Author Topic: First Build. Starting off with a Bartop.  (Read 4264 times)
CharlesDeMar
  • Last login:October 11, 2017, 11:46:41 am
« on: January 19, 2012, 04:31:13 pm »
Hey guys!  I have been lurking for a few months and finally decided to share what I have been up to.
A few months back, I decided that I wanted to make a MAME cabinet from scratch.  I don't have a whole lot of room in my townhouse, so I decided I would build a bartop.  Seemed logical at the time, even if I didn't have a bar in my house.  I soon realized that these bartops take up just as much space as a regular machine because you need a table or something to put it on.  I had dabbled in the emulator game for awhile now.  I had put Maximus Arcade on my HTPC and played using a logitech wireless gamepad.  Just wasn't the same as a joystick, so I set out to build this bartop.
I built it based on the plans for the Weecade.  I had to adjust some measurements to fit a 19" LCD monitor, but everything is pretty close.  First, I made a template for the sides out of plywood:
I used 3/4" MDF for the sides:
Used 1"X1" pieces to attach everything together (wanted to avoid screw holes on the outside):
End of day 1.  Made some progress.  I had a shell to work with:
Next I added the monitor to make sure it would fit:
I decided to use LED buttons and LED joysticks from Paradise Arcade.  The main reason was so LEDBlinky would speak the controls at the start of each game and keep them lit so I knew what was what.  In hindsight, it may have been a bit excessive.  But, whatever...
Had to router the bottom of the control panel because the joystick shafts were too short:
Cut out some holes for the speakers and fan.  Then sanded and prepped the cab for primer:
My wife let me take over the kitchen table for priming and painting.  Chicago winters are a bit too cold for painting in an unheated garage.  After 3 coats of primer, the painting began.  I got the glossiest black paint that I could find.  BTW, I still have no idea what I am going to do for a theme.
I put the initial coats down with a brush and sanded after each coat.  The final coat was done with a sponge roller.  It is hard to describe the final texture of the paint.  Definitely not super smooth.  But, I actually love the way it came out:
Time to put all the pieces together.  Speakers and marquee light installed:
Exhaust fans in the back as well as an access panel:
Buttons and joysticks installed:
LEDWiz and iPac installed on the back of the LCD mount:
Audio amplifier also installed on the back of the LCD mount:
Control panel all wired up:
As you can see by the last picture, I used RJ45 (ethernet) connectors so I could easily remove the control panel.  My thinking was that I could eventually build other control panels (trackball, spinner, etc) and easily swap the out.  The control panel is secured with panel clamps.
I originally bought a P4 computer off of eBay for the guts of the machine.  However, while I was waiting for the machine to be delivered, my nephew stepped on the LCD screen of his laptop.  The cost to fix the LCD was almost as much as the machine itself.  It is a dual core with 2 gigs of Ram.  I made a deal with him.  He gives me the laptop and I'll take him to Gamestop to buy an Xbox game.  Seems like a win-win to me.  Here is a few pics of the laptop outside of the machine (still have to figure out a way to get it inside the cab (alot less room than I had anticipated).
(The Wacko game on the screen is fitting since that is what my wife says I am for building one of these)
Here is a pic of the buttons lit up:
It has definitely been a learning process.  It has been rewarding, frustrating...well, mostly frustrating.  But, I am not out of the woods yet.  Here is a list of some of the things I still need to do:
1. install marquee
2. install plexi bezel over the monitor
3. tidy up the inside of the cab
4. install volume control
5. figure out if I want to put artwork on the sides and control panel (call me crazy, but it looks pretty slick being all black)
Let me know what you guys think!  I'll post up some more pics when I finish her up (maybe a video so you can see the LEDs in action).  Comments?  Suggestions?  Criticism?
DaveMMR
Re: First Build. Starting off with a Bartop.
« Reply #1 on: January 19, 2012, 05:03:59 pm »
I like when new members have a good looking cab right out of the gate.  You've incorporated a lot of the things I was thinking for a bartop (swappable panel design, 19" monitor, etc.)   Is playing two-players on this comfortable enough?
