Author Topic: Touch Screen Jukebox project conversion  (Read 20347 times)
0 Members and 10 Guests are viewing this topic.
ronnie-dent
  • Last login:May 15, 2020, 09:42:50 am
« on: April 07, 2012, 10:14:26 am »
Mentioned this in another thread, now work has began!
This is an NSM Hyperbeam slave wallbox, I was going to keep the lighting that was there but decided to remove all the inards and start fresh
I will be using-
17" ELO touch screen
pentium dual core 1.63ghz
2gb ram
300gb hd
Nvidia ge force 8500 graphics
Probably Album Player on xp pro with instant sheller
I plan to use a hifi amp for the sound not sourced yet! and the lighting probably dream leds.
pictures are not working for me will try in next post
ronnie-dent
Re: Touch Screen Jukebox project conversion
« Reply #1 on: April 07, 2012, 10:16:31 am »
Ok picture above before work started.
next stripped cabinet
ronnie-dent
« Reply #2 on: April 07, 2012, 10:26:14 am »
Now with mdf bezel cut to hold the touchscreen, a sign making company is making a perspex plexi to go over the mdf to tie in with the old glass but that has yet to be designed
problems to overcome are connecting the coin mech up to the sotware was thinking i-pac
Also power source for touchscreen and driver board, might use an xbox 360 power brick as I have a few spare.
Very much a work in progress and all ideas and advice most welcome
ronnie-dent
« Reply #3 on: April 07, 2012, 01:04:39 pm »
Had a mess with paint
Meph
  • Last login:December 14, 2025, 12:30:01 pm
« Reply #4 on: April 07, 2012, 03:54:19 pm »
Cool project.  I have been planning to convert a wallbox very similar to that one but instead of touchscreen I was going to hack the original controls and run SK jukebox like I did with my Rowe CD-100A Project.  I will be checking this one out though.
ronnie-dent
« Reply #5 on: April 08, 2012, 12:24:35 pm »
Thanks for that, should have more updates soon
ronnie-dent
« Reply #6 on: April 08, 2012, 03:14:13 pm »
Been thinking of ideas to light the frame of the door, there 2 long tube lights either side and 2 short along the top, chasing leds seems a good idea, plain white as the plastic is coloured blue and red so was thinking on these
http://www.ebay.co.uk/itm/170649749405?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Also the panel along the bottom which housed the keypad and display etc, would like to do something with that space, thought about vu meters
http://www.ebay.co.uk/itm/160730162512?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
but seller gives no details on size, also seen those plasma type discs (instead of a ball) like these
http://www.ebay.co.uk/itm/USB-POCKET-PLASMA-LIGHT-DISK-/280706655242?pt=UK_AudioElectronicsVideo_Video_TelevisionSetTopBoxes&hash=item415b6ba40a
might be ok or too small but something along those lines, or guess I could fit small speakers??
Drnick
  • Plodding Through Life
« Reply #7 on: April 10, 2012, 01:20:35 pm »
The first lights shown look OK, but you may be better off with something like these. (Controller and lights)
http://www.ebay.co.uk/itm/Music-IR-Controller-Sound-Control-12A-144W-RGB-LED-Light-Strip-Stripe-/190658995817?pt=UK_HomeGarden_Lighting_Lamps_Lighting_SM&hash=item2c64296669
http://www.ebay.co.uk/itm/3M-300cm-5050-Waterproof-IP65-RGB-180-SMD-LED-Lamp-Light-Strip-/200734573542?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ebcb683e6
It is more expensive then your original plan, but it means you actually get sound controlled lights rather then whatever patterns the tube light you showed offers. Even if you just set them to White rather then assorted colours they will still pulse to the beat :) .
As for the 2nd option, if they fit any belt I would guess they are about 2.5" - 3.0" diameter. I am putting in some EL Patches in spaces about the same size. (Unfortunately I cannot supply the link as they are no longer in stock).
