Author Topic: Change buttons to Normally Open?  (Read 2706 times)
007craft
  • Last login:March 03, 2013, 09:09:03 pm
« on: February 11, 2013, 05:39:28 pm »
So I went and bought some push buttons for my arcade.  They are tiny buttons which I will be using for emulator functions.  Unfortunately, I already drilled holes and put them in my cab only to find out they are Normally closed buttons.  Is there anyway I can convert them to normally open?
Re: Change buttons to Normally Open?
« Reply #1 on: February 11, 2013, 05:55:07 pm »
What buttons? Link? Pics?
007craft
« Reply #2 on: February 11, 2013, 05:59:10 pm »
Umm, I bought them at a local store.
http://www.leeselectronic.com/index.php?id_product=3277&controller=product
Theres no pics but not sure why that would matter?  they are NC switches with 2 prongs and I want to make them NO switches
« Reply #3 on: February 11, 2013, 07:01:57 pm »
There's thousands of different types of switches. How the ---fudgesicle--- am I supposed to know what one you have without a detailed description or a pic?
If there are only 2 prongs (terminals) on the switch and it is NC... go buy new switches.
Dawgz Rule
« Reply #4 on: February 11, 2013, 07:10:07 pm »
Because it is a two prong, you are pretty much out of luck.  Your best bet is to simply swap them out with the equivalent "normally open".  Check the part numbers and you will typically see an "NC" or "NO" to indicate what the normal position is.  You may also find it in the description.  Look at the bright side....it was a relatively inexpensive mistake.
  • Last login:Today at 11:45:21 am
« Reply #5 on: February 13, 2013, 12:23:17 pm »
Well you could use electronics to invert the switches, but by far it is simpler, easier to troubleshoot, and probably cheaper to just change the switches to NO, just as everyone else has suggested.
  • Last login:Today at 11:28:34 am
    • GroovyGameGear.com
« Reply #6 on: February 13, 2013, 02:36:20 pm »
It might even be as simple as a resistor or two for each switch, depending on the encoder being used.  But, yes, proper switches would make much more sense.
paigeoliver
  • Awesome face!
« Reply #7 on: February 14, 2013, 03:26:44 pm »
Just replace them, you will spend more time and money trying to get around them than just replacing them.
