Author Topic: Vertical games rotated on my horizontal monitor  (Read 2184 times)
  • Last login:November 13, 2025, 08:40:37 pm
« on: December 12, 2012, 01:41:56 pm »
I seem to be having all kinds of weird issues. The latest issue is that I have a bartop with a horizontal monitor installed. When I play a game, like Galaga, it will be rotated 90 degrees to the left. When I play Galaga '88 it is rotated 90 degrees to the right. I figured my Mame.ini was screwy, so I deleted it and ran Mame -cc to generate a new one. I get the exact same issue! I'm using Mame 1.06 and I don't ever remember having this problem before.
Any chance it's my video card? I'm using a Dell 4600 with the onboard Intel 82865G graphics board.
Any suggestions? I figured a default Mame.ini would fix it for sure.
  • Last login:Yesterday at 02:10:53 pm
Re: Vertical games rotated on my horizontal monitor
« Reply #1 on: December 12, 2012, 01:51:16 pm »
The ini files for the individual files in the ini folder override mame.ini
Try deleting one of those for a game that is oriented wrong.
« Reply #2 on: December 12, 2012, 01:55:35 pm »
Also, some games are listed as 90 and some are listed as 270 in mame.xml, so that's probably the way they originally were.
« Reply #3 on: December 12, 2012, 01:59:24 pm »
Thanks dude.
I installed a PCI video card and it's working just fine now. I suppose that means it's the video? I've had lots of problems with the onboard graphics of 5-7 years old PC's. The newer intel onboard work great.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: December 12, 2012, 02:36:20 pm »
I never had problems with the stock settings in MAME32 .106 .  Note attached. [even with onboard video, of which my first PC was an Intel 845G] All games run at the desktop resolution, in horizontal orientation.
(I have always used MAME32, at least to set up stuff - though without any effects, etc, no set-up is needed.)
-Banned-
« Reply #5 on: December 12, 2012, 02:51:00 pm »
So games like Galaga work ok on your setup? Do you have Mala point to your Mame32 install and it works fine? I'll check that out if so, not adding in a video card would be sweet.
« Reply #6 on: December 12, 2012, 03:10:58 pm »
No Luck. I dug up an old thread from back in the day: http://forum.arcadecontrols.com/index.php?topic=28324.0
All I can suggest is you are using one of the newer Intel onboard graphics. The one I'm using is junk.
  • Last login:September 20, 2025, 07:17:24 am
« Reply #7 on: December 12, 2012, 03:15:25 pm »
Using a front end? I know Mala will orientate the game if you choose it to in options.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #8 on: December 12, 2012, 03:44:14 pm »
@lew: 845 and 865 were the same generation - respectively, Dell 4500 (lower P4) and 4600 (upper P4). Should work the same. Do H and V games run horizontal from MAME itself? If so, then it might be a Mala setting like DaOld Man mentioned:
« Last Edit: December 12, 2012, 03:52:31 pm by Gray_Area »
-Banned-
« Reply #9 on: December 13, 2012, 08:42:24 am »
Sorry guys -
I meant to reply yesterday and wrote up a response, but I guess I didn't post it. Good thought on using mame command line. I did, and it was still sideways. So I did the following:
- redownloaded mame .106 and tested it (through MALA and CLI) still sideways
- downloaded mame .147(latest release) and tested it. IT WORKED!
Why would that work? I downloaded a release in the middle, like .125 or something, and it worked also. So, not sure what happened in which version of Mame but .147 worked great. Of course, now I need a new set of Mame roms and instead of trying to figure out the CLRMAMEPRO mess, I'm getting a complete updated set.
I'm also wondering why a new video card also fixed the issue, but at this point I don't care so much as long as everything is working with onboard video I'm good. Thanks Gray_Area, DaOldMan, and Bad Mouth for making me keep at it. It would've been easy just to use a different video card and call it a day.
  • Last login:October 28, 2025, 11:06:27 am
« Reply #10 on: December 15, 2012, 04:39:30 pm »
Have you tried the -norotate option?  There are a handful of rotating options explained here:  http://easyemu.mameworld.info/mameguide/mameguide-options.html
D
