Author Topic: advmenu and advancemame  (Read 4048 times)
loonytu
  • Last login:March 02, 2017, 09:40:51 pm
« on: August 12, 2012, 11:23:14 pm »
having problems some of the games i need to change to vertical is cause they only work that way on my lcd it was easier in arcadeos but since i changed my front end to advmenu i cant seem to rotate them it says i can do each game seperate in advmame configuration file but not sure how. i built a cocktail cabinet so i can play hor or vert games i need your help
Thenasty
  • Last login:November 24, 2025, 04:30:42 pm
Re: advmenu and advancemame
« Reply #1 on: August 13, 2012, 01:43:11 am »
in advmame.rc
gameROMname/display_ror yes
or
gameROMname/display_rol yes
you could do this per game name.
Free VGA Breakout Cable
loonytu
« Reply #2 on: August 13, 2012, 09:01:53 am »
thanks i will give it a try i think you save me from going insane lol
loonytu
« Reply #3 on: November 04, 2012, 10:12:57 am »
it worked thxs now the problem i having is advmenu s not showing most of my roms why
Thenasty
« Reply #4 on: November 15, 2012, 01:55:14 pm »
maybe the game you reffering is missing or incomplete etc....
you can add manually to try to see or use the same version of MAME and verify your ROM is good.
Adding manually.... Edit the Gamelist.RC (forgot the exact filename) and see how advmenu do it and just make one with the GAMEROm you wanna test.
loonytu
« Reply #5 on: February 18, 2014, 10:26:10 pm »
another problem how do I play a avi file just before advmenu loads I saw a mame lightening avi which looked cool can I do it
Thenasty
« Reply #6 on: February 18, 2014, 10:31:34 pm »
use batch file
if using pure DOS insert it in your Autoxec.bat file before ADVMENU
ex:
@echo off
,,,,,,,,,,,,,,, (ALL STUFF)
REM Below to execute the Avi Program for the Intro.Avi you like
AVI_PLAYER_FOR_DOS INTRO.AVI
Advmenu
loonytu
« Reply #7 on: February 18, 2014, 11:06:59 pm »
AVI_PLAYER_FOR_DOS INTRO.AVI is this what I put in just replace intro with mine
« Last Edit: February 18, 2014, 11:12:47 pm by loonytu »
loonytu
« Reply #8 on: February 18, 2014, 11:30:39 pm »
some people asking for my bezel pic
Thenasty
« Reply #9 on: February 19, 2014, 10:28:25 am »
you  need to find an AVI player for DOS.
That was just an example.
loonytu
« Reply #10 on: February 19, 2014, 08:26:01 pm »
I got it thxs just ave to deal with the quickview shareware
« Last Edit: February 19, 2014, 10:55:20 pm by loonytu »