Agreed. Sometimes plain "black" is simpler and simpler is sometimes better.   Besides, now that you made it playable, you'll never find the time to work on artwork anyhow.  ;)
Anyway, good job.  :cheers:
« Reply #2 on: January 19, 2012, 05:21:04 pm »
Great start and good looking CP.  Nice and colorful.  Having fun fitting everything into the weecade?  I found it's a really great bartop design but can be a bit of a tight squeeze.   :applaud:
HatTrick77
  • Last login:January 20, 2012, 03:02:21 am
« Reply #3 on: January 20, 2012, 02:27:37 am »
nicely done :applaud:  your wife sounds like a good sport for letting you drag your toys into the house.  this deep freeze we're having isn't fun, less than 2 weeks ago it was nearing 50* and i washed my car in the driveway.
Newgeta
  • Last login:August 29, 2016, 10:54:08 am
« Reply #4 on: January 20, 2012, 06:14:22 am »
nice build!
CharlesDeMar
« Reply #5 on: January 20, 2012, 08:28:33 am »
Thanks guys.  I am real happy with the way this is turning out.
It's not too bad.  The CP is 20 inches across (not sure what the Weecade was).  I haven't had a whole lot of gameplay, yet.  But, so far so good.
I hear ya on that one.  Seems that I got alot more done when I didn't have the flashing LEDs and the occasional "Get Over Here!"(MK) calling out to me.
Yeah, it's a pretty tight fit.  I can't imagine squeezing a P4 MB and power supply in there.
...less than 2 weeks ago it was nearing 50* and i washed my car in the driveway.
It's been a crazy winter.  I was sanding this badboy outside 2 weeks ago.  Now the temp guage in my car is reading single digits.
Thanks again guys for the comments.  My marquee should be arriving soon, so I'll post some pics as I get closer to finishing.
« Reply #6 on: January 20, 2012, 09:40:45 am »
Weecade is in the 18.4" neighborhood if memory serves me, I think the extra width is a definite must for a two player and looks better with the larger monitor.  When you cram a 19 in the width on the plans it looks kinda funny (to me at least).  The stock weecade is a bit cramped for two player with 4 buttons and all but unplayable with 6 each.  Good choice to fatten her up a bit.
greystone
  • Last login:March 12, 2012, 06:23:20 pm
« Reply #7 on: January 31, 2012, 04:19:08 pm »
I like what you've done, currently working on a similar project. How are you providing power to the DC amp? I'm assuming your laptop has a dedicated AC/DC power adapter.
CharlesDeMar
« Reply #8 on: January 31, 2012, 06:47:19 pm »
Thanks for the comments.  I purchased a seperate AC/DC power adapter off of Amazon to power the amplifier.  I bought the amp off of eBay.  I was a bit surprised when the amp showed up without a power supply (I guess it was meant for inside a car and wouldn't need a power converter).  I found a power supply that was meant for an LCD monitor that had the same specs.  It was a pain in the ass to match the plug, but in the end it works flawlessly.
nordemoniac
  • Weee! Hahaha...
« Reply #9 on: February 01, 2012, 06:32:36 am »
Is that one of those cheap 12V amps? I've seen some of those with built-in FM radio etc.
They're designed for cars/caravans/boats etc.
Seems like a good enough amp for a cabinet?
CharlesDeMar
« Reply #10 on: February 01, 2012, 01:42:18 pm »
Yep.  Not too bad.  Not enough to power a jukebox or anything.  But, powerful enough for this application.
golden_35
  • Last login:August 28, 2012, 02:58:25 am
« Reply #11 on: March 16, 2012, 10:20:08 am »
Sorry for the inexperienced questions, but here goes:
1) What kind/size screws do you use to screw the 1x1 to the MDF?
2) Once you mounted the LCD to the horizontal piece of wood, how do you secure the bezel and plexi to the monitor or cabinet?
Thank you.
