Author Topic: Blue Storm  (Read 18520 times)
ccmathome
  • Last login:February 25, 2021, 12:40:52 am
Re: Blue Storm
« Reply #40 on: July 26, 2012, 05:18:30 pm »
Going back to your jukebox build, what did you use for the sound?  What speakers are those and what did you power them with?  Was considering a similar style wall box but I wasn't sure what I wanted for sound.
The speakers are nothing special came from a $30 speaker box at walmart think they are Scosche HD brand. powered from hacked up pc speakers. I plan to redo this jukebox and use a proper speaker setup sometime soon.
Re: Blue Storm
« Reply #41 on: July 26, 2012, 06:41:22 pm »
Cabinet looks great!  :applaud:
ccmathome
Re: Re: Blue Storm
« Reply #42 on: July 27, 2012, 05:47:48 pm »
Thanks emphatic
Today I got some grayscale  test prints made to see how the cp and bezel looked
But the hexagons were too small
Then remade  the hexagon pattern double the original size and happy with it
Now I just need to figure out how to put the oval bit around the player 1&2 start and the art will be ready to print.
Sent from my Xoom using Tapatalk
ccmathome
Re: Blue Storm
« Reply #43 on: July 28, 2012, 05:46:44 pm »
Anyone know a good place I can buy some sanwa buttons need 10 dark blue focusattack and paradise arcade are out
  • Last login:Today at 02:21:11 am
Re: Blue Storm
« Reply #44 on: July 28, 2012, 06:41:54 pm »
http://www.canadianjoysticks.com/sanwa-denshi-obsf-30-solid-colour-snap-in-pushbutton/
Favorable nod from Emphatic and Opt2not - http://forum.arcadecontrols.com/index.php/topic,112512.msg1212000.html#msg1212000
ccmathome
Re: Blue Storm
« Reply #45 on: July 30, 2012, 12:33:10 am »
So I got most of the building done still have a lot of sanding and filling to do hope to start painting very soon
I've also got my controls ordered
ccmathome
Re: Blue Storm
« Reply #46 on: July 30, 2012, 04:54:29 pm »
Got the first coat of paint on the sides
Sorry for all the crappy pics cant find my cam so have had to use my xoom to take them all
ccmathome
Re: Blue Storm
« Reply #47 on: July 31, 2012, 05:28:55 pm »
OK for today I got the main cab almost done still need to sand the black and put down another coat of paint which I will do tonight then I'll  move on to the control panel
ccmathome
Re: Blue Storm
« Reply #48 on: August 04, 2012, 04:53:14 am »
How does this look for the cp overlay
Also got my controls yesterday
Drnick
  • Plodding Through Life
Re: Blue Storm
« Reply #49 on: August 04, 2012, 07:11:59 am »
Nice  :applaud: :applaud: Control panel is looking good, clean and simple.
ccmathome
Re: Blue Storm
« Reply #50 on: August 04, 2012, 05:31:17 pm »
Got most of the cab painted I'll try to install buttons and joysticks tomorrow after I pick up some acrylic
Now I need to finish up the box for the TV and figure out if i can rotate the screen or not.
Re: Blue Storm
« Reply #51 on: August 04, 2012, 06:09:00 pm »
Lookin' sweet!  :cheers:
ccmathome
Re: Blue Storm
« Reply #52 on: August 05, 2012, 09:23:04 pm »
Got the cp mostly done today next up is working on the TV
Re: Blue Storm
« Reply #53 on: August 06, 2012, 01:12:22 pm »
I like how those two pieces blend together. Is it seamless unless you know it?
ccmathome
Re: Blue Storm
« Reply #54 on: August 06, 2012, 09:06:28 pm »
There not seamless but appear to be. I think it turned out alright although I need to redo the cp sometime later cuz the p1 start is off alittle
Sent from my SCH-M828C using Tapatalk 2
RigoHoward
  • Last login:March 17, 2020, 06:10:43 pm
Re: Blue Storm
« Reply #55 on: August 08, 2012, 01:08:20 pm »
Looking pretty good so far :)
ccmathome
Re: Blue Storm
« Reply #56 on: August 15, 2012, 03:55:43 pm »
Update time
Today I got the screen installed but my bezel does not fit so going to have to get a new one made may put a temp black one on for now
Horizontal
Vertical
To rotate the screen just undo the nut and rotate the screen then tighten it back up
Re: Blue Storm
« Reply #57 on: August 15, 2012, 04:32:38 pm »
 :applaud: Awesome.
Seith
Re: Blue Storm
« Reply #58 on: August 17, 2012, 04:47:43 pm »
Really cool looking artwork and color usage!
Re: Blue Storm
« Reply #59 on: August 17, 2012, 05:23:52 pm »
Since your screen rotation is manual, you might want to swap that hex nut out for a wing nut.
ccmathome
Re: Re: Blue Storm
« Reply #60 on: August 17, 2012, 10:17:51 pm »
My local Lowes didn't have any wing nuts that fit ill probably check ace whenever I get around to it though I don't keep the nut tight just enough to keep the screen from moving forward
