Author Topic: My 4th try to building a arcade cabinet!!  (Read 19205 times)
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
Re: My 4th try to building a arcade cabinet!!
« Reply #40 on: February 15, 2013, 09:30:00 pm »
Thanks Nephasth! I have to admit, I got the idea for the LEDs from you! Instead of using heat shrink to stop the light from bleeding. I used the extra fasteners.  Im still having troubles with getting ledblinky setup right.
ark_ader
  • I glow in the dark.
« Reply #41 on: February 16, 2013, 08:06:58 am »
I like it, and I think you did a great job.  :applaud:
Fourth time a charm!
Mr Wilson
  • Last login:August 14, 2018, 01:24:44 pm
  • it never ends!!!!
« Reply #42 on: February 16, 2013, 09:07:27 am »
looking real good,wish you could pick up cabs that cheap here in UK
lcmgadgets
« Reply #43 on: February 16, 2013, 09:52:18 am »
4th attempt! Good for u, man, don't give up! You're a testimony to perserverance! I've gone thru several concept/partial plans myself. I finally decided on a 'Ghost in the Machine Mark II' semi-clone--which'll I'll probably never build now, for good reasons I won't bore u with.
Those cabs look great! Good for u! :applaud:
Professor Hayashida
Brian74
« Reply #44 on: February 17, 2013, 12:37:14 am »
Thanks a lot guys, really means a lot!!  :cheers: I am doing some updates, I will post some pics soon!!
Brian74
« Reply #45 on: April 17, 2013, 07:21:24 pm »
So I managed to finally start upgrading my cabinet. I replaced the old Arcade crt with a Samsung 27" LCD. So I made a new Bezel for it. I also made my control panel wider. Went from 28.5" to 36". I love the shoulder room I have now.
Sent from my SGH-T989 using Tapatalk 2
mgb
  • North East, US
« Reply #46 on: April 17, 2013, 11:12:15 pm »
I like where you're going with this. The wider control panel is looking great.
Seith
« Reply #47 on: April 18, 2013, 12:38:01 pm »
Nice!  That's gonna look really sweet once you splash some greens and blues on there!
lcmgadgets
« Reply #48 on: April 19, 2013, 12:25:19 am »
That looks really great. Go man, go!
Professor Hayashida
« Reply #49 on: April 19, 2013, 10:48:03 am »
Would love to see "before" and "after" pics side by side once you're done!  Nice!
D
segaleeroy
  • Last login:May 01, 2013, 03:39:43 pm
« Reply #50 on: April 19, 2013, 03:18:16 pm »
forsome reason i no that style of machine i just cant quite put my finger where i have seen them great build thou looking great
Brian74
« Reply #51 on: April 19, 2013, 09:37:19 pm »
Thank you guys for the comments!  :cheers: Weather has not been very good here in Mn. Its suppose to be spring, but we keep getting snow   :cry:
Brian74
« Reply #52 on: April 20, 2013, 08:01:58 pm »
I went to my storage garage to get a few things. I have the twin cab to the one that is getting the face lift stored there. I sat there and stared at for a few mins. Then I saw the 29" crt monitor sitting next to it. Then it hit me!! Swap out the the lcd for the crt and make it a vertical cabinet!!!
Brian74
« Reply #53 on: April 20, 2013, 08:03:13 pm »
Brian74
« Reply #54 on: April 20, 2013, 08:09:04 pm »
Here is the other cabinet. All stripped of hardware. The bottom half is laminate, the top has some kind of vinyl. There are a few deep scratches in both. Anyone have any ideas how to repair or remove the vinyl? Fix or remove the laminate?
Brian74
« Reply #55 on: April 20, 2013, 08:10:17 pm »
« Reply #56 on: April 21, 2013, 12:01:15 am »
upgrade is 1000% better now that you are went back to CRT.
« Last Edit: April 21, 2013, 12:03:14 am by harveybirdman »
Brian74
« Reply #57 on: April 21, 2013, 07:00:15 am »
The crt will be in the vertical cabinet. My LCD will be going in the new cabinet.
mgb
  • North East, US
« Reply #58 on: April 27, 2013, 12:52:35 am »
Wait I'm confused,
so you're redoing the cab with a 27" vertical crt and building a new horizontal with an lcd?
because your first pics on page 2 showed the cab with the wider panel and horiz bezel but then later pics show the same cab with a vert crt and no panel.
I gotta say, I have  a 27" vertical CRT and still I drool when I see that pic of your vert crt in there
TGov
  • Last login:March 21, 2017, 02:07:54 pm
« Reply #59 on: April 28, 2013, 12:32:58 am »
Did you only have one CRT?  I must have missed that.  I will take a working CRT anyday over a LCD for arcade gaming.
Great job on the build btw.  A very cool cab that makes a great MAME machine.
Brian74
Re: Re: My 4th try to building a arcade cabinet!!
« Reply #60 on: April 28, 2013, 09:14:48 am »
Wait I'm confused,
Yep thats what I'm doing. Mine I believe is a 29"
Brian74
« Reply #61 on: April 28, 2013, 09:16:32 am »
Each one had a crt. One is washed out and has lines running over the screen.
mgb
  • North East, US
« Reply #62 on: April 28, 2013, 02:27:36 pm »
Wait I'm confused,
Ok cool
It may say 29" but it's most likely 27" viewable
Brian74
« Reply #63 on: May 02, 2013, 11:09:32 pm »
So here is a update. I managed to redesign my cp for what is now a vertical cab. I think I will name it "Vertical Supremacy" see as it has a 27" crt. It sports 2 happ rotarys, il translucent centers with a black outer ring. Zippy 4 way, x-arcade trackball with a GGG trackball and rgb upgrade. Last but not least, a GGG TT2 spinner. Still have to wire it all up and make a bezel. Looking for some ideas for a new marquee. Thoughts, comments good or bad. Pics to follow.
Brian74
« Reply #64 on: May 02, 2013, 11:12:53 pm »
Drnick
  • Plodding Through Life
« Reply #65 on: May 03, 2013, 08:00:58 am »
Did the template help you out in the end?
Brian74
« Reply #66 on: May 05, 2013, 11:44:49 pm »
I tried to figure out how to use gimp to adjust the measurements. But I couldn't.
Brian74
« Reply #67 on: May 05, 2013, 11:48:52 pm »
I got my computer install today. Then I plugged in my hyperspin backup drive to test it out. I have to say, it looks awesome!! Here are some screen shots.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #68 on: May 06, 2013, 09:54:07 am »
I'm not a super huge fan of those bright colors but it's clean and works well, good job!
Brian74
« Reply #69 on: May 06, 2013, 09:55:44 am »
Thanks, I am reconsidering the colors myself.
