Author Topic: VertiCade - Successor to the Weecade (Finished - and plans uploaded)  (Read 31007 times)
lokesen
  • Last login:August 12, 2013, 12:17:33 pm
    • WeeCade & Project MAME
After three weeks, the VertiCade is finished.
VertiCade plans and artwork (now online!):
http://www.koenigs.dk/mame/eng/drawverticade.htm
Specifications:
http://www.koenigs.dk/mame/eng/specsverticade.htm
Pictures of the finished cabinet:
Most of the arcade games I play, are vertical games. Mr. Do!, Donkey Kong and Galaga are are some of my favourite games. They are all with vertical screen orientation and they all need only on set of controls with just one button. So naturally I wan't to make a cabinet just perfect for this type of old school arcade games.
Check out the whole project here:
http://www.koenigs.dk/mame/eng/stepverticade.htm
I will also update this thread with picture and progress too :)
My goal was to make a compact cabinet with a vertical mounted 17" LCD monitor. This way you could also use the design for a regular mounted 19" monitor by making the cabinet a few inches wider. This way more people will hopefully benefit from the design files I will make available soon :) The cabinet basically started out like the sketch on the left and ended up looking like the one to the right. I made about 15 sketches in between ending up with the result on the right due to size limitations and restrictions internally.
Here is a simple 3D model of the cabinet. I think it is a little bit more modern, sleek and streamlined than the WeeCade design. I can only hope it will be as popular.
I don't think I could have made a more compact design to fit a vertical 17" or a horizontal 19". Most of my design are based around the idea of making the most compact cabinet possible. Less is more - in my opinion.
IMO this design has some advantages because of the low height of the control panel. I always found that the WeeCade was too high to use comfortably at a normal table.
The control panels is made of two layers of 5 mm acrylics, but you could also use 12 mm MDF.
My design only has four pushbuttons, but the is easily room for six buttons there. But I don't think there is any need of more than four buttons for me.
Opposed to my other control panels, this has holes for bolts. I don't have access to making the special brackets and metal control panels I have used earlier on, but with four button head Allen bolts, this should look fantastic too. The top layer has larger holes for the bolt heads, so they are recessed in the layer and will be flush with the surface.
The solution I'm using here is Evonik Acrifix 116. In the US there are similar products from Weld-on and TENSOL in the UK.
Cutting out the sides:
Mouldings:
More mouldings in nice weather:
Started on the panels:
Erection of cabinet!
Housing for backlight and merquee:
Air vents for monitor:
Same:
Front piece mounted:
Support for the front piece:
Waiting for glue to dry:
Time for polyester putty
Making back panel:
Sanding the cabinet:
Front of control panel
Fitting the plugs for testing. Love the Neutrik USB plugs
Back panel:
Priming the cabinet:
Installing LED back light - $2 per strip :)
Looks very blue, but it really not that blue in real life. But it isn't warm white either!
Second layer of paint:
Back panel too:
Four coats of paint later...
2.5" to 3.5" adaptor to mount SSD:
Panel for monitor and backlight for marquee - Made with LED strips (12 volt)
Making plexi for marquee with fine veneer saw:
Frame and plaxi for marquee
Frame:
Frame painted black (spray can)
Mesh for speakers mounted with epoxy:
Speakers fixated with epoxy too - I would rather use screws, but I was not possible with these USB powered Logitech Z110 speakers. Other than that, they sound awesome!
Power and USB ports mounted too:
Back of cabinet with back panel:
12 volt PSU mounted with L shaped profiles and four screws. It's powering the PicoPSU.
Stealing 12 volt for the LED light from the PicoPSU. 5 volt also prepared for later use:
Monitor painted black:
Mini-itx and picoPSU doesn't take up much space and it's passive cooled = 100% silent!
And the back:
Marquee framing:
Screen cover / bezel made:
And finally it's almost finished!
Go here for working drawings (ready in just a few days):
http://www.koenigs.dk/mame/eng/draw.htm
I will update with more pictures tomorrow :)
« Last Edit: April 26, 2012, 07:29:00 am by lokesen »
Weecade, Nanocade, Verticade, Project MAME and Taitorama
More to come...
edekoning
Re: VertiCade - Successor to the Weecade
« Reply #1 on: April 10, 2012, 08:52:57 am »
Great to hear you are working on a new project! Your Project MAME was one of my inspirations for starting my own project :)
I really like the shape. What are the general dimensions?
BobA
  • What Me Worry?
« Reply #2 on: April 10, 2012, 09:41:57 am »
Nice new design.   Some measurements would help in it's construction by others.  :applaud:
lokesen
« Reply #3 on: April 10, 2012, 02:24:53 pm »
I have updated the first picture with some simple dimensions. There will be work drawings later (a week or so) like my other projects.
More to come...
Termin8tor
  • Last login:August 04, 2020, 01:54:23 am
« Reply #4 on: April 10, 2012, 02:37:59 pm »
Great start I can see lots of these popping up in future.  :applaud:
« Reply #5 on: April 10, 2012, 04:01:15 pm »
My last build was a modded weecade.  Can't thank you enough for the original build thread, really helped me out a lot.  One of the mods was fitting a 17" monitor that you could manually rotate to vert.  I had to lose the speakers under the marquee to fit it but I think it came out pretty well.
I can't wait to see what you do with this newest design of yours.  Keep it up man.
lokesen
« Reply #6 on: April 11, 2012, 04:49:27 am »
Thank you, I hope it turns out OK :)
More to come...
  • Last login:Yesterday at 10:59:20 am
« Reply #7 on: April 11, 2012, 05:09:47 am »
Thanks for posting this, your builds are always hugely inspiring.  :cheers:
ark_ader
  • I glow in the dark.
« Reply #8 on: April 11, 2012, 05:32:48 pm »
I'm looking for a nice easy weecade project to fill my days when we get some sunshine.
This is looking very promising.  :applaud:
I noticed that you haven't cut slots for T molding, has T molding gone out of style in small projects?
lokesen
« Reply #9 on: April 11, 2012, 05:52:53 pm »
Thank you... I don't have any experience with t-molding nor the tool to cut the slots for that. But I would like to make one with T molding next time.
More to come...
Unstupid
« Reply #10 on: April 11, 2012, 07:16:48 pm »
I think you are going to run into some problems here..... the marquee lip overhangs the monitor wen looked at perpindicular to the screen.  to see all of the screen you have to look at the screen at an angle... look like about 30deg angle there.  Any off angle is going to be problematic for LCD screens since 17" IPS panels are hard to find.  Now it's not going to be too bad since you are mounting the monitor vertical, but if someone was to mount a 19" horizontal like you suggest then they would be looking at it from a below the screen which is really bad.   Also your stick man looks too low... it looks like his hands would have to be up high just below his shoulders.  Not comfortable if your fore arms are above horizontal.
Other than that... Nice design... Kinda reminds me of the ones this guy on ebay is putting out:
« Last Edit: April 11, 2012, 07:18:31 pm by Unstupid »
lokesen
« Reply #11 on: April 12, 2012, 04:09:33 am »
Noted - but...
Ergonomically this cabinet is close to as good as it possible can IMO, when playing in on a dining table.
The picture you are referring to illustrates the lowest ange to view the cab from (like a child) - this is just one of the situations I have worked out. There is several other situations to illustrate a person of avarage height (myself) and one to show the highest angle before the marquee is a problem. When you are avarage height your arm will have en angle close to 90 degree and your angle to the monitor will be closer to 90 degree.
Believe me, I use a lot of time thinking out these issues. Let's just see how it play when finished - maybe you're right ;)
I hope it will not look too much like the cab from the YouTube video - I don't like that too much.
« Last Edit: April 12, 2012, 05:13:04 am by lokesen »
More to come...
Richie_jones
  • Last login:February 19, 2026, 01:59:01 am
« Reply #12 on: April 12, 2012, 06:20:57 am »
Great design looking forward to this one..
It was your site I stumbled across one day that led me to start my own project.  I don't even know what I was looking for at the time, but your website popped up and I'm now nearly finished my first cab...maybe a juke next, then maybe this verticle.l!!!!
Cheers
lokesen
« Reply #13 on: April 12, 2012, 09:02:05 am »
Cheers
I appreciate you saying that, because that is the whole idea with my homepage. It's the beginners place to start a new hobby, and eventually this also means more users here at BYOAC. Everybody wins :)
More to come...
lokesen
« Reply #14 on: April 13, 2012, 04:54:07 am »
Updated with new pictures
More to come...
Dalgaard
  • Last login:April 05, 2015, 01:42:14 pm
« Reply #15 on: April 13, 2012, 09:51:41 am »
Looks great as always! You're the reason I got started on this hobby...my Starcade: http://forum.arcadecontrols.com/index.php?topic=116996.0;all was hugely inspired by your work :) Not too many danish people in this hobby? Keep it up...ill be following the build intensely.
  • Last login:Yesterday at 11:45:21 am
« Reply #16 on: April 13, 2012, 10:13:42 am »
Good work!  :applaud: :applaud: :applaud:
lokesen
« Reply #17 on: April 14, 2012, 02:13:06 am »
I love your artwork! Sent a picture to my mail, I would like to feature it under user project on my homepage :)
More to come...