I think they (The Plasma disks) would look quite good in each corner of your unit :-)
As for the middle holes, Was there no way of re-utilising the numeric keypad from the original setup?  VU meters would be a good idea, I believe Gryhnd could probably assist you with those :-) there may be others out there who have done the same thing, but I can't think of anyone off the top of my head.
ronnie-dent
« Reply #8 on: April 10, 2012, 01:58:59 pm »
Thanks for the info, I did think light to sound would be better and later found these-
http://www.ebay.co.uk/itm/290689795895?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The strips would be the right size to suit the 2 sides and top part, was not sure if these would retain the setting after power off
All the surplus bits such as the keypad I flung on ebay and most parts now sold which will help to buy other bits.
going to keep an open mind on the bottom panel, no doubt I will have more ideas
Drnick
« Reply #9 on: April 11, 2012, 03:28:32 am »
Yep those would work :) Not sure about the retaining settings though.  It looks like there are 3 wires (2 x red and 1 x black) I would guess that the 2nd red wire would normally be used to give it a permanent connection to voltage, I could be wrong and it could be that it is the wire that goes to the switchable ignition normally.  At the worst you would have to press a couple o buttons on the remote to get it working.  Maybe fashion a holder where the numeric keypad used to be that it can fit into :)
ronnie-dent
« Reply #10 on: April 11, 2012, 05:30:19 am »
To be honest I like the look of the lights you linked to, looks a bit more robust, I may just go for those
Meph
« Reply #11 on: April 11, 2012, 07:26:11 am »
Those look great.  I'm really curious about how to wire them to power on automatically with my juke.  For $16 on ebay + $7 for the power adapter I think i'm going to grab a set and play with them.
« Reply #12 on: April 11, 2012, 08:17:50 am »
A few things I discovered with respect to sound activated lighting.
Modules that are for use in cars often will have a "no sound" fallback that just blinks or does something that you might not want it doing in a jukebox. Best to email the vendor to verify that before purchasing.
And the control module sensitivity can be futzy. Sometimes, I like the sound barely audible for just background music, but sometimes, I like it nice and loud.
The prob is the sensitivity adjustment is just one setting, it usually can't vary with volume, so you set it to low volume and you get nice effects, but when you crank the volume, all the lights just go full "on"
or you set it for loud volume and when you turn things down, everything goes dark.
I'm not sure what the best option is, but a controller than can be set to random patterns works pretty good if all you want is a  lightshow.
ronnie-dent
« Reply #13 on: April 11, 2012, 01:27:36 pm »
That's a good point! so what we would need is a light box that took a wired input say that came from a headphone input? must have a trawl and see what is out there.
I have my sound system sorted out, consisting of Rotel RA-840 amp with Kef coda 3 speakers, not sure to go with the onboard sound card or get a soundblaster or the like?
Ronnie
ronnie-dent
« Reply #14 on: April 11, 2012, 01:31:16 pm »
Looking at the pics on this-
http://www.ebay.co.uk/itm/190658995817?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
it has an audio socket, so would guess you could feed a steady signal that would not change with the volume?
Drnick
« Reply #15 on: April 11, 2012, 02:53:14 pm »
It will be steady if you never change windows volume or individual software volumes.  Unfortunately this would mean that you have to control the speaker volume directly from the amp or speakers.  As you are using a proper amp/speaker setup I don't think this would be an issue for you. Set the volume in windows to somewhere between 60 & 90% depending on what sounds best from your amp and what gives best results for the lights. Then never touch it again.  As for sound quality I installed a Soundblaster live to my machine (But then again I needed the 5.1 outputs for my speaker setup).  It definitely sounds better then the onboard realtek device.  If you do go down the SB Route  do yourself a favour and make sure you get drivers with it. I installed an OEM SBLive and the hassle I had getting working drivers under XP.  :hissy: Don't forget that whatever route you take you would need a headphone splitter cable so you have 1 side going to the amp and the other going to the LED Controller, I got 3 of these for my current setup :)
http://www.ebay.co.uk/itm/3-5mm-Stereo-Jack-1-Plug-2-x-Sockets-Headphone-Splitter-Adaptor-Plug-iPod-UK-/150764960647?pt=UK_Computing_CablesConnectors_RL&hash=item231a4abb87
ronnie-dent
« Reply #16 on: April 11, 2012, 03:00:37 pm »
Thanks for the advice, yes I was thinking I would leave the windows sound level to where it was best
I think with mp3 you loose some of the sound quality anyway?  think I will wait and see how it all sounds, might add a card later
The PC is nearly ready, it was a full size tower! lets say it's now sawn off >:D
pics soon
Drnick
« Reply #17 on: April 11, 2012, 03:08:17 pm »
:) Edited my last post and you had replied in the meantime.  Yeah you do lose some quality with MP3 over source material. I just rip my stuff at 320 for mp3 and 256 for aac,  It all depends on what's going to play it. (Juke or IPOD)
ronnie-dent
« Reply #18 on: April 11, 2012, 03:15:59 pm »
Lol, thanks, I have a feeling I have one of those!! but where??? will need to look in my box of wires see what I have
Ronnie
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #19 on: May 10, 2012, 06:48:37 am »
That is basically how herrondata do their conversions. They seem to have a problem with fixing their screens in securely though or at least on the ones I have encountered.
