Author Topic: Lighting Paradise Arcade 5v LED Lighted Arcade Pushbuttons  (Read 6125 times)
daillest319
  • Last login:April 04, 2012, 08:48:41 am
« on: February 06, 2012, 03:05:45 pm »
Anyone have any idea how i would light these. i am a noob in this area i purchased 16 buttons. I placed two links below of the buttons and a power supply i purchased but i have no idea what wires i would need and how i would connect them to light the buttons.
Also for the buttons details i purchased the 75 gram cherry microswitch and voltage for all the buttons is 5v.
http://www.paradisearcadeshop.com/en/230-red-led-convex-arcade-pushbutton.html
http://www.paradisearcadeshop.com/en/electrical/4-arcade-switching-power-supply.html
Brian74
  • Yep... I built that!!
Re: Lighting Paradise Arcade 5v LED Lighted Arcade Pushbuttons
« Reply #1 on: February 06, 2012, 03:17:23 pm »
If Im not mistaken, you should be able to tap into the 5v on you molex connector coming from your ps in your pc. I added a picture about what Im talking about.
« Reply #2 on: February 06, 2012, 03:19:09 pm »
He's using an arcade switching power supply, not a computer power supply. But all he needs to do (same principle) is put ground to ground and + of the LEDs to the 5V terminal of the power supply.
daillest319
« Reply #3 on: February 06, 2012, 03:43:50 pm »
if i was to use a pc power supply or the power supply i have how would i connect each button to go to the power supply. That is where i am stumped. I am not good any wiring fyi. so what type of wires would i need to buy to connect them all to go to the power supply.
For examply do i have to do anything to the buttons or the wires on the buttons and how do they alll go to that one spot on the power supply.
 Thanks you in advance
« Last Edit: February 06, 2012, 03:47:29 pm by daillest319 »
« Reply #4 on: February 06, 2012, 03:45:17 pm »
If they're going to be on all the time, you can daisy chain the power and ground from one button to the next.
daillest319
« Reply #6 on: February 06, 2012, 04:50:19 pm »
Looks like those will be fine. Judging by the pic of the button, the LED terminals look to be .250". Email Paradise to make sure though.
daillest319
« Reply #7 on: February 07, 2012, 08:41:26 am »
customer service told me .250 but at the of the button page it states the following....
So would the .250 fit? or do they have to be .187.
-Made to fit 24mm to 30mm holes (this includes 1 1/8 holes)
-Great for 1/16 inch metal to 3/4 inch wood control panels
-Buttons come complete with all parts needed (LED, microswitch, locking nut, and washer)
-Happ quality microswitches with .187" terminals
Also would i need the following link below to be on the wire or do i just need to split it somehow.
http://www.paradisearcadeshop.com/en/jamma-harnesses/66-ezswitch-off-led-button-control.html
« Last Edit: February 07, 2012, 08:55:05 am by daillest319 »
« Reply #8 on: February 07, 2012, 08:55:55 am »
The terminals for the microswitch are .187" (but are stepped and can also accept a .250" female quick disconnect, so you can use either for the microswitches), the terminals for the LEDs are .250" (can't use .187" female quick disconnects on the LED terminals).
You wouldn't need that unless you want your LEDs to turn off when that particular button is pushed.
« Last Edit: February 07, 2012, 08:58:32 am by Nephasth »
daillest319
« Reply #9 on: February 07, 2012, 08:24:32 pm »
Thank you Nephasth for all your help I do really appreciate it. Now im just waiting for my cables to come in  ;D
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 11:13:05 am
« Reply #10 on: February 07, 2012, 10:48:44 pm »
If i'm not mistaken I believe that you can tap 5v from the ipac if thats what your using as an encoder.
gatordad
« Reply #11 on: February 08, 2012, 10:24:23 am »
Found it here
http://www.ultimarc.com/jpac2.html
Scroll down to header plug diagram
I lit my leds on my trackball this way
daillest319
« Reply #12 on: February 09, 2012, 02:40:34 pm »
gatordad,
               that would be perfect. I had question would led wiz be able to light my buttons?
I have an led wiz this one excact
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=82&products_id=239
if it can't light my buttons ill purchase the ipac then.
gatordad
« Reply #13 on: February 09, 2012, 11:20:57 pm »
The Led Wiz gives so much flexibility for lighting buttons
It's programmable!
I was just pointing out an option for grabbing 5volts off of the button and control encoder (ipac)
Both Vendors are great
Groovy Game Gear and Ultimarc
BobA
  • What Me Worry?
« Reply #14 on: February 10, 2012, 04:07:29 pm »
The LED wiz will power the 16 single color buttons you have but you will have to supply it with a USB connection. I do not know how you will program the LED wiz and get it to operate without a computer.  You can just use a direct connection to your arcade power supply 5V and ground to run your LED buttons.  In that case you do not need and LED wiz.