Dalgaard
« Reply #18 on: April 14, 2012, 11:27:35 am »
Great :) I would be honored. Let me send you some pictures of the finished cab then...atm all I need to do is fix the marquee.
Dalgaard
« Reply #19 on: April 14, 2012, 02:44:59 pm »
Looking good! :) Can't wait for further updates!
BobA
  • What Me Worry?
« Reply #20 on: April 14, 2012, 04:23:28 pm »
Progressing really nicely.  :applaud: :applaud:  Is there any way to install pinball buttons on the sides of the cabinet?   Looks like supports would block the installation of the buttons.
lokesen
« Reply #21 on: April 14, 2012, 05:42:33 pm »
You could just drill straight through the support. But I am not going for Pinball buttons this time around though.
More to come...
lokesen
Re: VertiCade - Successor to the Weecade (huge update!)
« Reply #22 on: April 20, 2012, 03:05:47 pm »
Huge update to the thread and now it's more or less done!
Working drawings will be ready in just a few days now here:
More to come...
Unstupid
« Reply #23 on: April 20, 2012, 03:12:59 pm »
Looks awesome!  But It could really use some black t-molding!
Uncle Monkey
  • Last login:September 12, 2020, 10:16:25 pm
  • P24L
    • Project Thread
« Reply #24 on: April 20, 2012, 03:23:18 pm »
NO!!!!! It looks sleek and unique as is, no t-molding please...... :soapbox:
« Reply #25 on: April 20, 2012, 04:43:02 pm »
It's beautiful!  :applaud:
  • Last login:February 27, 2026, 12:32:01 am
« Reply #26 on: April 20, 2012, 05:02:30 pm »
Looks really great loke!
Are you going to put side art on it?  It would look really nice if you had a circular logo on the sides, something that matches the marquee.
Either way, it looks really great and cleanly built.  :applaud:
lokesen
« Reply #27 on: April 20, 2012, 05:26:33 pm »
The location of the marque is going to be a major hindrance.  Looks nice but doesn't look like it would be comfortable to play.
I am very sorry to say that it is comfortable for play - sorry about that. I don't actually know what the major hindrance of the marquee is. Nothing I have noticed.
More to come...
lokesen
« Reply #28 on: April 20, 2012, 05:29:36 pm »
Thanks.
I am working on some side art, but I am undecided about it atm. I guess I need more time to come up with something good.
More to come...
Termin8tor
« Reply #29 on: April 20, 2012, 05:40:23 pm »
Great work as always, truly inspiring :cheers:
Vidiot
  • John 3:16
« Reply #30 on: April 21, 2012, 08:30:16 am »
Looks like a very similar shape of my current build. I love it man. I wanted mine to be a vertical screen at first but I couldn't find a screen to mount in there that wouldn't be obscured by the marquee overhang. Looks like you overcame that problem. Great job! :applaud:
taylormadelv
  • Last login:February 18, 2019, 05:46:59 pm
« Reply #31 on: April 21, 2012, 12:43:16 pm »
Very insipiring build! I really love the way you eliminated the T-Moulding! Sweeeeeeet! What a sweet looking bartop!
kalars123
  • Last login:August 09, 2019, 12:31:51 pm
« Reply #32 on: April 21, 2012, 01:10:37 pm »
looking great as always where do you get your panel mount usb and power connectors I've been trying to find them online but haven't found those exact ones yet
lokesen
« Reply #33 on: April 21, 2012, 03:13:19 pm »
Thank you - but I have nothing against T-moulding at all. I think up right cabinets looks better with T-moulding, but IMO they are much too dominating on smaller bartops.
More to come...
lokesen
Re: VertiCade - Successor to the Weecade (Finished - and plans uploaded)
« Reply #34 on: April 23, 2012, 06:44:59 am »
More to come...
Well Fed Games
  • Delicious!
« Reply #35 on: April 23, 2012, 08:26:07 am »
Very nice, thanks for sharing the plans.  :cheers:
lokesen
« Reply #36 on: April 23, 2012, 02:25:03 pm »
Thank you - no problem!
More to come...
lokesen
« Reply #37 on: April 26, 2012, 07:30:14 am »
A couple of new pics added.
I am updating the CP with spinner for Arkanoid and I will post pictures of that soon.
More to come...
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« Reply #38 on: April 26, 2012, 08:08:28 am »
I love your work lokesen. This is another amazing bartop!
Woodshop Flunky
« Reply #39 on: April 26, 2012, 11:47:38 am »
This build is tip-top!  I love the yellow side panels.  :applaud:
Questions...
1. Where did you get your LED strips?
2. I like you'r silent running setup.  What are you using for a hard drive?  I tried to use something similar to...
