2001 »
rablack97
« Reply #419 on: June 28, 2013, 02:10:21 pm »
I feel the pain here,  I use Degenatrons plans for scratch builds and Jstik/button placement drives me out of my mind.
Your gonna have to modify your plans to lengthen the height of the CP to push the Jstiks further up to accomodate those buttons, most folks use the standard long barrell buttons.
I started putting buttons on the sides.
I would think 80mm should be big enough to support any jstik and still give you room for your buttons.
Oh yeah, gonna get me that nintendo looking genius contraption you done went off and designed  :)
« Last Edit: June 28, 2013, 02:12:12 pm by rablack97 »
« Reply #420 on: June 28, 2013, 02:16:26 pm »
This directed at me?  Whatchoo talkin' 'bout?
As for the admin buttons, I used short barrels on mine, not sure where I got them from, they were in my parts bucket.
Ultimarc gold leaf buttons look short, but I don't have a measurement for those.  Naturally, I can adjust plans a bit so this is less of a headache for future buyers.
rablack97
« Reply #421 on: June 28, 2013, 02:17:35 pm »
OK here you go :
I just had something similar to this done recently.  The printed recommended a 3/4" bleed line and a 3/4 padding/cut line.
So what you would have is 3 shapes, 1 inside the original and 1 outside of the original....
Decent results.....
rablack97
« Reply #422 on: June 28, 2013, 02:23:49 pm »
The black one man..........I LOOOOOOOOVEEE THAT....
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=130522.0;attach=291772;image
I would adjust it, nothing like some Happs button  :)
« Reply #423 on: June 28, 2013, 02:25:12 pm »
Ahh the vertical.  Yeah, that one is my favorite I've made so far...   :cheers:
rablack97
« Reply #424 on: June 28, 2013, 02:27:43 pm »
Fix that depth though man, i refuse to go short barrel and use spacers, you fix that you can put me down for one of those....
« Reply #425 on: June 28, 2013, 02:39:02 pm »
Sounds good to me.   :cheers:
« Reply #426 on: June 28, 2013, 02:40:21 pm »
Sneak preview of what's next...   ;)
rablack97
« Reply #427 on: June 28, 2013, 02:42:34 pm »
is that a viewlix?
that looks like a darn jigsaw puzzle....
« Reply #428 on: June 28, 2013, 02:46:01 pm »
How much is that? :o
« Reply #429 on: June 28, 2013, 02:46:11 pm »
is that a viewlix?
Ding ding ding...
And, yeah, jigsaw puzzle-ish to be sure.  But, if the end result matches what I have in my head, will look good.   :applaud:
« Reply #430 on: June 28, 2013, 02:47:00 pm »
Don't know yet, plans are with my CNC guy, he has to take a good look at them and let me know.
rablack97
« Reply #431 on: June 28, 2013, 03:05:18 pm »
I'm starting with ther vert first, that viewlix is for grown folks only....... :dizzy:
« Reply #432 on: June 28, 2013, 03:29:44 pm »
Fixed.  Moved the admin buttons, moved some buttons on the CP, no interference now (on the vertical).  :cheers:
lowgunn
  • Last login:February 08, 2025, 02:33:10 pm
« Reply #433 on: June 28, 2013, 11:48:26 pm »
is that a viewlix?
Ding ding ding...
How am I gonna explain the viewlix to the wife....
TheDude
  • Bartops all the way !
    • BARTOPMANIA
« Reply #434 on: June 29, 2013, 03:46:35 am »
Hey, you've got a nice selection of bartops !
I'm especially interested in the upcoming viewlix-shaped one !
You should be granted a medal for bartop accessibility to the masses ! ;)
« Reply #435 on: June 29, 2013, 11:34:46 am »
That's a full-size Vewlix, not a bartop.
rablack97
« Reply #436 on: June 29, 2013, 11:56:29 am »
What size monitor does the vert hold and how much?
Sent from my PC36100 using Tapatalk 2
Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #437 on: June 29, 2013, 01:28:22 pm »
I designed it to fit a 17" Dell LCD, rotated of course.  1708fb is a good one as it's meant to be rotated.
Kit is $180 shipped, add $10 for slot cutting.
rablack97
« Reply #438 on: June 29, 2013, 11:03:00 pm »
What about the guts...micro pc boards only or can a decased xbox fit....
« Reply #439 on: June 29, 2013, 11:05:18 pm »
Plenty of room in the vertical, I would think a decased xbox would be fine.   :cheers:
