Author Topic: Best way to fill metal cp holes?  (Read 2072 times)
mrcram
  • Last login:October 07, 2016, 05:47:03 am
  • OREGON STATE
« on: February 12, 2012, 11:57:43 am »
I would like to fill these before I put on a new overlay as cp will now be used for gun holster. Best method? Its on a virtua fighter 2. That thin sheet metal stuff.
Sent from my LS670 using Tapatalk
Hoopz
  • Last login:Yesterday at 09:59:38 am
  • Intellivision Rocks!
Re: Best way to fill metal cp holes?
« Reply #1 on: February 12, 2012, 12:11:49 pm »
Bondo and sand.   :cheers:
« Reply #2 on: February 12, 2012, 12:28:04 pm »
JB Weld some sheet metal onto the bottom to brace the holes then bondo and fill the top.
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #3 on: February 12, 2012, 02:04:41 pm »
What they said.  I'm finishing one up now.  On mine the epoxy I used to attach the backing plate failed on one hole so the bondo kinda squeezed out a little bit, but no harm.
Bringing to life a child's imagination.
migraineman
  • Last login:July 01, 2016, 02:56:35 pm
« Reply #4 on: February 14, 2012, 03:36:45 pm »
Add some kind of backing material and bondo the front.  My Gals Panic II cab was heavily modded by a previous owner - brazed a galvanized steel outlet box cover to the back.  Ugly on the back, but smooth on the front.  JB Weld should work fine in this application, as there's no real load on the panel.
elkameleon
« Reply #5 on: February 14, 2012, 04:19:15 pm »
I have the same machine, I just had a new cp made... but I have the resources for that, so do what everyone else said.
mgb
  • North East, US
« Reply #6 on: February 14, 2012, 11:56:18 pm »
I actually took the metal knock outs out of 4" electrical boxes and jb welded them in and then bondo'd. they help op great, even when drilling my new holes actually overlapped the filled holes
« Reply #7 on: February 15, 2012, 12:02:58 am »
So when are you going to start sharing the wealth?  :bat  I've got metal that needs bending.  Plans... big plans.
Q*Bert_OP
  • Oh yes, we did!
« Reply #8 on: February 15, 2012, 06:25:18 am »
Why not just leave the holes there and cover the overlay with plexi?
elkameleon
« Reply #9 on: February 15, 2012, 08:29:41 am »
Hey, I would, if I knew the guys in the shop were competent enough to follow my design the first time! I don't have any problems at the plasma table, because well, I design what gets cut out, but they always ALWAYS screw up the bending! I had my CP made 3 times before it was right...
mrcram
  • OREGON STATE
« Reply #10 on: February 15, 2012, 11:20:30 pm »
Thanks for the advice.  Going to weld and bond it.
