Author Topic: Power cord socket solution?  (Read 7024 times)
fantoboy
  • Last login:May 24, 2017, 02:02:13 pm
  • I'm a mushroom cloud layin' motha fu($@!
« on: August 29, 2012, 01:06:37 am »
I want to put something like this on the outside of my cabinet:
http://www.amazon.com/IEC-Power-Jack-Chassis-Mount/dp/B0008IW78W/ref=pd_sim_sbs_hi_3
On the inside, everything will be plugged into a smart strip.  I was hoping to find a female to female adapter to connect the two, but I can't.  Any suggestions on the best way to go about this?  All I can think of is either just wire it together or to splice two female power cord ends together.
    • GroovyGameGear.com
Re: Power cord socket solution?
« Reply #1 on: August 29, 2012, 01:37:25 am »
I'd just cut the male plug off the smart strip, and solder the wires to the terminals of the part you linked to.  Just make sure that you get the wires hooked up to the correct terminals, and heat-shrink the connections to insulate them.
  • Last login:Today at 11:42:03 am
« Reply #2 on: August 29, 2012, 01:53:47 am »
You might want a model with an illuminated switch and fuse like this:
If you don't want to cut up the smart strip cord, mount a deep electrical box (pref. a cross between these two types) on the inside with a dual outlet.  Ensure that the outlet box mounts so that the feedthru is covered.
Wiring connections for illuminated switch attached.  (2 is ground.)
« Last Edit: August 29, 2012, 02:00:29 am by PL1 »
Unstupid
« Reply #3 on: August 29, 2012, 01:54:17 am »
what Randy said....  Only thing I'd add is you may want to look at the one that includes the switch... that way you have a single external point that you can turn on the whole machine.
http://www.amazon.com/Amico-IEC320-Module-Switch-Socket/dp/B0050HH70E/ref=pd_cp_e_1
« Last Edit: August 29, 2012, 01:58:19 am by Unstupid »
fantoboy
« Reply #4 on: August 29, 2012, 02:24:34 am »
I was thinking that I would want a push-button instead of a switch though, to wire to the PC power button.  You guys are controlling the smart strip with the power switch?
mgb
  • North East, US
« Reply #5 on: August 29, 2012, 08:19:04 am »
The power switch wired to the pc would be seperate. Its best to have a main power switch like the others above have said and then you would have a seperate pc power button.
the power switch on the cord socket would control power to the whole cab, so when its off, there is no power to the smart strip.
TopJimmyCooks
« Reply #6 on: August 29, 2012, 08:48:06 am »
Y'all are over-complicating this.  I say if you have a momentary switch up front controlling the PC and smart strip for day to day on/off, removing the cord from the IEC socket is a better means of disconnect and a main switch is redundant extra complication extra redundant.  Get your free IEC socket off an old tv, power supply, printer, etc. and go to town.  Don't send money to the Amazons that you don't have to.
jpS14
  • Last login:October 04, 2022, 04:34:26 pm
« Reply #7 on: August 29, 2012, 08:56:46 am »
I agree with TJC. I got a IEC off a dead power supply and just wired the smartstip to it. Works just fine and I spent no money doing it.
SavannahLion
« Reply #8 on: August 29, 2012, 09:51:19 am »
Clearly you've never had a reach around.  ;)
  • Last login:Yesterday at 06:13:57 pm
« Reply #9 on: August 29, 2012, 10:03:15 am »
I agree with jpS14, who agrees with TJC.
I agree with TJC. ...
wcndave
  • Last login:June 10, 2021, 03:37:36 am
« Reply #10 on: August 29, 2012, 11:02:31 am »
If you want to, I think you can get power strips where turning your PC on/off turns the strip on/off, so you only need one button.
TopJimmyCooks
« Reply #11 on: August 29, 2012, 11:32:08 am »
Hmm - not really sure where that comes from or goes, but I will say that you are correct.
SavannahLion
« Reply #12 on: August 29, 2012, 03:40:52 pm »
It's when you don't have easy access behind a piece of equipment and it's not always feasible to pull it out. A master switch there is easier to reach around and feel for. If you pull the power cable from there (not from the wall) it's much harder to plug it in, especially if there's an orientation to the cable or other recepters there.
TopJimmyCooks
« Reply #13 on: August 29, 2012, 04:55:08 pm »
Oh, ok.  The term reacharound could be construed to mean something entirely different than what you meant.  If you want a switch on the back, do it.  I bet you're going to have to pull it out from the wall to service it anyway.  I wouldn't spend extra to do it.  Hell, what if you leave it off by accident, you've got a reacharound to get it back hot.  Now, if the cab line cord was hard connected, I would say it was basically required to have the switch.
mgb
  • North East, US
« Reply #14 on: August 29, 2012, 05:08:20 pm »
I don't see whats over complicated about having a main cabinet shut off.
ahofle
    • Arcade Ambience Project
« Reply #15 on: August 29, 2012, 05:54:19 pm »
Anyone have a link for a similar switch that includes the fuse?
CoryBee
  • Bopity Boopy
« Reply #16 on: August 29, 2012, 07:44:04 pm »
Or get a $2 power strip, crack open the power strip and short the wires closed, then pop out the switch and move it to the back of the cabinet.   ;D
haha jim, i did exactly that a few days ago
SavannahLion
« Reply #17 on: August 29, 2012, 07:50:37 pm »
Hey, nothing wrong with keeping your mind in that gutter. ;)
When it comes to the portions that deal with mains, one shouldnt be too stingy. If the cord is cracked, replace it. Pay the small price to pickup a multimeter to double check your wiring. Spend a little extra for known good PSU's to avoid the questionable Chinese knockoffs. In the greater scheme of things, spending a negligable amount of money and a bit of timefor the convenience of a well designed circuit is well worth it.
I'm not saying one should shell out $200 for a power strip when a $5 power strip is just as effective though.
In any case, every cab is different.
fantoboy
« Reply #18 on: August 29, 2012, 08:31:23 pm »
That's the smart strip I was referring to in my original post.  I want to wire that to the inside of the jack mounted on the case.
Hockeyboy
  • Last login:April 17, 2022, 02:48:38 pm
« Reply #19 on: August 30, 2012, 09:05:33 am »
This is exactly what I'm planning on doing. I got the socket from an old computer power supply - just unscrewed it from the box and snipped the wires that were soldered to the posts. I'm going to de-solder the wires that are still connected, then re-solder the cut wires from the smart strip. Easy as pie to do, and it's not going to cost me anything. Besides, if you look at that part you mention, Amazon sells it, but it actually ships from Hong Kong and a couple reviews said they never received their part after weeks of waiting.
gtxjoe
  • Last login:August 19, 2022, 08:55:58 am
« Reply #20 on: August 30, 2012, 09:46:54 pm »
Here are some other options
http://www.amazon.com/SF-Cable-prong-Adapter-60320-C14/dp/B004OC579E/ref=pd_sbs_lg_1
or
Take a second PC cord, cut the male 3 prong plug off of it and replace it with w 3 prong receptacle.  Now you can plug you smart strip into this
http://www.icreatables.com/electrical/plug-cord-replace.html
