Author Topic: Clarification on multiple trackballs...  (Read 1935 times)
Well Fed Games
  • Delicious!
« on: August 20, 2012, 08:37:39 pm »
So I have a gutted Millipede cocktail I might MAME into a "multi" pede... if I have two trackballs, and an opti-pac, will I be able to play 2 players appropriately (p2 disabled when p1 is playing and vice versa)?
millercentral
  • Last login:March 07, 2024, 04:38:47 pm
Re: Clarification on multiple trackballs...
« Reply #1 on: August 23, 2012, 04:34:36 pm »
Opti-Pac can support two trackballs (and two spinners) connected simultaneously, no need to disable them, mame will recognize them independently. I have two trackballs in my 3-sided cokctail and they work great together...
Well Fed Games
  • Delicious!
« Reply #2 on: August 23, 2012, 08:45:30 pm »
Thanks for the confirmation!  :cheers:
Javinator
  • Last login:April 13, 2013, 06:13:43 am
  • Forever planning the project
« Reply #3 on: August 24, 2012, 10:26:27 am »
From Ultimarc:
Plug USB cable into the connector on the board and connect to the PC USB port. The PC will auto-detect the device and install a standard mouse driver. (Actually it installs two mouse devices)
Looks like it should work fine  :)
Well Fed Games
  • Delicious!
« Reply #4 on: August 24, 2012, 11:55:27 am »
Thanks, I checked the site but wasn't sure how windows would handle two mouse devices (if it would sum the input into one, etc.- I was looking into using trackballs for a homebrew game but the game dev forums said 2 mice were a no-go). But I guess if it did combine the input no one would buy the optipac!  ;D
From Ultimarc:
    • GroovyGameGear.com
« Reply #5 on: August 24, 2012, 02:11:43 pm »
MAME can do it, with the proper command line switch, so it can be done.  I think you need to look at the RAW input methodology in order to support two mouse devices simultaneously.
Well Fed Games
  • Delicious!
« Reply #6 on: August 24, 2012, 02:46:03 pm »
Thanks Randy. I assume a couple Opti-Wiz(es) would be another alternative for a 2-trackball cocktail?
« Reply #7 on: August 24, 2012, 02:53:33 pm »
Yes.  If you decide to go this route, make sure that each Opti-Wiz on the same PC has a unique device number (i.e Device 1 and Device 2).
