November 30, 2025, 03:00:36 pm
Tupperware with a layer of quarter's already on the bottom, so you get that satisfying 'clink!'.
I believe the PONG prototype originally used a loaf pan, so you may be onto something.
What I have done is purchased a 8" cake/loaf pan and drilled a hole in it near the top. I swapped out the bottom bolt on my coin door for a longer one that goes through both the coin door and the cake pan, holding it in place. Since it isn't touching the ground it has a nice ring to it even with the first coin dropped. And as it fills up it totally has "that sound"
