Author Topic: Antimatter - LED side setup v.2 - All Finished 02.22.13  (Read 31266 times)
SpaceHedgehog
  • Almost done ...
The gray is a lot better than the white. Not sure about the marqee - it is a little too cartoonish but it's important to go with what you like. Wish I could offer some better suggestions .....
Click a pic for a video tour
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
I personally like the cartoony but i think it needs more.  im not sure what but more.    maybe a mad scientist or something???
Louis Tully
« Last Edit: February 12, 2015, 09:52:46 am by Louis Tully »
  • Last login:Today at 01:20:49 am
If you want to go a little Star Trek, perhaps a warning that if the magnetic containment field strength goes below 15%, the field will collapse, destroying the cab.
Louis Tully
« Last Edit: February 12, 2015, 09:52:52 am by Louis Tully »
Nestafari
  • Last login:August 21, 2019, 09:08:58 am
Your Lowboy is amazing...The style is pure the cuts are agressives and the cp is crazy...
You want to paint your cab...That idea is really good. what about a pencil in a banksy style? this draw is a bit antimatter   :dunno
why dont you put the logo at the top of the cab and smaller not in central stage.
And a astronom like this should be easy to paint..Some ideas for the marquee too..
Ilove the antimatter is written on the draw with the 2 guys with glasses on the side
Hope it helps..good luck
« Last Edit: December 13, 2012, 01:16:48 am by Nestafari »
Space Simpsons cab in progress
Louis Tully
« Last Edit: February 12, 2015, 09:53:09 am by Louis Tully »
Louis Tully
« Last Edit: February 12, 2015, 09:54:35 am by Louis Tully »
BurgerKingDiamond
Re: Lowboy. Casters and a complete test fit. 12/14
« Reply #48 on: December 14, 2012, 12:11:56 pm »
I really like the design of your lowboy.
You could get a better fit with the bezel if you decase the monitor though.
-Welcome to the Fantasy Zone.
Louis Tully
« Reply #49 on: December 14, 2012, 03:45:19 pm »
« Last Edit: February 12, 2015, 09:54:40 am by Louis Tully »
Louis Tully
« Reply #50 on: December 15, 2012, 11:59:22 am »
« Last Edit: February 12, 2015, 09:54:47 am by Louis Tully »
Louis Tully
Re: Lowboy. Sound reactive LEDs work. 12/15
« Reply #51 on: December 24, 2012, 01:12:44 pm »
« Last Edit: February 12, 2015, 09:49:36 am by Louis Tully »
jmike
That's looks fantastic. I'm sure they look even better in person. Nicely done.
And how much you curling back there? Those 50lbs each   :notworthy:
Merry X-mas to you and your family.
Enjoy!
  • Last login:Today at 03:34:59 am
Is that a round base on there? I love it if it is!
Louis Tully
« Last Edit: February 12, 2015, 09:49:05 am by Louis Tully »
Louis Tully
« Last Edit: February 12, 2015, 09:49:00 am by Louis Tully »
Re: Antimatter - Lowboy. Illuminated side art. Some this and that. 12/25
« Reply #56 on: December 25, 2012, 08:08:57 pm »
Looks great.   :applaud:
The only thing you might want to consider is black carriage bolts to go with the black dust washers, black Atari button cones, and black button bodies.
Louis Tully
« Reply #57 on: December 25, 2012, 08:34:59 pm »
« Last Edit: February 12, 2015, 09:48:45 am by Louis Tully »
« Reply #58 on: December 25, 2012, 09:13:57 pm »
You can buy black powder coated aluminum similar to this for the kick plate.
Should be pretty durable.
Louis Tully
« Reply #59 on: December 27, 2012, 10:47:39 am »
« Last Edit: February 12, 2015, 09:48:39 am by Louis Tully »
« Reply #60 on: December 27, 2012, 11:16:49 pm »
Looking good Louis! Im debating whether or not to add a kick plate to A Little Rage.
Louis Tully
« Reply #61 on: December 28, 2012, 06:32:40 am »
« Last Edit: February 12, 2015, 09:48:32 am by Louis Tully »
Louis Tully
« Reply #62 on: December 28, 2012, 06:53:03 am »
« Last Edit: February 12, 2015, 09:48:26 am by Louis Tully »
Re: Antimatter - Clear tubing, push pins, styrofoam plates and tape. 12/28
« Reply #63 on: December 28, 2012, 10:09:54 am »
Dad blammit Louis, yet another idea I will have to steal from you for a future build! (Great work on the leds, and I like the way you use common material for your ideas.)