« Reply #20 on: May 10, 2012, 11:10:53 pm »
just thought i'd throw this in...
i used RGB LED strips to light up everything. I also used a piece of translucent plexi on the front.
Drnick
« Reply #21 on: May 12, 2012, 07:20:26 am »
Yay, I'm allowed to put money in that jukebox "Loonies only"  :laugh2: I just can't take that currency seriously, I just cant.
« Reply #22 on: May 12, 2012, 12:53:31 pm »
actually this is a route machine so yes you HAVE to put money in it.
it's only $1 coins because the machine had to be installed before a replacement electronic mech could be located for it. (old ass ms111) a shiny new coin controls SR5i series mech is on order... so we scabbed the original to only accept $1 coins for now.  :dunno no big deal
ed12
« Reply #23 on: May 12, 2012, 01:58:19 pm »
hi
just a q here if u do not mind
u are in canada right ?
if so lonnie/tonnie will not work with any older accepter
unless u swap out to :mei-cash-flow-refernce-series-330:,
i know done it did it have the tire mark's
ed
« Reply #24 on: May 13, 2012, 04:37:49 pm »
hi
ed
some can be just reprogrammed. the old mars 111 series rom chip holds 4 coin profiles. is too small to hold all the coin profiles needed for all these goofy canadian coins (25a 25b 100a 100b 200a 200b) Canada changed the metalurgical content of the coins so each coin now needs their own profile. If the accept window is so wide it accepts both types (nickel (a series) and plated steel coins (b series)) the acceptor will start accepting slugs because the coins are so different.
the 111 can be hacked to accept 1.00 and 2.00 coins by sacrificing the quarters. newer series 111 (after money controls took over the company) are a little more advanced and can be programmed a little better.
yes the mei 9500 series is the most compatible with the unit existing in there, but the rest of our machines are using the money controls SR3 mech. the SR5 is compatible with the programmer we use with the SR3 units so with a little modification, the SR5 is future proof for us.
ed12
« Reply #25 on: May 13, 2012, 04:59:53 pm »
hi
sorry i detest the sr series
and mei did state that the token reject is still in place
i will be doing field progamming next week to test this
and yes the canadian coin's have gone goffey to say the least
the new tonnie for example has 3 maple leaf's on them
the new toonie is rounder,thus making the accepter thinking it is a token
u said u have a patch for sr5 ?
how about sr3 ? these are used in touch-tune's
and they said that the mfg is still working on the patch
hence the reason i got the mapping for mei's and sr3's so i can convert
also a side note here are u using bill accepter's ? if so what type ?
as the ict's we have have will not accept the newest 5$ bill
and i have little faith they will beable to take the new polymaier when they get realsed in nov 2012
ed
« Reply #26 on: May 13, 2012, 05:41:13 pm »
 :P SORRY BOUT THE HIJACK  :P
 the SR5 is basically a wide body SR3 so it's nearly identical. the programmer is the same one.
yes we just started loading the new profiles in the last week or so. they had to push back the coin profile release because there was a huge variation in the coins being produced and the acceptance was low. they seemed to have worked it out.
ed
we are using ict. the p70 series and the A6 series. we have an FP-001 programmer for these as well. the bills acceptors are a little different from the coin programming but if your acceptors are not taking the 2006 issue of the 5 dollar bills then it would simply be a matter of flashing the rom with an updated version.