And dont kick me, cause I aint the one who thought of it, but I still think the coin buttons in the dual switch plate was a good idea. Just need to figure out a way to hide the switch holes and paint it black of course.
Louis Tully
« Reply #64 on: December 28, 2012, 11:49:47 am »
« Last Edit: February 12, 2015, 09:48:06 am by Louis Tully »
« Reply #65 on: December 28, 2012, 01:25:28 pm »
One of my current builds uses a variation of this.
Use a stainless steel cover plate like this.
Once the center hole(s) are drilled/nibbled/filed to the right size, use a metal cutoff wheel on a table saw to trim the outer curved portions leaving the flat center portion with countersunk screw holes.
Fodors fun fact: The linked version (F-type/TV cable plate) only needs to be rounded out to perfectly fit the bat-handle Grayhill 04 mini-joystick -- will be posting more on that soon.
Louis Tully
« Reply #66 on: December 30, 2012, 06:46:42 am »
« Last Edit: February 12, 2015, 09:48:00 am by Louis Tully »
CovertJellyfish
  • Last login:December 19, 2013, 06:03:46 pm
Re: Antimatter - Controlled chaos with the control panel. 12/30
« Reply #67 on: January 02, 2013, 05:16:27 pm »
Like the build, what you really need is some texure on that side though to make it look more industrial, http://www.filterforge.com/filters/4497.html I know it looks a bit green, but this is the same type of texuring they use on CGI starship models for the Feds...
Louis Tully
« Reply #68 on: January 03, 2013, 05:45:51 pm »
« Last Edit: February 12, 2015, 09:47:46 am by Louis Tully »
Louis Tully
« Reply #69 on: January 03, 2013, 05:58:57 pm »
« Last Edit: February 12, 2015, 09:47:42 am by Louis Tully »
jmike
Re: Antimatter - It's alive. 01/03
« Reply #70 on: January 03, 2013, 08:52:54 pm »
That thing looks sweet!
 Looking forward to the video with the marquee installed.
Great job as always LT
« Reply #71 on: January 03, 2013, 10:44:00 pm »
Sweet!!
Those coin buttons are bright arent they?
I plan to dim mine a bit with the led wiz (Its going to be interesting working with that led wiz, I can already see some problems with emuls besides mame, definitely need to study up on it more. Having to put off finishing A Little Rage may have turned out to be a blessing.)
Anyway, maybe its the camera making them look so bright, but I have noticed mine being pretty bright at 5 Volts.
Anyway, this is a great build.
Got to try Kinkos for my marquee, (Tired of splicing two or three images together). Can they print on the transparent copy paper?
Louis Tully
« Reply #72 on: January 04, 2013, 07:24:03 am »
« Last Edit: February 12, 2015, 09:47:29 am by Louis Tully »
Louis Tully
« Reply #73 on: January 04, 2013, 07:43:43 am »
« Last Edit: February 12, 2015, 09:47:25 am by Louis Tully »
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: Antimatter - It's alive. 01/03 (LED brightness fix)
« Reply #74 on: January 04, 2013, 08:33:13 am »
Looking good man.  I like the design and the layout.  Everything fits together pretty well.
CovertJellyfish
« Reply #75 on: January 04, 2013, 04:22:00 pm »
That's pretty awesome looking texture. That would definitely make the cabinet look 10x better. If I could actually paint worth a damn, I'd do it.
Welllll..... That's a texture for a CGI model... you would need something that actually created a difference in the surface height to make it more realistic, say about the thickness of paper or cardboard from a cereal box, and build up some serious greebling around the antimatter sigil, plus using the right paints can help, http://www.humbrol.com/paints/paints-by-finish/metalcote-colours/ac5025-27003-polished-steel-14ml-metalcote-enamel-tinlet/ this paint polishes to give a metal finish, I know it looks good on a smal model, how it will look on a larger area IDK...
Louis Tully
« Reply #76 on: January 04, 2013, 04:57:42 pm »
« Last Edit: February 12, 2015, 09:47:12 am by Louis Tully »
Louis Tully
« Reply #77 on: January 04, 2013, 05:01:30 pm »
« Last Edit: February 12, 2015, 09:47:07 am by Louis Tully »
CovertJellyfish
« Reply #78 on: January 04, 2013, 05:17:32 pm »
Now that, if done correctly, would be top shelf badass.
Yep, I'd look around some 3D model sites for ideas for your greebles, and maybe talk to a few model makers, I have an idea of how I would do it, if you want?
Louis Tully
« Reply #79 on: January 04, 2013, 09:00:03 pm »
« Last Edit: February 12, 2015, 09:46:49 am by Louis Tully »