as for the polymer notes... the release for the 5/10/20 is looking like late 2013 before they hit the streets. we haven't bothered with the 50's and 100's that have already been released as they are very unlikely to be used in our machines... i'm optimistic though... I'll shoot our guy at ICT an e-mail to find out for sure.
ed12
« Reply #27 on: May 13, 2012, 07:18:16 pm »
ya sorry i did not mean to hi-jack
side note
i have the same programer for the ict's
it is the 2009/10 5$ note that they will not take
i would love to talk private to u about the other
ed
« Last Edit: May 13, 2012, 07:24:12 pm by ed12 »
ronnie-dent
« Reply #28 on: May 18, 2012, 04:09:55 pm »
Ok getting back to my project, has been a while but the place doing the plexi took a month to do!! so thing came to a halt, got it back on Friday so have been working away since
By no means is it finnished but is running, see what you think so far?
ronnie-dent
« Reply #29 on: May 18, 2012, 04:11:55 pm »
and more
ronnie-dent
« Reply #30 on: May 18, 2012, 04:13:51 pm »
more yet
ronnie-dent
« Reply #31 on: May 18, 2012, 04:18:51 pm »
Still need to work out a way to connect the coin mech
Do somthing with the panel where the keypad was
also where the selection rocker was
finnish the pc setup properly, as in get a full copy of album player, get it all so I'm happy with it, setup instant sheller and use my custom boot screen
Drnick
« Reply #32 on: May 18, 2012, 05:37:14 pm »
I would hack a usb numeric keypad for the coin input, I presume the software will allow you to set any particular key for coin insert.
Did you get the led set I linked to, if so how did you find it to work with, nice and simple?  Does it work well?
ronnie-dent
« Reply #33 on: May 19, 2012, 04:39:01 am »
The credit board that was in the juke also has a reducer regulator 18v to 12v for the mech, I may need to change the mech to somthing more standard? not sure what yet
Yes I did use those lights and they are great, very easy to work with, but now I have the amp in there I'm getting some interference from the lights? not looked into that as yet.
cheers Ronnie
Drnick
« Reply #34 on: May 19, 2012, 05:08:20 am »
Is the amp running from its own power source?  I presume the leds are running from 12v on PC side of things?
ronnie-dent
« Reply #35 on: May 19, 2012, 05:44:59 am »
Yes the amp from mains 240v the pc is running by itself, everything else, lights monitor and touchscreen from and xbox 360 brick
cheers Ronnie
Drnick
« Reply #36 on: May 19, 2012, 09:47:30 am »
Its possible that the amp has ground to external chassis and that is causing it.  Not sure on how to check that one, I suppose move the controller and the amp further away from each other and see if the effects lessen. If they are both plugged into the same power strip try moving them onto separate strips.
What amp are you using for this, Car Audio Amp? 12V Portable Amp?  Do you know what the power draw is on the amp itself.
« Reply #37 on: May 19, 2012, 10:44:39 am »
cheers Ronnie
the board can be modified easily to accommodate whatever mode of switching you need. the regulator is a standard 7812 regulator, you can feed it as low as 15 and up to 30 volts DC. or you can remove it and bypass the regulator and run the mech off of 12 volts supplied from the computer or other 12 volt power supply.
the board is also wired up by NSM to switch between two resistance ratings to indicate the credit, which will not work with any system you would setup, a small modification is needed to switch the board to either supply a high or low signal for your coin in.
let me know what you require and i can tell you how to mod the board acordingly.
ronnie-dent
« Reply #38 on: May 19, 2012, 11:16:15 am »
I'm using a Rotel RA-840 hifi amp, I have it bolted inside the cabinet so it is grounded via the bolts to earth, the mains wire for it was unearthed?
ronnie-dent
« Reply #39 on: May 19, 2012, 11:20:27 am »
cheers Ronnie
Brilliant, your just the guy I was looking for to help me with this,
I have a 12v supply to run it so just need to sort out the credit side of things, was going to buy an ipac but thought it was overkill for a couple of inputs, Album player supports credit via key strokes, so whatever you think would be best
thanks Ronnie
